Kodi "Default Select Action" problem -FireTV
DarkKniyt (John)
When setting up the shortcuts to my Emby videos, the "Default Select Action" is incorrect.
I select "Add-On - Video Add-On - Emby - Movies - Movies". (Movies being my movie Library in Emby).
The "Default Select Action" shows the path as "ActivateWindow(MusicLibrary,library://video/Emby - ...".
Shouldn't this be VideoLibrary?
What this is causing is for my Movies to be listed not by Title but by, I think, entry number.
Example of my movies list;
108
109
110
etc...
Should be;
2 Guns
3:10 to Yuma
The 5th Wave
etc...
Any help would be appreciated! Thanks!
Angelblue05
Replace music library with 10025. This is the window ID for the video library.
Sent from my iPhone using Tapatalk
DarkKniyt (John)
Could you tell me how you do this? Thanks.
Angelblue05
Type it in?... :) ActivateWindow(10025,library://....
DarkKniyt (John)
There's no place to "Type" it in that I can find??
Angelblue05
Whih skin are you using?
DarkKniyt (John)
Aeon Nox
Guest
