joggs 24 Posted April 21, 2016 Posted April 21, 2016 When entering a view/library that is not tv or movie, you can select what view and sort setting to use. This is reset the next time you enter the view/library. I think you usually want to use the same view and sort setting for a specific view, so that should be set by default each time you enter the view/library. 1
ebr 16337 Posted April 21, 2016 Posted April 21, 2016 Really the same as Request: Remember filters (persistent)
