theusedversion 36 Posted April 25, 2016 Posted April 25, 2016 Just wanted to report a few things that I am experiencing with Collections and offer one suggestion.1.) Long press on movies to bring up the multi-select is malfunctioning for me. So you want to add all of an actor's movies to a collection so you bring up the actor's profile and click to see all of their movies. Then you long press on one of the titles so that you can multi-select all of them. And it works. But the title that you long press on will show an X in it's box but it won't register on the top bar. So what can happen and has happened to me several times is that I go to select all of the actor's movies with multi-select and all the titles will show Xs in their box but the number on the bar at top on the left will miss the very first movie despite showing an X for it. It's been like this for the last several updates. I just never reported it. As you can see in the image, all the boxes are marked for the 7 movies but the number on the top only shows 6. 2. Names will accent marks don't show up in alphabetical order like they do for everything else. As you can see in the image below, Mélanie Laurent and Mélanie Thierry appear after Morgan Griffin.Fake Edit: I just realized as I was posting this that I could go into the Edit mode and change the sort name and just replace the accented letter with the regular version. So that's a work around. 3. Last issue, uploaded cover images still constantly disappear and then reappear again. I've posted about this issue before but figured I would bring it up again since I'm already talking about Collections. Uploaded images will disappear and will show one of the cover images for one of the movies in the collection. They will eventually reappear again. They are never moved from the directory that they are saved to. Not sure what causes it. 4. I would like to make a suggestion. For those with large collections, bottom navigation on the collections screen (the left and right arrows) would be great. As of right now, you have to scroll all the way back up to the top. Not a big issue. Just thought it would be nice.
theusedversion 36 Posted April 25, 2016 Author Posted April 25, 2016 I meant Checkmarks instead of Xs for the first issue.
theusedversion 36 Posted April 25, 2016 Author Posted April 25, 2016 In case I wasn't clear on the first issue, the problem happens on whatever title you first long-pressed on. It's always that first title that fails to correctly register as selected.
Luke 42186 Posted April 25, 2016 Posted April 25, 2016 I'm looking into the checkbox issue and also the special characters will be fixed. I can't reproduce the image issue though. 1
