oldschool 16 Posted April 19, 2016 Author Posted April 19, 2016 I unchecked the NFO inside MCM yesterday and I woke up to the same metadata inside Emby, so maybe that will help out things. I added the XML saver plugin to Emby, so hopefully that means everything will be sorted today. I'll update this thread if I run into more problems. Thanks for your help Happy2Play!
oldschool 16 Posted April 20, 2016 Author Posted April 20, 2016 Some metadata was reset again this morning.
Luke 42301 Posted April 20, 2016 Posted April 20, 2016 I would just make your life easier and pick one piece of software to manage your metadata
Happy2Play 9814 Posted April 20, 2016 Posted April 20, 2016 Do you have a xml and nfo file present? Do both of them have the same metadata when changed? If neither program is being refreshed or re-fetching, then the only difference can be a difference in info in the xml and nfo.
oldschool 16 Posted April 20, 2016 Author Posted April 20, 2016 Do you have a xml and nfo file present? Do both of them have the same metadata when changed? If neither program is being refreshed or re-fetching, then the only difference can be a difference in info in the xml and nfo. It looks like both are being created. I made a change to the metadata and both of them were recreated when I change the info inside Emby. It looks like the size is 1KB off between the nfo and the xml when I make a change to the metadata inside Emby.
