Mentalblaze 9 Posted April 23, 2016 Posted April 23, 2016 My OpenMediaVault have been using a lot of memory for a while so I started to examine what might be the cause of this. Today I found a possible suspect but I need some help to investigate further and if possible solve it. Today I started by restarting OMV. Then I used Emby a couple of hours, creating the used ram to increase to close 2Gb (of 8gb), so that is not a problem. After that I wanted to see what happened if I triggered a Library sync. That took about 2-5 minutes and during the first two minutes, the memory used rised up to 4gb. Still not a problem if not for the fact that the 4gb memory still is locked after half an hour. The used memory is now up to 5gb and I expect it to rise further during the night as emby handles the scans automatically so that there is only 0.5gb left in the morning for the system to use... If I look among my processes, emby user takes around 3 to 3.5 percent of the memory for mono. So the rest is hidden somewhere. Earlier I tried by stopping the emby service, but no memory was released (only had it turned off for a minute). Is this a known problem that there is a solution or workaround for? I have OMV 2.2 and emby 3.0.5818.0 Any more diagnostics I can run to pinpoint any problems?
Luke 42243 Posted April 23, 2016 Posted April 23, 2016 Hi, welcome. The first tihng I would do is update to the latest version of Emby Server, then try again and report back. Thanks!
Mentalblaze 9 Posted April 26, 2016 Author Posted April 26, 2016 Since my question I tried to upgrade Emby to see if that would help, but I ran into other problems along the way. Mainly bad sectors on the OMV drive, forcing me to do a temporary reinstallation (I will do a proper one on better media soon)... That is the main reason for a late response. That said, if and when I reinstall Emby Server on the OMV (have it on a Windows server for now), how can I limit Mono to a certain amount of RAM? After a bit of investigation it seems like the culprit is the Mono framework. I would like to set a max of 2Gb ram for Mono. And probably schedule restarts once a day or something to see if that helps. Is that a good idea?
Luke 42243 Posted April 26, 2016 Posted April 26, 2016 Hi, I don't recall it off the top of my head, but i think there are some memory related command line parameters that mono can accept. 1
