scope99 7 Posted April 22, 2016 Posted April 22, 2016 When a scan media task is run the server is hanging on 53%. While stuck Emby uses 16% system resources. Attempting to stop the task fails. I have attached a log which shows the scan starting at 7.30.56 and an attempt to stop the scan at 7.31.10. If someone could help it would be greatly appreciated. Thanks in advance. Log.txt
Luke 42186 Posted April 23, 2016 Posted April 23, 2016 Hi, since you have a lot of plugins installed, I would suggest removing them and seeing if the issue reproduces with just the core server.
scope99 7 Posted April 23, 2016 Author Posted April 23, 2016 (edited) Thanks for looking at it Luke I have removed all of the plugins and the task is still hanging. Here is the new log: Log.txt Scan starts at: 2016-04-23 13:23:11.4600 Edited April 23, 2016 by scope99
Luke 42186 Posted April 23, 2016 Posted April 23, 2016 The log only represents two minutes of time since you started the scan. I would try to be a little more patient. Sometimes the scan can take a little time.
scope99 7 Posted April 23, 2016 Author Posted April 23, 2016 Actually it has now progressed to 64.7%. I might leave it running till tomorrow morning and see what happens. Thanks
scope99 7 Posted April 23, 2016 Author Posted April 23, 2016 Ok it ran ok. It took 3 and a half hours but now runs in 11 seconds. All fixed.
