Darkjeje 11 Posted July 25, 2016 Author Posted July 25, 2016 I'm in stereo. But why the Emby is transcoding a movie that it was directplay few month ago ?
RanmaCanada 502 Posted July 30, 2016 Posted July 30, 2016 (edited) If I may, it appears that this box has issues with VLC and MX player. Kodi has apparently resolved most issues with the box. http://forum.kodi.tv/showthread.php?tid=221916 The box is only available in France so support is extremely limited. If you can use external players, I would suggest you use it and try Kodi or SPMC Google translate Si je peux , il semble que cette boîte a des problèmes avec VLC et MX lecteur . Kodi a apparemment résolu la plupart des problèmes avec la boîte . http://forum.kodi.tv/showthread.php?tid=221916 La boîte est seulement disponible en France pour le soutien est extrêmement limité. Si vous pouvez utiliser des joueurs externes , je vous suggère de l'utiliser et essayez Kodi ou SPMC Edited July 30, 2016 by RanmaCanada
Darkjeje 11 Posted August 23, 2016 Author Posted August 23, 2016 (edited) @@RanmaCanada Yes It's true, this box is not perfect, but she is better than 1 year ago. I don't understand why Emby doesn't directplay my movie whereas with vlc of the box (DLNA) is OK. When I use vlc in Emby for android TV the movie is transcoding, when I use Emby for Android TV without VLC, the movie is transcoding, but when I use the appli VLC the movie is directplay with DLNA whitout problem. So for me the problem is the detection of Emby which don't know that the freebox is ok to directplay. No ? My log : http://192.168.1.6:8096/emby/videos/2ae56a1efe0aa11c8e31acaed2582b54/stream.mkv?DeviceId=db4b864504eb9c15&MediaSourceId=2ae56a1efe0aa11c8e31acaed2582b54&VideoCodec=h264&AudioCodec=aac,mp3&AudioStreamIndex=1&VideoBitrate=39872000&AudioBitrate=128000&MaxAudioChannels=2&Level=51&Profile=high&PlaySessionId=9f2fffc663dd430c99422dc22ec1e4b0&api_key=f281567512fd41f4b435cc819441b288&CopyTimestamps=true&ForceLiveStream=false {"Protocol":"File","Id":"2ae56a1efe0aa11c8e31acaed2582b54","Path":"/volume1/Film/Film (L Ã Z)/Le Flingueur (2011)/Le Flingueur (2011).ts","Type":"Default","Container":"ts","Name":"480P/H264/MP2","ETag":"ab74babe4cda34a7bc7a06276a84e4d0","RunTimeTicks":49823280000,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","TimeBase":"1/90000","CodecTimeBase":"1/50","NalLengthSize":"0","IsInterlaced":false,"IsAVC":false,"BitRate":2080469,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":576,"Width":720,"AverageFrameRate":25,"RealFrameRate":25,"Profile":"Main","Type":"Video","AspectRatio":"20:11","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":30,"IsAnamorphic":false},{"Codec":"mp2","Language":"fra","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"Fra MP2 stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":2080469,"RequiredHttpHeaders":{}} /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -fflags +genpts -i file:"/volume1/Film/Film (L Ã Z)/Le Flingueur (2011)/Le Flingueur (2011).ts" -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -force_key_frames "expr:gte(t,n_forced*5)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1280)/2)*2:trunc(ow/dar/2)*2" -copyts -avoid_negative_ts disabled -start_at_zero -pix_fmt yuv420p -preset superfast -crf 23 -b:v 2080469 -maxrate 2080469 -bufsize 4160938 -vsync -1 -profile:v high -level 51 -map_metadata -1 -threads 0 -codec:a:0 aac -strict experimental -ac 2 -ab 128000 -af "aresample=async=1" -y "/var/packages/EmbyServer/target/var/transcoding-temp/835efdeef8608bf50086ad0e01ab02ed.mkv" ffmpeg version 3.1.1-static http://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.4.0 (Debian 5.4.0-4) 20160609 configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libwebp --enable-libspeex --enable-libvorbis --enable-libvpx --enable-libfreetype --enable-fontconfig --enable-libxvid --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvo-amrwbenc --enable-gray --enable-libopenjpeg --enable-libopus --enable-libass --enable-gnutls --enable-libvidstab --enable-libsoxr --enable-frei0r --enable-libfribidi --disable-indev=sndio --disable-outdev=sndio --enable-librtmp --enable-libmfx --enable-libzimg --cc=gcc libavutil 55. 28.100 / 55. 28.100 libavcodec 57. 48.101 / 57. 48.101 libavformat 57. 41.100 / 57. 41.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 47.100 / 6. 47.100 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 1.100 / 2. 1.100 libpostproc 54. 0.100 / 54. 0.100 Input #0, mpegts, from 'file:/volume1/Film/Film (L Ã Z)/Le Flingueur (2011)/Le Flingueur (2011).ts': Duration: 01:23:02.33, start: 0.200000, bitrate: 2080 kb/s Program 1 Stream #0:0[0x80c]: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p(tv), 720x576 [SAR 16:11 DAR 20:11], 25 fps, 25 tbr, 90k tbn, 50 tbc Stream #0:1[0x80d](fra): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16p, 192 kb/s [libx264 @ 0xa941120] using SAR=3974/3983 [libx264 @ 0xa941120] using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 [libx264 @ 0xa941120] profile High, level 5.1 [libx264 @ 0xa941120] 264 - core 148 r276 3f5ed56 - H.264/MPEG-4 AVC codec - Copyleft 2003-2016 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x3:0x3 me=dia subme=1 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=6 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=0 rc=crf mbtree=0 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=2080 vbv_bufsize=4160 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 pb_ratio=1.30 aq=1:1.00 [matroska @ 0xa93f920] Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead. Last message repeated 1 times Output #0, matroska, to '/var/packages/EmbyServer/target/var/transcoding-temp/835efdeef8608bf50086ad0e01ab02ed.mkv': Metadata: encoder : Lavf57.41.100 Stream #0:0: Video: h264 (libx264) (H264 / 0x34363248), yuv420p, 1046x574 [SAR 5740:5753 DAR 20:11], q=-1--1, 2080 kb/s, 25 fps, 1k tbn, 25 tbc Metadata: encoder : Lavc57.48.101 libx264 Side data: cpb: bitrate max/min/avg: 2080000/0/2080000 buffer size: 4160000 vbv_delay: -1 Stream #0:1: Audio: