AlwinHummels 134 Posted February 1, 2014 Posted February 1, 2014 Added som more music genres to git 1
trusselo 225 Posted February 1, 2014 Posted February 1, 2014 so, are these images incorporated into MB now?
Tikuf 663 Posted February 1, 2014 Posted February 1, 2014 @@trusselo Yes. The more we get the better.
Smaky 131 Posted February 3, 2014 Posted February 3, 2014 How long would it take from the images being incorporated to git and MB3 Server to start downloading it? I noticed some of the files I created about a week ago are not yet available for download (for instance, some of those that were merged today... but also some merged several days. E.g. Televisió de Gatalunya, and several others with accented characters... could this be an issue with accented characters in some cases? I created folders using the exact same name in the studios list.
trusselo 225 Posted February 3, 2014 Posted February 3, 2014 (edited) They would be included with the next release of media browser server Edited February 3, 2014 by trusselo
Tikuf 663 Posted February 3, 2014 Posted February 3, 2014 They would be included with the next release of media browser server Not correct. Mb server downloads them from git they should be available immediately @@Smaky if the names are exactly the same in the git text file then they should be downloaded if they are not then it may well be the accented characters.
trusselo 225 Posted February 3, 2014 Posted February 3, 2014 (edited) Really? That's cool. Never would have thought of using git as a type of on-demand file serving service. But at the same time that's exactly what it is Mind--> blown! Sent from my SGH-I337M using Tapatalk Edited February 3, 2014 by trusselo
Smaky 131 Posted February 3, 2014 Posted February 3, 2014 I guess something is not behaving properly... for instance: For France 2 Cinéma, this is how it looks in web client: Then in the master respository the folder for the stuido looks like this: and in the studiothumbs.txt is is listed like this: So everything matches.. but editing the studio and refresing metadata manually bring no thumb, nor trying to download it manually: However, this does not seems to be an accented characters issue as I face the same situation with Imax Film Entertainment and Intandem Films.
Tikuf 663 Posted February 3, 2014 Posted February 3, 2014 (edited) @@Smaky try a force refresh also have a look at the folder in the inb make sure it matches. Edited February 3, 2014 by Tikuf
Smaky 131 Posted February 3, 2014 Posted February 3, 2014 (edited) @@Tikuf by force refresh, I guess you mean this, right? And the folder under C:\Users\XXXX\AppData\Roaming\MediaBrowser-Server\ImagesByName\Studio looks like this... which matches the names in the master... and txt file. Unfortunately, still no go. Hmm.. interesting force refresh worked for IMAX... but not for the other one (with accent) More data... this is what I got while trying to manually download the image for Industrial Light & Magic (ILM) and Konami Corporation Ltd. (Notice it ends with a .) Edited February 3, 2014 by Smaky
Tikuf 663 Posted February 3, 2014 Posted February 3, 2014 (edited) Ok looks like a bug? @@Luke Smaky, Luke is pretty busy with a few changes we are making atm can you post it on git with as much info as you can (screenshots , logs every thing you can think of that may help) It will be well down the list I am afraid. Edited February 3, 2014 by Tikuf
fantaxp7 191 Posted February 3, 2014 Posted February 3, 2014 So since I am using My Channel Logos for WMC to get logos is that blocking the channel logos that I see here from being used? Thanks
Luke 42239 Posted February 3, 2014 Author Posted February 3, 2014 there's probably a bad entry in one of the txt files
bloodtaker 71 Posted February 3, 2014 Posted February 3, 2014 @@fantaxp7 possibly i know in swmc there is a option to use or not use the logos but i am not sure if that applies to mbs 1
Smaky 131 Posted February 4, 2014 Posted February 4, 2014 (edited) I continued to check on all the studios (about 63) I recently added. Only those with special characters (e.g. accents or periods at the end). What kind of information would be useful to narrow this down? I am troubleshooting this on a case by case basis. * ILM: My bad, named the file thumbs.jpg instead of thumb.jpg (fixed) * For Konami Corporation Ltd. - Problem here is the '.' character at the end, the folder gets named without a '.' at the end; I managed to create the folder by means of mkdir "\\?\C:\Folder with Dot.". Lets see if this fixes this one. * For Canal Sur Televisión - this is what the log shows: 2014-02-03 21:02:25.1790 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Studios/Canal Sur Televisión/RemoteImages?type=Thumb&startIndex=0&limit=10 Ip: [::1]:58634. Headers: Connection=keep-alive,Accept=text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8,Accept-Encoding=gzip,deflate,sdch,Accept-Language=en-US,en;q=0.8,es;q=0.6,ja;q=0.4,Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.3; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/32.0.1700.102 Safari/537.36 I noticed calling directly the URL would show this: Not sure how this call will bring the data from git. But it seems special characters are causing an issue. Not sure how to proceed from here. Edited February 4, 2014 by Smaky
Luke 42239 Posted February 4, 2014 Author Posted February 4, 2014 @@Tikuf can you sanitize the text files? Thanks.
Koleckai Silvestri 1154 Posted February 4, 2014 Posted February 4, 2014 I had a problem downloading any image with accents in the studio/network name.
Smaky 131 Posted February 4, 2014 Posted February 4, 2014 Modified my previous post with some additional data.
Luke 42239 Posted February 4, 2014 Author Posted February 4, 2014 remove all the ones with special characters from git for now
Smaky 131 Posted February 7, 2014 Posted February 7, 2014 On some of the studios, I am getting this in the error log: 2014-02-07 02:19:21.0599 Warn - StringMapTypeDeserializer: Property 'studio' does not exist on type 'MediaBrowser.WebDashboard.Api.GetDashboardResource' and the image would not download.
Smaky 131 Posted February 18, 2014 Posted February 18, 2014 Any news on getting the special characters issue fixed? I can do .Net programming so if help is needed I´m up to it.
Tikuf 663 Posted February 18, 2014 Posted February 18, 2014 @@Smaky I don't think it has been looked at yet (there are some big ticket items in front of it). So knock yourself out
Smaky 131 Posted February 18, 2014 Posted February 18, 2014 I guess this may be a way to bring my old programming skills up to (it´s been a few years) so while you tackle with the big ticket stuff I guess I might take a look at this one... how can I start up?
Tikuf 663 Posted February 18, 2014 Posted February 18, 2014 Copy the repo from git, get vs2012 (not sure if c#express will work or not) make your changes then compile and test
Smaky 131 Posted March 21, 2014 Posted March 21, 2014 Have anyone got the time to check on the special characters issue? I have not yet got the time to do it myself.
