roywood 5 Posted April 24, 2016 Author Posted April 24, 2016 There's no path substitution anymore it seems like. Try re-adding it on your server. Sent from my iPhone using Tapatalk Typo, oops. Fixed and still fails to direct play. Log: http://xbmclogs.com/pnvwlhfof Changed play from http instead of samba and tried again. That seemed to load faster. Tried with one other movie and that also seemed to load faster. However, I then went to settings and play from http was again checked. Log: http://xbmclogs.com/psbxtqkk0 Sent from my XT1254 using Tapatalk
xnappo 1611 Posted April 24, 2016 Posted April 24, 2016 So now this is the path: smb://192.168.0.2/DD-Wrt/Movie-Tv/Parents/Bridge of Spies 2015 1080p BluRay x264 DTS-JYK/Bridge of Spies 2015 1080p BluRay x264 DTS-JYK.mkv If that looks right, possibly you need a password? Enter it under Settings->Playback->Network credentials.
roywood 5 Posted April 24, 2016 Author Posted April 24, 2016 So now this is the path: smb://192.168.0.2/DD-Wrt/Movie-Tv/Parents/Bridge of Spies 2015 1080p BluRay x264 DTS-JYK/Bridge of Spies 2015 1080p BluRay x264 DTS-JYK.mkv If that looks right, possibly you need a password? Enter it under Settings->Playback->Network credentials. It does look right. I am not really familiar with network credentials. I've looked around and don't really understand it. Is it the information that goes to my Samba share (usb connected to router) or to the Linux laptop that is running the Emby the server? I have no password or username for the Samba share but I do to log into the laptop. Sent from my XT1254 using Tapatalk
xnappo 1611 Posted April 24, 2016 Posted April 24, 2016 Best way to figure this out: 1. Switch skin to Confluence 2. Go to Video->sub menu Files 3. Add network location 4. In server, put 192.168.0.2 5. In shared folder put DD-Wrt/Movie-Tv Add the location and see if you can see the files. If you can't, then try the laptop username/password.
roywood 5 Posted April 24, 2016 Author Posted April 24, 2016 Didn't work with 192.168.0.2. It did create a network connection with 192.168.2.1 (the IP of my USB hard drive). Tried to make one with the IP address of the laptop running as of emby server but it would not connect. Same error with direct play. Took longer to load. Log: http://xmbclogs.com/pxenna8yj Sent from my XT1254 using Tapatalk
xnappo 1611 Posted April 24, 2016 Posted April 24, 2016 (edited) Maybe you need to do the path substitution to 192.168.2.1 then.. In your last log, 'Play from HTTP' is on again. Edited April 24, 2016 by xnappo
roywood 5 Posted April 25, 2016 Author Posted April 25, 2016 Maybe you need to do the path substitution to 192.168.2.1 then.. In your last log, 'Play from HTTP' is on again. I think that got it. Would you check for sure. Thanks for all the help. Http://xbmclogs.com/pe2aqt2vf Sent from my XT1254 using Tapatalk 1
Angelblue05 4132 Posted April 25, 2016 Posted April 25, 2016 You can confirm by checking your emby dashboard and just mouseover the Kodi device under active devices, while playing something Sent from my iPhone using Tapatalk 1
roywood 5 Posted April 25, 2016 Author Posted April 25, 2016 You can confirm by checking your emby dashboard and just mouseover the Kodi device under active devices, while playing something Sent from my iPhone using Tapatalk Oh. Learn something new everyday. Thanks so much to you both. Sent from my XT1254 using Tapatalk 2
roywood 5 Posted April 25, 2016 Author Posted April 25, 2016 You can confirm by checking your emby dashboard and just mouseover the Kodi device under active devices, while playing something Sent from my iPhone using Tapatalk Well I may have spoken too soon. The video started buffering. Also, I Moises over kodi in devices and didn't see anything at all. Sent from my XT1254 using Tapatalk
Angelblue05 4132 Posted April 25, 2016 Posted April 25, 2016 You may have to adjust your Kodi advanced settings for better performance. The add-on only provides the path/url to play, Kodi is still in charge of everything that happens at playback. You can probably google the solution Sent from my iPhone using Tapatalk 1
xnappo 1611 Posted April 25, 2016 Posted April 25, 2016 Yep - from your last log it is finally direct playing - so whatever stuttering you are getting now is unrelated to the Addon. Glad you got it going!