aac (LC) ([255][0][0][0] / 0x00FF), 48000 Hz, stereo, fltp, 128 kb/s Metadata: encoder : Lavc57.48.101 aac Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (mp2 (native) -> aac (native)) Press [q] to stop, [?] for help [h264 @ 0xaa12a40] Reinit context to 720x576, pix_fmt: yuv420p frame= 12 fps=0.0 q=0.0 size= 0kB time=00:00:00.08 bitrate= 0.0kbits/s speed=0.171x [h264 @ 0xa9b7120] Increasing reorder buffer to 2 frame= 16 fps= 15 q=21.0 size= 41kB time=00:00:00.34 bitrate= 991.7kbits/s speed=0.323x frame= 22 fps= 14 q=22.0 size= 113kB time=00:00:00.61 bitrate=1501.9kbits/s speed=0.393x frame= 29 fps= 14 q=22.0 size= 198kB time=00:00:00.85 bitrate=1904.0kbits/s speed=0.408x frame= 35 fps= 13 q=22.0 size= 274kB time=00:00:01.11 bitrate=2018.5kbits/s speed=0.425x frame= 42 fps= 13 q=22.0 size= 363kB time=00:00:01.36 bitrate=2179.2kbits/s speed=0.435x frame= 48 fps= 13 q=23.0 size= 447kB time=00:00:01.62 bitrate=2255.4kbits/s speed=0.444x frame= 54 fps= 13 q=24.0 size= 532kB time=00:00:01.89 bitrate=2297.8kbits/s speed=0.453x frame= 61 fps= 13 q=25.0 size= 652kB time=00:00:02.13 bitrate=2504.2kbits/s speed=0.454x frame= 67 fps= 13 q=25.0 size= 765kB time=00:00:02.41 bitrate=2601.1kbits/s speed=0.463x frame= 73 fps= 13 q=26.0 size= 873kB time=00:00:02.66 bitrate=2683.2kbits/s speed=0.466x frame= 80 fps= 13 q=28.0 size= 992kB time=00:00:02.92 bitrate=2781.8kbits/s speed=0.469x frame= 87 fps= 13 q=30.0 size= 1096kB time=00:00:03.22 bitrate=2787.7kbits/s speed=0.477x frame= 93 fps= 13 q=30.0 size= 1172kB time=00:00:03.45 bitrate=2778.6kbits/s speed=0.476x frame= 100 fps= 13 q=32.0 size= 1258kB time=00:00:03.69 bitrate=2793.3kbits/s speed=0.475x frame= 106 fps= 13 q=30.0 size= 1324kB time=00:00:03.99 bitrate=2718.6kbits/s speed=0.481x frame= 112 fps= 13 q=28.0 size= 1386kB time=00:00:04.22 bitrate=2688.1kbits/s speed=0.48x frame= 119 fps= 13 q=26.0 size= 1447kB time=00:00:04.48 bitrate=2646.4kbits/s speed=0.482x frame= 126 fps= 13 q=28.0 size= 1513kB time=00:00:04.77 bitrate=2594.5kbits/s speed=0.486x frame= 133 fps= 13 q=25.0 size= 1557kB time=00:00:05.05 bitrate=2523.0kbits/s speed=0.488x frame= 141 fps= 13 q=23.0 size= 1612kB time=00:00:05.33 bitrate=2476.5kbits/s speed=0.489x frame= 148 fps= 13 q=25.0 size= 1656kB time=00:00:05.61 bitrate=2417.8kbits/s speed=0.492x frame= 155 fps= 13 q=23.0 size= 1702kB time=00:00:05.91 bitrate=2359.7kbits/s speed=0.496x frame= 162 fps= 13 q=25.0 size= 1750kB time=00:00:06.20 bitrate=2308.9kbits/s speed=0.499x frame= 170 fps= 13 q=25.0 size= 1803kB time=00:00:06.50 bitrate=2270.3kbits/s speed=0.502x frame= 177 fps= 13 q=23.0 size= 1864kB time=00:00:06.80 bitrate=2243.7kbits/s speed=0.505x frame= 186 fps= 13 q=25.0 size= 1917kB time=00:00:07.12 bitrate=2203.9kbits/s speed=0.51x frame= 194 fps= 13 q=24.0 size= 1951kB time=00:00:07.46 bitrate=2141.0kbits/s speed=0.516x frame= 203 fps= 14 q=23.0 size= 1988kB time=00:00:07.85 bitrate=2074.6kbits/s speed=0.523x frame= 213 fps= 14 q=21.0 size= 2021kB time=00:00:08.21 bitrate=2015.3kbits/s speed=0.529x frame= 222 fps= 14 q=22.0 size= 2061kB time=00:00:08.61 bitrate=1959.2kbits/s speed=0.537x frame= 232 fps= 14 q=23.0 size= 2094kB time=00:00:08.98 bitrate=1909.9kbits/s speed=0.542x frame= 243 fps= 14 q=23.0 size= 2136kB time=00:00:09.40 bitrate=1860.0kbits/s speed=0.551x frame= 252 fps= 14 q=22.0 size= 2169kB time=00:00:09.81 bitrate=1810.9kbits/s speed=0.558x frame= 263 fps= 15 q=24.0 size= 2228kB time=00:00:10.13 bitrate=1801.1kbits/s speed=0.561x frame= 272 fps= 15 q=21.0 size= 2264kB time=00:00:10.53 bitrate=1760.2kbits/s speed=0.566x frame= 281 fps= 15 q=21.0 size= 2322kB time=00:00:10.90 bitrate=1745.0kbits/s speed=0.571x frame= 291 fps= 15 q=20.0 size= 2342kB time=00:00:11.24 bitrate=1706.3kbits/s speed=0.573x frame= 301 fps= 15 q=18.0 size= 2350kB time=00:00:11.67 bitrate=1649.5kbits/s speed=0.58x frame= 312 fps= 15 q=19.0 size= 2363kB time=00:00:12.09 bitrate=1600.2kbits/s speed=0.586x frame= 324 fps= 15 q=21.0 size= 2381kB time=00:00:12.63 bitrate=1544.2kbits/s speed=0.597x frame= 336 fps= 16 q=20.0 size= 2427kB time=00:00:13.05 bitrate=1522.9kbits/s speed=0.602x frame= 349 fps= 16 q=20.0 size= 2468kB time=00:00:13.59 bitrate=1487.9kbits/s speed=0.613x frame= 362 fps= 16 q=20.0 size= 2506kB time=00:00:14.08 bitrate=1457.8kbits/s speed=0.62x frame= 375 fps= 16 q=18.0 size= 2542kB time=00:00:14.61 bitrate=1425.1kbits/s speed=0.63x frame= 388 fps= 16 q=20.0 size= 2599kB time=00:00:15.14 bitrate=1405.7kbits/s speed=0.639x frame= 401 fps= 17 q=20.0 size= 2633kB time=00:00:15.63 bitrate=1379.1kbits/s speed=0.646x frame= 414 fps= 17 q=20.0 size= 2673kB time=00:00:16.17 bitrate=1354.0kbits/s speed=0.654x frame= 426 fps= 17 q=23.0 size= 2721kB time=00:00:16.66 bitrate=1337.9kbits/s speed=0.66x frame= 440 fps= 17 q=19.0 size= 2748kB time=00:00:17.19 bitrate=1309.1kbits/s speed=0.668x frame= 453 fps= 17 q=19.0 size= 2759kB time=00:00:17.72 bitrate=1274.8kbits/s speed=0.676x frame= 466 fps= 17 q=19.0 size= 2768kB time=00:00:18.26 bitrate=1241.8kbits/s speed=0.683x frame= 478 fps= 18 q=19.0 size= 2777kB time=00:00:18.73 bitrate=1214.5kbits/s speed=0.687x frame= 488 fps= 18 q=19.0 size= 2792kB time=00:00:19.11 bitrate=1196.8kbits/s speed=0.688x frame= 495 fps= 18 q=22.0 size= 2823kB time=00:00:19.56 bitrate=1182.3kbits/s speed=0.692x frame= 503 fps= 17 q=22.0 size= 2888kB time=00:00:19.79 bitrate=1195.0kbits/s speed=0.688x frame= 509 fps= 17 q=23.0 size= 2971kB time=00:00:20.05 bitrate=1213.6kbits/s speed=0.684x frame= 517 fps= 17 q=26.0 size= 3095kB time=00:00:20.39 bitrate=1243.4kbits/s speed=0.683x frame= 528 fps= 17 q=23.0 size= 3166kB time=00:00:20.80 bitrate=1246.8kbits/s speed=0.685x frame= 539 fps= 17 q=23.0 size= 3203kB time=00:00:21.27 bitrate=1233.6kbits/s speed=0.689x frame= 549 fps= 17 q=23.0 size= 3271kB time=00:00:21.67 bitrate=1236.3kbits/s speed=0.69x frame= 559 fps= 18 q=25.0 size= 3347kB time=00:00:22.10 bitrate=1240.7kbits/s speed=0.693x frame= 567 fps= 17 q=25.0 size= 3406kB time=00:00:22.37 bitrate=1246.7kbits/s speed=0.69x frame= 575 