shagia 0 Posted April 24, 2016 Posted April 24, 2016 (edited) Hey all, recently I've installed Emby through the stable release channel on a Raspberry Pi running Raspbian, the install was successful (Emby responds without error when you type in it's command on a terminal), but I can't connect to the 8096 port for some reason, and it doesn't seem to be taken by Emby either. Connecting to the port after restarting the Emby service just throws me a "ERR_CONNECTION_REFUSED" error. I've even opened the ports 8096 to 8920 on my router, still nothing. I successfully started a server on 8096 by doing: nc -l 8096 This brought back browser information when I connected to the port even though Emby was running, I thought. I even checked out the emby-server.log file, and it's just nothing. So now, I assume Emby just isn't doing anything. Edit: still writing this post, but I just tried to check the service status on emby-server, and I got this: pi@RaPi:~ $ service emby-server status emby-server.service - Emby Media Server Loaded: loaded (/lib/systemd/system/emby-server.service; disabled) Active: failed (Result: exit-code) since Sun 2016-04-24 20:16:36 UTC; 11min ago Process: 5544 ExecStopPost=/usr/bin/emby-server clear (code=exited, status=0/SUCCESS) Process: 5484 ExecStart=/usr/bin/emby-server start (code=exited, status=1/FAILURE) Main PID: 5484 (code=exited, status=1/FAILURE) Not exactly sure what to do at this point after looking at so many forum topics and fixes, so I'm hoping I can get it solved here , I'm still pretty new to linux / bash so I'm unaware if there's anymore commands that can possibly pass anyone more information on this issue. Edited April 24, 2016 by shagia
shagia 0 Posted April 25, 2016 Author Posted April 25, 2016 update, I reinstalled through the same repo, and although Emby is still failing to run, I'm finally getting some info in my log: Info, Main, Emby Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.1.17.7 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /var/lib/emby-server Mono: 4.2.3 (Stable 4.2.3.4/832de4b Wed Mar 16 13:34:50 UTC 2016) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe [ERROR] FATAL UNHANDLED EXCEPTION: System.NullReferenceException: Object reference not set to an instance of an object at MediaBrowser.Server.Mono.MainClass.Main (System.String[] args) <0x751a9218 + 0x00258> in <filename unknown>:0 exception inside UnhandledException handler: Object reference not set to an instance of an object exception inside UnhandledException handler: Object reference not set to an instance of an object
shagia 0 Posted April 25, 2016 Author Posted April 25, 2016 (edited) last edit most likely, I got it running. I just went on the github page and got the latest master. how dumb of me ahahah Edited April 25, 2016 by shagia
Luke 42243 Posted April 25, 2016 Posted April 25, 2016 Hi, thank you for your resilience. I have a feeling it's the same issue as this: http://emby.media/community/index.php?/topic/33725-dockerserver-keeps-crashing/&do=findComment&comment=324167 And I pushed a fix to master for that today. Thanks! 1
