anderbytes 141 Posted April 20, 2016 Posted April 20, 2016 (edited) The subject tells it all. after v5930 I can't scroll the right panel in Reports. So when I explode the Filters or Columns, I can't access the ones who go to the bottom of the list. Edited April 20, 2016 by anderbytes
Happy2Play 9800 Posted April 20, 2016 Posted April 20, 2016 The issues is present in all versions in all browsers right now. 5931, 5942, 5954.24390
Luke 42186 Posted April 20, 2016 Posted April 20, 2016 Yea, sorry, I'm a little slow on the reports section. We accepted a number of community enhancements for them but now unfortunately we're on the hook anytime those enhancements are accidentally affected by other changes.
Jorpd 0 Posted August 11, 2016 Posted August 11, 2016 I'm migrating my server and I need to generate a list of media that has a certain tag in order to ensure they're applied over on the new server. I'm currently unable to do so because of this bug, is there an alternate way I can generate this list? Or is this issue in the works? Thanks
d00zah 152 Posted August 11, 2016 Posted August 11, 2016 @Jorpd, check out item #2 in this post: http://emby.media/community/index.php?/topic/36755-some-css-fixes-tweaks/&do=findComment&comment=345201 IF you don't know how to apply custom CSS: http://localhost:8096/web/dashboardgeneral.html & look under 'Branding'.
anderbytes 141 Posted August 11, 2016 Author Posted August 11, 2016 @@d00zah, I really hope this is not the way fixes will be resolved in Emby. :-/ CSS are not meant to be used as fixes... but for customization.
d00zah 152 Posted August 11, 2016 Posted August 11, 2016 No, @@anderbytes, I'm only suggesting them as a matter of usability, as it beats doing without until a fix is released. Jorpd expressed what I interpreted as an immediate need. This one has been around for a while & is one of several I hope will ultimately be fixed.
anderbytes 141 Posted August 11, 2016 Author Posted August 11, 2016 I understand, but if everyone uses this case fix, nobody will care to follow the real fix, devs won't feel the weight of the bug existence, and our CSS will be bloated forever.