fps= 17 q=25.0 size= 3455kB time=00:00:22.72 bitrate=1245.8kbits/s speed=0.69x frame= 585 fps= 17 q=23.0 size= 3522kB time=00:00:23.10 bitrate=1248.7kbits/s speed=0.691x frame= 597 fps= 18 q=23.0 size= 3598kB time=00:00:23.57 bitrate=1250.2kbits/s speed=0.694x frame= 609 fps= 18 q=23.0 size= 3680kB time=00:00:24.06 bitrate=1252.9kbits/s speed=0.698x frame= 621 fps= 18 q=22.0 size= 3763kB time=00:00:24.53 bitrate=1256.6kbits/s speed=0.702x frame= 633 fps= 18 q=21.0 size= 3854kB time=00:00:25.02 bitrate=1261.6kbits/s speed=0.706x frame= 646 fps= 18 q=24.0 size= 3976kB time=00:00:25.53 bitrate=1275.5kbits/s speed=0.71x frame= 655 fps= 18 q=25.0 size= 4034kB time=00:00:25.92 bitrate=1275.0kbits/s speed=0.71x frame= 663 fps= 18 q=26.0 size= 4110kB time=00:00:26.21 bitrate=1284.2kbits/s speed=0.708x frame= 675 fps= 18 q=25.0 size= 4196kB time=00:00:26.73 bitrate=1286.1kbits/s speed=0.712x frame= 687 fps= 18 q=25.0 size= 4298kB time=00:00:27.15 bitrate=1296.3kbits/s speed=0.714x frame= 698 fps= 18 q=24.0 size= 4395kB time=00:00:27.64 bitrate=1302.1kbits/s speed=0.717x frame= 710 fps= 18 q=25.0 size= 4505kB time=00:00:28.07 bitrate=1314.6kbits/s speed=0.719x frame= 720 fps= 18 q=26.0 size= 4597kB time=00:00:28.50 bitrate=1321.1kbits/s speed=0.72x frame= 732 fps= 18 q=26.0 size= 4714kB time=00:00:28.97 bitrate=1333.1kbits/s speed=0.723x frame= 743 fps= 18 q=22.0 size= 4830kB time=00:00:29.41 bitrate=1345.1kbits/s speed=0.725x frame= 755 fps= 18 q=25.0 size= 4924kB time=00:00:29.93 bitrate=1347.7kbits/s speed=0.728x frame= 767 fps= 18 q=25.0 size= 5032kB time=00:00:30.42 bitrate=1354.9kbits/s speed=0.731x frame= 779 fps= 18 q=25.0 size= 5113kB time=00:00:30.87 bitrate=1356.8kbits/s speed=0.733x frame= 790 fps= 19 q=24.0 size= 5190kB time=00:00:31.29 bitrate=1358.4kbits/s speed=0.734x frame= 801 fps= 19 q=22.0 size= 5265kB time=00:00:31.76 bitrate=1357.7kbits/s speed=0.736x frame= 813 fps= 19 q=23.0 size= 5350kB time=00:00:32.21 bitrate=1360.4kbits/s speed=0.738x frame= 823 fps= 19 q=21.0 size= 5422kB time=00:00:32.61 bitrate=1361.8kbits/s speed=0.739x frame= 834 fps= 19 q=23.0 size= 5490kB time=00:00:33.06 bitrate=1360.0kbits/s speed=0.74x frame= 846 fps= 19 q=23.0 size= 5559kB time=00:00:33.55 bitrate=1357.1kbits/s speed=0.742x frame= 858 fps= 19 q=23.0 size= 5630kB time=00:00:34.02 bitrate=1355.5kbits/s speed=0.743x frame= 870 fps= 19 q=23.0 size= 5704kB time=00:00:34.51 bitrate=1353.7kbits/s speed=0.745x frame= 880 fps= 19 q=24.0 size= 5798kB time=00:00:34.94 bitrate=1359.2kbits/s speed=0.746x frame= 893 fps= 19 q=21.0 size= 5890kB time=00:00:35.41 bitrate=1362.5kbits/s speed=0.748x frame= 903 fps= 19 q=25.0 size= 5970kB time=00:00:35.81 bitrate=1365.5kbits/s speed=0.748x frame= 913 fps= 19 q=22.0 size= 6040kB time=00:00:36.24 bitrate=1365.0kbits/s speed=0.749x frame= 923 fps= 19 q=22.0 size= 6127kB time=00:00:36.65 bitrate=1369.6kbits/s speed=0.75x frame= 934 fps= 19 q=23.0 size= 6223kB time=00:00:37.07 bitrate=1374.8kbits/s speed=0.751x frame= 944 fps= 19 q=25.0 size= 6301kB time=00:00:37.46 bitrate=1377.9kbits/s speed=0.751x frame= 953 fps= 19 q=25.0 size= 6377kB time=00:00:37.82 bitrate=1381.2kbits/s speed=0.75x frame= 963 fps= 19 q=24.0 size= 6442kB time=00:00:38.25 bitrate=1379.7kbits/s speed=0.751x frame= 975 fps= 19 q=22.0 size= 6512kB time=00:00:38.69 bitrate=1378.5kbits/s speed=0.752x frame= 987 fps= 19 q=22.0 size= 6568kB time=00:00:39.16 bitrate=1373.8kbits/s speed=0.754x frame= 998 fps= 19 q=25.0 size= 6641kB time=00:00:39.59 bitrate=1373.9kbits/s speed=0.755x frame= 1008 fps= 19 q=21.0 size= 6727kB time=00:00:40.00 bitrate=1377.7kbits/s speed=0.755x frame= 1019 fps= 19 q=25.0 size= 6812kB time=00:00:40.47 bitrate=1378.8kbits/s speed=0.757x frame= 1028 fps= 19 q=29.0 size= 7001kB time=00:00:40.85 bitrate=1403.8kbits/s speed=0.757x frame= 1031 fps= 19 q=-1.0 Lsize= 7310kB time=00:00:41.16 bitrate=1454.9kbits/s speed=0.754x video:6646kB audio:643kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.297147% [libx264 @ 0xa941120] frame I:14 Avg QP:15.78 size: 27315 [libx264 @ 0xa941120] frame P:363 Avg QP:17.07 size: 11752 [libx264 @ 0xa941120] frame B:654 Avg QP:18.36 size: 3297 [libx264 @ 0xa941120] consecutive B-frames: 12.0% 8.3% 5.5% 74.1% [libx264 @ 0xa941120] mb I I16..4: 41.2% 29.5% 29.3% [libx264 @ 0xa941120] mb P I16..4: 16.2% 15.3% 3.5% P16..4: 35.6% 0.0% 0.0% 0.0% 0.0% skip:29.4% [libx264 @ 0xa941120] mb B I16..4: 1.3% 1.0% 0.1% B16..8: 19.1% 0.0% 0.0% direct:10.3% skip:68.1% L0:38.5% L1:46.1% BI:15.5% [libx264 @ 0xa941120] 8x8 transform intra:42.2% inter:47.6% [libx264 @ 0xa941120] coded y,uvDC,uvAC intra: 38.7% 50.7% 21.4% inter: 11.0% 15.5% 0.5% [libx264 @ 0xa941120] i16 v,h,dc,p: 62% 24% 6% 8% [libx264 @ 0xa941120] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 27% 21% 16% 6% 5% 7% 5% 8% 6% [libx264 @ 0xa941120] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 28% 31% 11% 5% 4% 5% 5% 5% 5% [libx264 @ 0xa941120] i8c dc,h,v,p: 41% 26% 23% 10% [libx264 @ 0xa941120] Weighted P-Frames: Y:7.4% UV:5.2% [libx264 @ 0xa941120] kb/s:1318.71 [aac @ 0xa969400] Qavg: 465.863 Then I to make something to help you to find the problem? Thank you, Jérémy Edited August 23, 2016 by Darkjeje
Darkjeje 11 Posted August 23, 2016 Author Posted August 23, 2016 Is there an option on the server to force the directplay on a particular client ? Is it planned to add this option?
ebr 16337 Posted August 23, 2016 Posted August 23, 2016 What version of the app are you using? I'm not sure why that item is transcoding unless maybe it is to make it seekable (which the Google player cannot do with a .ts file). Still, I would expect it to direct stream with VLC. If you can play that item then send a log with the app and come back here and tell me what time you did that and what item you played and the name of the Emby user that was logged on, I may be able to tell.
ebr 16337 Posted August 23, 2016 Posted August 23, 2016 Oh wait - the server may be limiting the audio bitrate to 128 and that audio sample rate is 192. What version of the server?
