soundsnake8 27 Posted April 25, 2016 Posted April 25, 2016 I have just switched back to chocolate theme but the red circle check mark on the folder.png is driving me crazy I can not find a way to get rid of it. No matter what I check or uncheck it is always there. For me it is a distraction, I know I am nitpicking but is there a way to stop it from ever showing up ? I also like Xenon theme a lot but the watched, unwatched, latest seletcor seems to be a one time operation, as soon as I switch from Movies to Recorded TV I have to reclick the watched, unwatched, latest. Is there a way to make the selection stay ? Thx. Paul
ebr 16340 Posted April 25, 2016 Posted April 25, 2016 Settings (cog icon) -> View Options -> Played Indicator on Items
soundsnake8 27 Posted April 25, 2016 Author Posted April 25, 2016 quick reply, thanks. I have that unchecked but it makes no difference the target remains !
ebr 16340 Posted April 25, 2016 Posted April 25, 2016 You'll need to provide more information (screen shots) because I just tested it and it worked as designed.
soundsnake8 27 Posted April 25, 2016 Author Posted April 25, 2016 screen shots thanks for looking at this !
ebr 16340 Posted April 25, 2016 Posted April 25, 2016 They are only showing in the recent list, correct?
ebr 16340 Posted April 25, 2016 Posted April 25, 2016 Okay, it is just an anomaly in that one area and you are the first person to notice it in six years . Can't promise when I'll get a chance to look at it but I will.
soundsnake8 27 Posted May 31, 2016 Author Posted May 31, 2016 3.0.304 Fixed the anomaly and the Music lists are also greatly improved ! THANK YOU ! THANK YOU ! 1
