horstepipe 422 Posted April 20, 2016 Posted April 20, 2016 hey This problem seems to be already discussed, but I didn't find a proper solution for it: Actor images and rotten tomatoes rating are not scraped automatically by Emby. I have to refresh the movie and every single actor to make them appear. Is this still a known bug or what can I do to solve it?
Luke 42186 Posted April 20, 2016 Posted April 20, 2016 You've said you're using another program to fetch your metadata, so this right now is just a quirk with that type of setup. 1
horstepipe 422 Posted April 20, 2016 Author Posted April 20, 2016 (edited) ok, thank you... is this problem on your fixing agenda for the near future? Unfortunately Emby is missing a (for me) essential scraping feature: Scraping pictures in original language and plot etc in mine (German) Edited April 20, 2016 by horstepipe
horstepipe 422 Posted April 20, 2016 Author Posted April 20, 2016 You've said you're using another program to fetch your metadata, so this right now is just a quirk with that type of setup. So when I only pre-scrape all the pictures and let Emby scrape the metadata it should work?
horstepipe 422 Posted April 21, 2016 Author Posted April 21, 2016 So when I only pre-scrape all the pictures and let Emby scrape the metadata it should work? yep this works. Just let Emby create the .nfo file then everything works fine
horstepipe 422 Posted May 24, 2016 Author Posted May 24, 2016 (edited) hey @@Luke I'm on current stable release and meanwhile I let Emby fetch all metadata and images. But again I'm having the problem that the rotten tomatoe's rating and oscar nominations only appear when I manually refresh a movie. I'm using the real time monitoring feature, could this be the problem? So I copy the movie on my NAS and a couple of seconds later it's been added to Emby database automatically. Everything is fine except the two mentioned things. Edited May 24, 2016 by horstepipe