Darkjeje 11 Posted August 24, 2016 Author Posted August 24, 2016 Hello ebr, Thank you for your answer. The version of my server is 3.1.117.0 beta. I tested again at 7h41 AM Paris with the login HDTV. Let me know if you need anything. Jérémy
ebr 16337 Posted August 24, 2016 Posted August 24, 2016 Hello ebr, Thank you for your answer. The version of my server is 3.1.117.0 beta. I tested again at 7h41 AM Paris with the login HDTV. Let me know if you need anything. Jérémy You didn't say what version the app was. Did you send a log with the "Send Logs" button in the app? I don't see one. I do think it may be the bitrate of the mp2 audio that is causing the transcoding.
Darkjeje 11 Posted August 24, 2016 Author Posted August 24, 2016 (edited) You didn't say what version the app was. Did you send a log with the "Send Logs" button in the app? I don't see one. Sorry I forgot to sand the log. I tested again at 6h43 PM, my version is up to date is 1.2.31g. I do think it may be the bitrate of the mp2 audio that is causing the transcoding. If it that, I can do or you can do anything to resolve this problem ? Edited August 24, 2016 by Darkjeje
ebr 16337 Posted August 24, 2016 Posted August 24, 2016 I do believe it is the audio sample rate. Right now that is a limitation being imposed by the server but we will look at it in the future.
Luke 42244 Posted August 24, 2016 Posted August 24, 2016 @@RanmaCanada Yes It's true, this box is not perfect, but she is better than 1 year ago. I don't understand why Emby doesn't directplay my movie whereas with vlc of the box (DLNA) is OK. When I use vlc in Emby for android TV the movie is transcoding, when I use Emby for Android TV without VLC, the movie is transcoding, but when I use the appli VLC the movie is directplay with DLNA whitout problem. So for me the problem is the detection of Emby which don't know that the freebox is ok to directplay. No ? My log : http://192.168.1.6:8096/emby/videos/2ae56a1efe0aa11c8e31acaed2582b54/stream.mkv?DeviceId=db4b864504eb9c15&MediaSourceId=2ae56a1efe0aa11c8e31acaed2582b54&VideoCodec=h264&AudioCodec=aac,mp3&AudioStreamIndex=1&VideoBitrate=39872000&AudioBitrate=128000&MaxAudioChannels=2&Level=51&Profile=high&PlaySessionId=9f2fffc663dd430c99422dc22ec1e4b0&api_key=f281567512fd41f4b435cc819441b288&CopyTimestamps=true&ForceLiveStream=false {"Protocol":"File","Id":"2ae56a1efe0aa11c8e31acaed2582b54","Path":"/volume1/Film/Film (L Ã Z)/Le Flingueur (2011)/Le Flingueur (2011).ts","Type":"Default","Container":"ts","Name":"480P/H264/MP2","ETag":"ab74babe4cda34a7bc7a06276a84e4d0","RunTimeTicks":49823280000,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","TimeBase":"1/90000","CodecTimeBase":"1/50","NalLengthSize":"0","IsInterlaced":false,"IsAVC":false,"BitRate":2080469,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":576,"Width":720,"AverageFrameRate":25,"RealFrameRate":25,"Profile":"Main","Type":"Video","AspectRatio":"20:11","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":30,"IsAnamorphic":false},{"Codec":"mp2","Language":"fra","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"Fra MP2 stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":2080469,"RequiredHttpHeaders":{}} /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -fflags +genpts -i file:"/volume1/Film/Film (L Ã Z)/Le Flingueur (2011)/Le Flingueur (2011).ts" -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -force_key_frames "expr:gte(t,n_forced*5)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1280)/2)*2:trunc(ow/dar/2)*2" -copyts -avoid_negative_ts disabled -start_at_zero -pix_fmt yuv420p -preset superfast -crf 23 -b:v 2080469 -maxrate 2080469 -bufsize 4160938 -vsync -1 -profile:v high -level 51 -map_metadata -1 -threads 0 -codec:a:0 aac -strict experimental -ac 2 -ab 128000 -af "aresample=async=1" -y "/var/packages/EmbyServer/target/var/transcoding-temp/835efdeef8608bf50086ad0e01ab02ed.mkv" ffmpeg version 3.1.1-static http://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.4.0 (Debian 5.4.0-4) 20160609 configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libwebp --enable-libspeex --enable-libvorbis --enable-libvpx --enable-libfreetype --enable-fontconfig --enable-libxvid --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvo-amrwbenc --enable-gray --enable-libopenjpeg --enable-libopus --enable-libass --enable-gnutls --enable-libvidstab --enable-libsoxr --enable-frei0r --enable-libfribidi --disable-indev=sndio --disable-outdev=sndio --enable-librtmp --enable-libmfx --enable-libzimg --cc=gcc libavutil 55. 28.100 / 55. 28.100 libavcodec 57. 48.101 / 57. 48.101 libavformat 57. 41.100 / 57. 41.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 47.100 / 6. 47.100 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 1.100 / 2. 1.100 libpostproc 54. 0.100 / 54. 0.100 Input #0, mpegts, from 'file:/volume1/Film/Film (L Ã Z)/Le Flingueur (2011)/Le Flingueur (2011).ts': Duration: 01:23:02.33, start: 0.200000, bitrate: 2080 kb/s Program 1 Stream #0:0[0x80c]: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p(tv), 720x576 [SAR 16:11 DAR 20:11], 25 fps, 25 tbr, 90k tbn, 50 tbc Stream #0:1[0x80d](fra): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16p, 192 kb/s [libx264 @ 0xa941120] using SAR=3974/3983 [libx264 @ 0xa941120] using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 [libx264 @ 0xa941120] profile High, level 5.1 [libx264 @ 0xa941120] 264 - core 148 r276 3f5ed56 - H.264/MPEG-4 AVC codec - Copyleft 2003-2016 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x3:0x3 me=dia subme=1 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=6 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=0 rc=crf mbtree=0 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=2080 vbv_bufsize=4160 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 pb_ratio=1.30 aq=1:1.00 [matroska @ 0xa93f920] Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead. Last message repeated 1 times Output #0, matroska, to '/var/packages/EmbyServer/target/var/transcoding-temp/835efdeef8608bf50086ad0e01ab02ed.mkv': Metadata: encoder : Lavf57.41.100 Stream #0:0: Video: h264 (libx264) (H264 / 0x34363248), yuv420p, 1046x574 [SAR 5740:5753 DAR 20:11], q=-1--1, 2080 kb/s, 25 fps, 1k tbn, 25 tbc Metadata: encoder : Lavc57.48.101 libx264 Side data: cpb: bitrate max/min/avg: 2080000/0/2080000 buffer size: 4160000 vbv_delay: -1 Stream #0:1: Audio: aac (LC) ([255][0][0][0] / 0x00FF), 48000 Hz, stereo, fltp, 128 kb/s Metadata: encoder : Lavc57.48.101 aac Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (mp2 (native) -> aac (native)) Press [q] to stop, [?] for help [h264 @ 0xaa12a40] Reinit context to 720x576, pix_fmt: yuv420p frame= 12 fps=0.0 q=0.0 size= 0kB time=00:00:00.08 bitrate= 0.0kbits/s speed=0.171x [h264 @ 0xa9b7120] Increasing reorder buffer to 2 frame= 16 fps= 15 q=21.0 size= 41kB time=00:00:00.34 bitrate= 991.7kbits/s speed=0.323x frame= 22 fps= 14 q=22.0 size= 113kB time=00:00:00.61 bitrate=1501.9kbits/s speed=0.393x frame= 29 fps= 14 q=22.0 size= 198kB time=00:00:00.85 bitrate=1904.0kbits/s speed=0.408x frame= 35 fps= 13 q=22.0 size= 274kB time=00:00:01.11 bitrate=2018.5kbits/s speed=0.425x frame= 42 fps= 13 q=22.0 size= 363kB time=00:00:01.36 bitrate=2179.2kbits/s speed=0.435x frame= 48 fps= 13 q=23.0 size= 447kB time=00:00:01.62 bitrate=2255.4kbits/s speed=0.444x frame= 54 fps= 13 q=24.0 size= 532kB time=00:00:01.89 bitrate=2297.8kbits/s speed=0.453x frame= 61 fps= 13 q=25.0 size= 652kB time=00:00:02.13 bitrate=2504.2kbits/s speed=0.454x frame= 67 fps= 13 q=25.0 size= 765kB time=00:00:02.41 bitrate=2601.1kbits/s speed=0.463x frame= 73 fps= 13 q=26.0 size= 873kB time=00:00:02.66 bitrate=2683.2kbits/s speed=0.466x frame= 80 fps= 13 q=28.0 size= 992kB time=00:00:02.92 bitrate=2781.8kbits/s speed=0.469x frame= 87 fps= 13 q=30.0 size= 1096kB time=00:00:03.22 bitrate=2787.7kbits/s speed=0.477x frame= 93 fps= 13 q=30.0 size= 1172kB time=00:00:03.45 bitrate=2778.6kbits/s speed=0.476x frame= 100 fps= 13 q=32.0 size= 1258kB time=00:00:03.69 bitrate=2793.3kbits/s speed=0.475x frame= 106 fps= 13 q=30.0 size= 1324kB time=00:00:03.99 bitrate=2718.6kbits/s speed=0.481x frame= 112 fps= 13 q=28.0 size= 1386kB time=00:00:04.22 bitrate=2688.1kbits/s speed=0.48x frame= 119 fps= 13 q=26.0 size= 1447kB time=00:00:04.48 bitrate=2646.4kbits/s speed=0.482x frame= 126 fps= 13 q=28.0 size= 1513kB time=00:00:04.77 bitrate=2594.5kbits/s speed=0.486x frame= 133 fps= 13 q=25.0 size= 1557kB time=00:00:05.05 bitrate=2523.0kbits/s speed=0.488x frame= 141 fps= 13 q=23.0 size= 1612kB time=00:00:05.33 bitrate=2476.5kbits/s speed=0.489x frame= 148 fps= 13 q=25.0 size= 1656kB time=00:00:05.61 bitrate=2417.8kbits/s speed=0.492x frame= 155 fps= 13 q=23.0 size= 1702kB time=00:00:05.91 bitrate=2359.7kbits/s speed=0.496x frame= 162 fps= 13 q=25.0 size= 1750kB time=00:00:06.20 bitrate=2308.9kbits/s speed=0.499x frame= 170 fps= 13 q=25.0 size= 1803kB time=00:00:06.50 bitrate=2270.3kbits/s speed=0.502x frame= 177 fps= 13 q=23.0 size= 1864kB time=00:00:06.80 bitrate=2243.7kbits/s speed=0.505x frame= 186 fps= 13 q=25.0 size= 1917kB time=00:00:07.12 bitrate=2203.9kbits/s speed=0.51x frame= 194 fps= 13 q=24.0 size= 1951kB time=00:00:07.46 bitrate=2141.0kbits/s speed=0.516x frame= 203 fps= 14 q=23.0 size= 1988kB time=00:00:07.85 bitrate=2074.6kbits/s speed=0.523x frame= 213 fps= 14 q=21.0 size= 2021kB time=00:00:08.21 bitrate=2015.3kbits/s speed=0.529x frame= 222 fps= 14 q=22.0 size= 2061kB time=00:00:08.61 bitrate=1959.2kbits/s speed=0.537x frame= 232 fps= 14 q=23.0 size= 2094kB time=00:00:08.98 bitrate=1909.9kbits/s speed=0.542x frame= 243 fps= 14 q=23.0 size= 2136kB time=00:00:09.40 bitrate=1860.0kbits/s speed=0.551x frame= 252 fps= 14 q=22.0 size= 2169kB time=00:00:09.81 bitrate=1810.9kbits/s speed=0.558x frame= 263 fps= 15 q=24.0 size= 2228kB time=00:00:10.13 bitrate=1801.1kbits/s speed=0.561x frame= 272 fps= 15 q=21.0 size= 2264kB time=00:00:10.53 bitrate=1760.2kbits/s speed=0.566x frame= 281 fps= 15 q=21.0 size= 2322kB time=00:00:10.90 bitrate=1745.0kbits/s speed=0.571x frame= 291 fps= 15 q=20.0 size= 2342kB time=00:00:11.24 bitrate=1706.3kbits/s speed=0.573x frame= 301 fps= 15 q=18.0 size= 2350kB time=00:00:11.67 bitrate=1649.5kbits/s speed=0.58x frame= 312 fps= 15 q=19.0 size= 2363kB time=00:00:12.09 bitrate=1600.2kbits/s speed=0.586x frame= 324 fps= 15 q=21.0 size= 2381kB time=00:00:12.63 bitrate=1544.2kbits/s speed=0.597x frame= 336 fps= 16 q=20.0 size= 2427kB time=00:00:13.05 bitrate=1522.9kbits/s speed=0.602x frame= 349 fps= 16 q=20.0 size= 2468kB time=00:00:13.59 bitrate=1487.9kbits/s speed=0.613x frame= 362 fps= 16 q=20.0 size= 2506kB time=00:00:14.08 bitrate=1457.8kbits/s speed=0.62x frame= 375 fps= 16 q=18.0 size= 2542kB time=00:00:14.61 bitrate=1425.1kbits/s speed=0.63x frame= 388 fps= 16 q=20.0 size= 2599kB time=00:00:15.14 bitrate=1405.7kbits/s speed=0.639x frame= 401 fps= 17 q=20.0 size= 2633kB time=00:00:15.63 bitrate=1379.1kbits/s speed=0.646x frame= 414 fps= 17 q=20.0 size= 2673kB time=00:00:16.17 bitrate=1354.0kbits/s speed=0.654x frame= 426 fps= 17 q=23.0 size= 2721kB time=00:00:16.66 bitrate=1337.9kbits/s speed=0.66x frame= 440 fps= 17 q=19.0 size= 2748kB time=00:00:17.19 bitrate=1309.1kbits/s speed=0.668x frame= 453 fps= 17 q=19.0 size= 2759kB time=00:00:17.72 bitrate=1274.8kbits/s speed=0.676x frame= 466 fps= 17 q=19.0 size= 2768kB time=00:00:18.26 bitrate=1241.8kbits/s speed=0.683x frame= 478 fps= 18 q=19.0 size= 2777kB time=00:00:18.73 bitrate=1214.5kbits/s speed=0.687x frame= 488 fps= 18 q=19.0 size= 2792kB time=00:00:19.11 bitrate=1196.8kbits/s speed=0.688x frame= 495 fps= 18 q=22.0 size= 2823kB time=00:00:19.56 bitrate=1182.3kbits/s speed=0.692x frame= 503 fps= 17 q=22.0 size= 2888kB time=00:00:19.79 bitrate=1195.0kbits/s speed=0.688x frame= 509 fps= 17 q=23.0 size= 2971kB time=00:00:20.05 bitrate=1213.6kbits/s speed=0.684x frame= 517 fps= 17 q=26.0 size= 3095kB time=00:00:20.39 bitrate=1243.4kbits/s speed=0.683x frame= 528 fps= 17 