tre4b 4 Posted April 16, 2016 Posted April 16, 2016 Another Emby strange thing. When using LiveTV with HDHomerun and schedules direct. First thing in the morning the TV is never available. If I go into LiveTV i just get the recorded programs. HDHomeRUns app is fine and works but not Emby. Later in the day Emby will be back to usual and working throughout the rest of the time. I have tried ramping the schedule refresh up to once every two hours, this did not fix it though so I'm looking for any other ideas. Trev
Luke 42242 Posted April 16, 2016 Posted April 16, 2016 Please see how to report a problem: http://emby.media/community/index.php?/topic/790-how-to-report-a-problem/&do=findComment&comment=23949 Thanks.
tre4b 4 Posted April 19, 2016 Author Posted April 19, 2016 https://onedrive.live.com/redir?resid=50D4C3762CCD2008!385825&authkey=!AALp3WGUU3mOu8U&ithint=file%2ctxt This is the log for the day. Shows errors before 5am because the network is switched off.
Luke 42242 Posted April 19, 2016 Posted April 19, 2016 Your log shows http requests to your HDHR tuner that are failing.
tre4b 4 Posted April 22, 2016 Author Posted April 22, 2016 Ah, so it is looking for the HDHR then not putting up the guide because it cannot see a service to support it? Would that be the right thinking? The interesting thing is that when this happens I use the HD Homerun app and that connects and sees the Live TV just fine. This suggests that the FireTV is seeing the box okay but the QNAP server with my Emby on it may not be. I'll have a poke through the networking. The Emby box is on the main router but the HDHR is on the switch, it could be something is getting between them as the FireTV is also on the switch and not the router.
Luke 42242 Posted April 23, 2016 Posted April 23, 2016 It's not really the same unfortunately. The mechanism we use to get the channel list is different than what the hdhomerun app uses. I would ensure the HDHR firmware is up to date, then try again. Apart from that, your HDHR is returning 503 errors, so until those are resolved you're going to continue to have problems.
tre4b 4 Posted April 24, 2016 Author Posted April 24, 2016 Hi Luke, I checked the firmware and it's the most up to date already so not that. Next to try I will keep the switch and HDHomerun live through the night. Maybe the downtime on those is causing more issues than it is solving. I originally made them go off for a while to essentially reboot them once a day but didn't want to be rebooting the server. Maybe the down time causes Emby to stuggle a bit when they come on line?
Luke 42242 Posted April 25, 2016 Posted April 25, 2016 No, the issue isn't that the HDHR is offline, the issue is that it's returning error responses.
