pünktchen 1411 Posted April 21, 2016 Posted April 21, 2016 By what app version and on which devices, the VLC option shouldn't be there anymore???
Spaceboy 2573 Posted April 22, 2016 Posted April 22, 2016 When I asked the question before to ebr he said only devices using the prior version of Android will still have vlc options. My case was a nexus 7
CBers 7554 Posted April 22, 2016 Posted April 22, 2016 Basically, only Amazon devices still have VLC as a player. The Google versions use Exoplayer, which is the built-in player.
pünktchen 1411 Posted April 22, 2016 Author Posted April 22, 2016 I installed v1.74g of the app yesterday on a Tablet with Android 5.0.1 and still have the vlc option (thank god)! That's why i ask.
ebr 16336 Posted April 22, 2016 Posted April 22, 2016 Any device running Android 6.0+ will no longer have VLC as an option and will have the ability to direct stream and bitstream both DTS and DD. 1
benjamoomin 3 Posted April 22, 2016 Posted April 22, 2016 Is it possible to get the vlc option back at all? Or is it not possible. Cheers
ebr 16336 Posted April 22, 2016 Posted April 22, 2016 Is it possible to get the vlc option back at all? Or is it not possible. Cheers Not at this time on the Google platform.
Spaceboy 2573 Posted April 22, 2016 Posted April 22, 2016 Is it possible for the issues caused by the removal of vlc to be looked at? It's made live tv inoperable for those of us not using Emby tv and using android
ebr 16336 Posted April 22, 2016 Posted April 22, 2016 Is it possible for the issues caused by the removal of vlc to be looked at? It's made live tv inoperable for those of us not using Emby tv and using android Let's start fresh and see what we can figure out. Create your live TV issue and send me the log, Then start a new thread telling me you sent it and the Emby user that was logged on.
Spaceboy 2573 Posted April 23, 2016 Posted April 23, 2016 Let's start fresh and see what we can figure out. Create your live TV issue and send me the log, Then start a new thread telling me you sent it and the Emby user that was logged on. done http://emby.media/community/index.php?/topic/34166-live-tv-android-tv/ cheers
raven-au 17 Posted May 2, 2016 Posted May 2, 2016 Is it possible to get the vlc option back at all? Or is it not possible. Cheers I have the VLC option on Android TV 5.1.1, it's enabled, and I have the issues described relating to the new player. So it seems having "the option" doesn't make any difference.
Luke 42243 Posted May 2, 2016 Posted May 2, 2016 I have the VLC option on Android TV 5.1.1, it's enabled, and I have the issues described relating to the new player. So it seems having "the option" doesn't make any difference. Hi, in order to best help you, please see how to report a problem. Thanks.
raven-au 17 Posted May 6, 2016 Posted May 6, 2016 Hi, in order to best help you, please see how to report a problem. Thanks. @@Luke, thanks for the attention and your suggestion. What I've encountered lately has been reported by others elsewhere so I believe there's nothing to be gained by reporting the same problem. I hope they will be worked out in time in the same way as similar problems I've encountered in the past have been. It's just unfortunate that recent updates to (in my case) the Android TV app appear to have introduced regressions. Ian