q=23.0 size= 3166kB time=00:00:20.80 bitrate=1246.8kbits/s speed=0.685x frame= 539 fps= 17 q=23.0 size= 3203kB time=00:00:21.27 bitrate=1233.6kbits/s speed=0.689x frame= 549 fps= 17 q=23.0 size= 3271kB time=00:00:21.67 bitrate=1236.3kbits/s speed=0.69x frame= 559 fps= 18 q=25.0 size= 3347kB time=00:00:22.10 bitrate=1240.7kbits/s speed=0.693x frame= 567 fps= 17 q=25.0 size= 3406kB time=00:00:22.37 bitrate=1246.7kbits/s speed=0.69x frame= 575 fps= 17 q=25.0 size= 3455kB time=00:00:22.72 bitrate=1245.8kbits/s speed=0.69x frame= 585 fps= 17 q=23.0 size= 3522kB time=00:00:23.10 bitrate=1248.7kbits/s speed=0.691x frame= 597 fps= 18 q=23.0 size= 3598kB time=00:00:23.57 bitrate=1250.2kbits/s speed=0.694x frame= 609 fps= 18 q=23.0 size= 3680kB time=00:00:24.06 bitrate=1252.9kbits/s speed=0.698x frame= 621 fps= 18 q=22.0 size= 3763kB time=00:00:24.53 bitrate=1256.6kbits/s speed=0.702x frame= 633 fps= 18 q=21.0 size= 3854kB time=00:00:25.02 bitrate=1261.6kbits/s speed=0.706x frame= 646 fps= 18 q=24.0 size= 3976kB time=00:00:25.53 bitrate=1275.5kbits/s speed=0.71x frame= 655 fps= 18 q=25.0 size= 4034kB time=00:00:25.92 bitrate=1275.0kbits/s speed=0.71x frame= 663 fps= 18 q=26.0 size= 4110kB time=00:00:26.21 bitrate=1284.2kbits/s speed=0.708x frame= 675 fps= 18 q=25.0 size= 4196kB time=00:00:26.73 bitrate=1286.1kbits/s speed=0.712x frame= 687 fps= 18 q=25.0 size= 4298kB time=00:00:27.15 bitrate=1296.3kbits/s speed=0.714x frame= 698 fps= 18 q=24.0 size= 4395kB time=00:00:27.64 bitrate=1302.1kbits/s speed=0.717x frame= 710 fps= 18 q=25.0 size= 4505kB time=00:00:28.07 bitrate=1314.6kbits/s speed=0.719x frame= 720 fps= 18 q=26.0 size= 4597kB time=00:00:28.50 bitrate=1321.1kbits/s speed=0.72x frame= 732 fps= 18 q=26.0 size= 4714kB time=00:00:28.97 bitrate=1333.1kbits/s speed=0.723x frame= 743 fps= 18 q=22.0 size= 4830kB time=00:00:29.41 bitrate=1345.1kbits/s speed=0.725x frame= 755 fps= 18 q=25.0 size= 4924kB time=00:00:29.93 bitrate=1347.7kbits/s speed=0.728x frame= 767 fps= 18 q=25.0 size= 5032kB time=00:00:30.42 bitrate=1354.9kbits/s speed=0.731x frame= 779 fps= 18 q=25.0 size= 5113kB time=00:00:30.87 bitrate=1356.8kbits/s speed=0.733x frame= 790 fps= 19 q=24.0 size= 5190kB time=00:00:31.29 bitrate=1358.4kbits/s speed=0.734x frame= 801 fps= 19 q=22.0 size= 5265kB time=00:00:31.76 bitrate=1357.7kbits/s speed=0.736x frame= 813 fps= 19 q=23.0 size= 5350kB time=00:00:32.21 bitrate=1360.4kbits/s speed=0.738x frame= 823 fps= 19 q=21.0 size= 5422kB time=00:00:32.61 bitrate=1361.8kbits/s speed=0.739x frame= 834 fps= 19 q=23.0 size= 5490kB time=00:00:33.06 bitrate=1360.0kbits/s speed=0.74x frame= 846 fps= 19 q=23.0 size= 5559kB time=00:00:33.55 bitrate=1357.1kbits/s speed=0.742x frame= 858 fps= 19 q=23.0 size= 5630kB time=00:00:34.02 bitrate=1355.5kbits/s speed=0.743x frame= 870 fps= 19 q=23.0 size= 5704kB time=00:00:34.51 bitrate=1353.7kbits/s speed=0.745x frame= 880 fps= 19 q=24.0 size= 5798kB time=00:00:34.94 bitrate=1359.2kbits/s speed=0.746x frame= 893 fps= 19 q=21.0 size= 5890kB time=00:00:35.41 bitrate=1362.5kbits/s speed=0.748x frame= 903 fps= 19 q=25.0 size= 5970kB time=00:00:35.81 bitrate=1365.5kbits/s speed=0.748x frame= 913 fps= 19 q=22.0 size= 6040kB time=00:00:36.24 bitrate=1365.0kbits/s speed=0.749x frame= 923 fps= 19 q=22.0 size= 6127kB time=00:00:36.65 bitrate=1369.6kbits/s speed=0.75x frame= 934 fps= 19 q=23.0 size= 6223kB time=00:00:37.07 bitrate=1374.8kbits/s speed=0.751x frame= 944 fps= 19 q=25.0 size= 6301kB time=00:00:37.46 bitrate=1377.9kbits/s speed=0.751x frame= 953 fps= 19 q=25.0 size= 6377kB time=00:00:37.82 bitrate=1381.2kbits/s speed=0.75x frame= 963 fps= 19 q=24.0 size= 6442kB time=00:00:38.25 bitrate=1379.7kbits/s speed=0.751x frame= 975 fps= 19 q=22.0 size= 6512kB time=00:00:38.69 bitrate=1378.5kbits/s speed=0.752x frame= 987 fps= 19 q=22.0 size= 6568kB time=00:00:39.16 bitrate=1373.8kbits/s speed=0.754x frame= 998 fps= 19 q=25.0 size= 6641kB time=00:00:39.59 bitrate=1373.9kbits/s speed=0.755x frame= 1008 fps= 19 q=21.0 size= 6727kB time=00:00:40.00 bitrate=1377.7kbits/s speed=0.755x frame= 1019 fps= 19 q=25.0 size= 6812kB time=00:00:40.47 bitrate=1378.8kbits/s speed=0.757x frame= 1028 fps= 19 q=29.0 size= 7001kB time=00:00:40.85 bitrate=1403.8kbits/s speed=0.757x frame= 1031 fps= 19 q=-1.0 Lsize= 7310kB time=00:00:41.16 bitrate=1454.9kbits/s speed=0.754x video:6646kB audio:643kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.297147% [libx264 @ 0xa941120] frame I:14 Avg QP:15.78 size: 27315 [libx264 @ 0xa941120] frame P:363 Avg QP:17.07 size: 11752 [libx264 @ 0xa941120] frame B:654 Avg QP:18.36 size: 3297 [libx264 @ 0xa941120] consecutive B-frames: 12.0% 8.3% 5.5% 74.1% [libx264 @ 0xa941120] mb I I16..4: 41.2% 29.5% 29.3% [libx264 @ 0xa941120] mb P I16..4: 16.2% 15.3% 3.5% P16..4: 35.6% 0.0% 0.0% 0.0% 0.0% skip:29.4% [libx264 @ 0xa941120] mb B I16..4: 1.3% 1.0% 0.1% B16..8: 19.1% 0.0% 0.0% direct:10.3% skip:68.1% L0:38.5% L1:46.1% BI:15.5% [libx264 @ 0xa941120] 8x8 transform intra:42.2% inter:47.6% [libx264 @ 0xa941120] coded y,uvDC,uvAC intra: 38.7% 50.7% 21.4% inter: 11.0% 15.5% 0.5% [libx264 @ 0xa941120] i16 v,h,dc,p: 62% 24% 6% 8% [libx264 @ 0xa941120] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 27% 21% 16% 6% 5% 7% 5% 8% 6% [libx264 @ 0xa941120] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 28% 31% 11% 5% 4% 5% 5% 5% 5% [libx264 @ 0xa941120] i8c dc,h,v,p: 41% 26% 23% 10% [libx264 @ 0xa941120] Weighted P-Frames: Y:7.4% UV:5.2% [libx264 @ 0xa941120] kb/s:1318.71 [aac @ 0xa969400] Qavg: 465.863 Then I to make something to help you to find the problem? Thank you, Jérémy The next release of Emby Server should have a fix for this, thanks.
Darkjeje 11 Posted August 25, 2016 Author Posted August 25, 2016 Thank you Luke and ebr, I wait that If you want to test the new server with my movie write me. Thanks
Luke 42244 Posted August 25, 2016 Posted August 25, 2016 If you can provide a sample file, we'll try it out to make sure. Just PM me with a link. Thanks.
