ulrick65 30 Posted December 30, 2013 Posted December 30, 2013 I've done a little testing so I think the answer to this question is "Yes" but I want to be sure before I change my backdrops around. When browsing a TV "Season" (not the series level), does MB3 use the backdrops from the Series folder if there are no backdrops in the Season folder? If so, then I assume if I put just one backdrop in the Season folder it will only display that one or will it cycle through the ones in the Series folder too? (I have not tested this out...guess I can give that a shot). Thanks.
Solution Luke 42176 Posted December 30, 2013 Solution Posted December 30, 2013 the client apps decide what they want to display, but i think in the majority of situations, what you described will be true. 1
ulrick65 30 Posted December 30, 2013 Author Posted December 30, 2013 Thanks. Based on some quick testing it seems to be for MBC for sure. I am "redoing" my collection, so this is a good time to delete all the duplicate backdrops in the seasons folders...I never liked having all the duplicate files but I always figured it was necessary (at least it was in the early years of MB I am quite sure).
