foghat 65 Posted April 16, 2016 Posted April 16, 2016 Hi, Cinema mode has stopped working for me. It has been a bit since I've watched a movie, so not sure when it happened. This is happening on 2 different devices. I have the prompt enabled and am also using a custom into. The prompt will appear and the custom intro will play, but no trailers. If I remove the custom intro then no prompt and nothing plays before the movie. I've attached a log. As far as I can tell it is seeing some trailers - not sure why they don't play. I've tried completely resetting the database. When prompted, I do not select Direct Play, I take the default 'add-on' selection. Anyone have any suggestions? server-63596275199 - Copy.txt
Angelblue05 4132 Posted April 16, 2016 Posted April 16, 2016 Your kodi log, enable debug in the add-on settings > advanced. Playback a movie, post that Kodi log, thanks. Sent from my iPhone using Tapatalk
foghat 65 Posted April 16, 2016 Author Posted April 16, 2016 Hi, I did a bit more digging on this. Turns out I can't play trailers via the web interface either so problem seems to be at the server level. I will post in the server section, but the 2 transcode logs that get created (I have it set to play 2 trailers) are showing it is trying to play trailers that are not even showing in my trailers section. It I try manually use the trailer url in the log, it does not work.