Luke 42244 Posted August 25, 2016 Posted August 25, 2016 You can try out the changes now by installing both the beta version of the app and the beta Emby Server. Enjoy.
Darkjeje 11 Posted August 25, 2016 Author Posted August 25, 2016 Ok, thank you Luke. At this moment, I don't see any update for my packet of emby on my synology. My version is 3.1.117.0 and I see in Emby that the version 3.1.121 is now available for download but @@solabc16 don't have push this version. I think that he takes well deserved holidays How to install the beta version of emby for android TV ? Do you have a link for me to know how install this beta version ? Thank you Luke
Luke 42244 Posted August 25, 2016 Posted August 25, 2016 See here for the app: http://emby.media/community/index.php?/topic/24350-android-open-beta-testing/
solabc16 379 Posted August 27, 2016 Posted August 27, 2016 Hello @@DarkjejeThe latest builds are all available now, see here: http://emby.media/community/index.php?/topic/37777-large-delay-between-releases-stable-and-beta-and-update-package-appearing-in-synology/?p=360077Best- James
Darkjeje 11 Posted August 27, 2016 Author Posted August 27, 2016 (edited) Hello @@Darkjeje The latest builds are all available now, see here: http://emby.media/community/index.php?/topic/37777-large-delay-between-releases-stable-and-beta-and-update-package-appearing-in-synology/?p=360077 Best - James Thank you James !!! You can try out the changes now by installing both the beta version of the app and the beta Emby Server. Enjoy. Sorry Luke, my problem is not resolved The server's version is 3.1.124.0, The Emby for Android TV version is 1.2.39g. I have send my android tv log at 9h55 AM profil "HDTV". The log of the server : http://192.168.1.6:8096/emby/videos/2ae56a1efe0aa11c8e31acaed2582b54/stream.mkv?DeviceId=db4b864504eb9c15&MediaSourceId=2ae56a1efe0aa11c8e31acaed2582b54&VideoCodec=h264&AudioCodec=aac,mp3&AudioStreamIndex=1&VideoBitrate=56112986&AudioBitrate=192000&MaxAudioChannels=6&Level=51&Profile=high&PlaySessionId=0615aeca507844889294c58be36711f2&api_key=f281567512fd41f4b435cc819441b288&CopyTimestamps=true&SubtitleMethod=Encode&EnableSubtitlesInManifest=false&Tag=ab74babe4cda34a7bc7a06276a84e4d0 {"Protocol":"File","Id":"2ae56a1efe0aa11c8e31acaed2582b54","Path":"/volume1/Film/Film (L Ã Z)/Le Flingueur (2011)/Le Flingueur (2011).ts","Type":"Default","Container":"ts","Name":"480P/H264/MP2","ETag":"ab74babe4cda34a7bc7a06276a84e4d0","RunTimeTicks":49823280000,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","TimeBase":"1/90000","CodecTimeBase":"1/50","NalLengthSize":"0","IsInterlaced":false,"IsAVC":false,"BitRate":2080469,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":576,"Width":720,"AverageFrameRate":25,"RealFrameRate":25,"Profile":"Main","Type":"Video","AspectRatio":"20:11","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":30,"IsAnamorphic":false},{"Codec":"mp2","Language":"fra","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"Fra MP2 stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":2080469,"RequiredHttpHeaders":{}} /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -fflags +genpts -i file:"/volume1/Film/Film (L Ã Z)/Le Flingueur (2011)/Le Flingueur (2011).ts" -ss 00:00:01.000 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -force_key_frames "expr:gte(t,n_forced*5)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1280)/2)*2:trunc(ow/dar/2)*2" -copyts -avoid_negative_ts disabled -start_at_zero -pix_fmt yuv420p -preset superfast -crf 23 -b:v 2080469 -maxrate 2080469 -bufsize 4160938 -vsync -1 -profile:v high -level 51 -map_metadata -1 -threads 0 -codec:a:0 aac -strict experimental -ac 2 -ab 192000 -af "aresample=async=1" -y "/var/packages/EmbyServer/target/var/transcoding-temp/282ab20c5ef11163d4dd43cbc99c8934.mkv" ffmpeg version 3.1.2-static http://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.4.0 (Debian 5.4.0-6) 20160609 configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libwebp --enable-libspeex --enable-libvorbis --enable-libvpx --enable-libfreetype --enable-fontconfig --enable-libxvid --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvo-amrwbenc --enable-gray --enable-libopenjpeg --enable-libopus --enable-libass --enable-gnutls --enable-libvidstab --enable-libsoxr --enable-frei0r --enable-libfribidi --disable-indev=sndio --disable-outdev=sndio --enable-librtmp --enable-libmfx --enable-libzimg --cc=gcc libavutil 55. 28.100 / 55. 28.100 libavcodec 57. 48.101 / 57. 48.101 libavformat 57. 41.100 / 57. 41.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 47.100 / 6. 47.100 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 1.100 / 2. 1.100 libpostproc 54. 0.100 / 54. 0.100 Input #0, mpegts, from 'file:/volume1/Film/Film (L Ã Z)/Le Flingueur (2011)/Le Flingueur (2011).ts': Duration: 01:23:02.33, start: 0.200000, bitrate: 2080 kb/s Program 1 Stream #0:0[0x80c]: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p(tv), 720x576 [SAR 16:11 DAR 20:11], 25 fps, 25 tbr, 90k tbn, 50 tbc Stream #0:1[0x80d](fra): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16p, 192 kb/s [libx264 @ 0xa959c80] using SAR=3974/3983 [libx264 @ 0xa959c80] using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 [libx264 @ 0xa959c80] profile High, level 5.1 [libx264 @ 0xa959c80] 264 - core 148 r276 3f5ed56 - H.264/MPEG-4 AVC codec - Copyleft 2003-2016 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x3:0x3 me=dia subme=1 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=6 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=0 rc=crf mbtree=0 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=2080 vbv_bufsize=4160 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 pb_ratio=1.30 aq=1:1.00 [matroska @ 0xa98bac0] Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead. Last message repeated 1 times Output #0, matroska, to '/var/packages/EmbyServer/target/var/transcoding-temp/282ab20c5ef11163d4dd43cbc99c8934.mkv': Metadata: encoder : Lavf57.41.100 Stream #0:0: Video: h264 (libx264) (H264 / 0x34363248), yuv420p, 1046x574 [SAR 5740:5753 DAR 20:11], q=-1--1, 2080 kb/s, 25 fps, 1k tbn, 25 tbc Metadata: encoder : Lavc57.48.101 libx264 Side data: cpb: bitrate max/min/avg: 2080000/0/2080000 buffer size: 4160000 vbv_delay: -1 Stream #0:1: Audio: aac (LC) ([255][0][0][0] / 0x00FF), 48000 Hz, stereo, fltp, 192 kb/s Metadata: encoder : Lavc57.48.101 aac Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (mp2 (native) -> aac (native)) Press [q] to stop, [?] for help [h264 @ 0xaab7660] Reinit context to 720x576, pix_fmt: yuv420p [h264 @ 0xaa5bbe0] Increasing reorder buffer to 2 frame= 6 fps=0.0 q=0.0 size= 0kB time=00:00:00.00 bitrate=N/A speed= 0x frame= 12 fps= 12 q=0.0 size= 0kB time=00:00:00.15 bitrate= 0.0kbits/s speed=0.145x frame= 16 fps= 10 q=22.0 size= 43kB time=00:00:00.34 bitrate=1039.8kbits/s speed=0.216x frame= 21 fps=9.9 q=22.0 size= 110kB time=00:00:00.53 bitrate=1687.3kbits/s speed=0.252x frame= 27 fps= 10 q=23.0 size= 188kB time=00:00:00.72 bitrate=2115.9kbits/s speed=0.276x frame= 33 fps= 10 q=24.0 size= 286kB time=00:00:00.96 bitrate=2444.0kbits/s speed=0.303x frame= 39 fps= 10 q=24.0 size= 396kB time=00:00:01.25 bitrate=2581.8kbits/s speed=0.338x frame= 45 fps= 11 q=24.0 size= 507kB time=00:00:01.49 bitrate=2781.1kbits/s speed=0.354x frame= 52 fps= 11 q=28.0 size= 638kB time=00:00:01.75 bitrate=2987.9kbits/s speed=0.369x frame= 58 fps= 11 q=28.0 size= 754kB time=00:00:02.00 bitrate=3078.8kbits/s speed=0.382x frame= 64 fps= 11 q=29.0 size= 838kB time=00:00:02.24 bitrate=3064.5kbits/s speed=0.389x frame= 71 fps= 11 q=30.0 size= 939kB time=00:00:02.49 bitrate=3083.0kbits/s speed=0.397x frame= 76 fps= 11 q=32.0 size= 1003kB time=00:00:02.71 bitrate=3030.7kbits/s speed=0.399x frame= 84 fps= 11 q=29.0 size= 1093kB time=00:00:03.00 bitrate=2976.4kbits/s speed=0.412x frame= 91 fps= 12 q=28.0 size= 1168kB time=00:00:03.35 bitrate=2855.3kbits/s speed=0.428x frame= 99 fps= 12 q=29.0 size= 1238kB time=00:00:03.64 bitrate=2780.9kbits/s speed=0.437x frame= 107 fps= 12 q=29.0 size= 1309kB time=00:00:03.96 bitrate=2702.4kbits/s speed=0.449x frame= 115 fps= 12 q=27.0 size= 1361kB time=00:00:04.31 bitrate=2586.4kbits/s speed=0.461x frame= 123 fps= 12 q=25.0 size= 1412kB time=00:00:04.58 bitrate=2521.6kbits/s speed=0.464x frame= 130 fps= 13 q=25.0 size= 1454kB time=00:00:04.90 bitrate=2428.1kbits/s speed=0.472x frame= 140 fps= 13 q=24.0 size= 1538kB time=00:00:05.27 bitrate=2391.5kbits/s speed=0.484x frame= 150 fps= 13 q=25.0 size= 1612kB time=00:00:05.65 bitrate=2336.3kbits/s speed=0.495x frame= 159 fps= 13 q=22.0 size= 1676kB time=00:00:06.05 bitrate=2266.3kbits/s speed=0.508x frame= 172 fps= 14 q=24.0 size= 1742kB time=00:00:06.52 bitrate=2186.5kbits/s speed=0.525x frame= 183 fps= 14 q=23.0 size= 1786kB time=00:00:07.01 bitrate=2085.2kbits/s speed=0.542x frame= 194 fps= 14 q=22.0 size= 1832kB time=00:00:07.42 bitrate=2022.0kbits/s speed=0.551x frame= 205 fps= 15 q=21.0 size= 1872kB time=00:00:07.87 bitrate=1948.1kbits/s speed=0.564x frame= 216 fps= 15 q=23.0 size= 1917kB time=00:00:08.27 bitrate=1897.4kbits/s speed=0.572x frame= 226 fps= 15 q=23.0 size= 1957kB time=00:00:08.72 bitrate=1837.4kbits/s speed=0.582x frame= 239 fps= 15 q=23.0 size= 2004kB time=00:00:09.13 bitrate=1798.2kbits/s speed=0.589x frame= 249 fps= 16 q=23.0 size= 2055kB time=00:00:09.57 bitrate=1757.3kbits/s speed=0.599x frame= 261 fps= 16 q=21.0 size= 2120kB time=00:00:10.00 bitrate=1735.5kbits/s speed=0.606x frame= 273 fps= 16 q=19.0 size= 2147kB time=00:00:10.49 bitrate=1675.6kbits/s speed=0.617x frame= 283 fps= 16 q=20.0 size= 2162kB time=00:00:10.90 bitrate=1624.7kbits/s speed=0.623x frame= 294 fps= 16 q=20.0 size= 2178kB time=00:00:11.37 bitrate=1569.3kbits/s speed=0.631x frame= 304 fps= 16 q=22.0 size= 2204kB time=00:00:11.73 bitrate=1538.9kbits/s speed=0.634x frame= 315 fps= 17 q=18.0 size= 2252kB time=00:00:12.22 bitrate=1508.9kbits/s speed=0.642x frame= 327 fps= 17 q=18.0 size= 2289kB time=00:00:12.65 bitrate=1482.4kbits/s speed=0.647x frame= 339 fps= 17 q=18.0 size= 2329kB time=00:00:13.14 bitrate=1451.5kbits/s speed=0.656x frame= 351 fps= 17 q=18.0 size= 2367kB time=00:00:13.61 bitrate=1424.5kbits/s speed=0.662x frame= 362 fps= 17 q=20.0 size= 2401kB time=00:00:14.03 bitrate=1401.2kbits/s speed=0.667x frame= 372 fps= 17 q=19.0 size= 2435kB time=00:00:14.44 bitrate=1381.0kbits/s speed=0.67x frame= 383 fps= 17 q=17.0 size= 2468kB time=00:00:14.89 bitrate=1357.9kbits/s speed=0.675x frame= 393 fps= 17 q=21.0 size= 2515kB time=00:00:15.29 bitrate=1346.9kbits/s speed=0.678x frame= 404 fps= 18 q=23.0 size= 2556kB time=00:00:15.72 bitrate=1331.6kbits/s speed=0.681x frame= 417 fps= 18 q=18.0 size= 2589kB time=00:00:16.25 bitrate=1304.7kbits/s speed=0.689x frame= 430 fps= 18 q=18.0 size= 2604kB time=00:00:16.79 bitrate=1270.7kbits/s speed=0.697x frame= 443 fps= 18 q=19.0 size= 2618kB time=00:00:17.28 bitrate=1241.0kbits/s speed=0.702x frame= 456 fps= 18 q=19.0 size= 2631kB time=00:00:17.81 bitrate=1209.7kbits/s speed=0.709x frame= 466 fps= 18 q=19.0 size= 2657kB time=00:00:18.28 bitrate=1190.4kbits/s speed=0.713x frame= 476 fps= 18 q=21.0 size= 2735kB time=00:00:18.71 bitrate=1197.7kbits/s speed=0.716x frame= 485 fps= 18 q=22.0 size= 2834kB time=00:00:19.03 bitrate=1219.9kbits/s speed=0.714x frame= 494 fps= 18 q=25.0 size= 2931kB time=00:00:19.39 bitrate=1238.1kbits/s speed=0.714x frame= 505 fps= 18 q=24.0 size= 3007kB time=00:00:19.88 bitrate=1238.8kbits/s speed=0.718x frame= 516 fps= 18 q=26.0 size= 3100kB time=00:00:20.31 bitrate=1250.4kbits/s speed=0.72x frame= 526 fps= 18 q=24.0 size= 3169kB time=00:00:20.71 bitrate=1253.2kbits/s speed=0.721x frame= 536 fps= 18 q=25.0 size= 3240kB time=00:00:21.12 bitrate=1256.6kbits/s speed=0.722x frame= 543 fps= 18 q=25.0 size= 3296kB time=00:00:21.39 bitrate=1261.7kbits/s speed=0.719x frame= 553 fps= 18 q=24.0 size= 3354kB time=00:00:21.78 bitrate=1261.2kbits/s speed=0.72x frame= 562 fps= 18 q=24.0 size= 3428kB time=00:00:22.12 bitrate=1269.4kbits/s speed=0.719x frame= 570 fps= 18 q=24.0 size= 3481kB time=00:00:22.48 bitrate=1268.1kbits/s speed=0.719x frame= 581 fps= 18 q=23.0 size= 3552kB time=00:00:22.87 bitrate=1272.3kbits/s speed=0.72x frame= 591 fps= 18 q=25.0 size= 3634kB time=00:00:23.33 bitrate=1275.6kbits/s speed=0.723x frame= 602 fps= 18 q=24.0 size= 3713kB time=00:00:23.76 bitrate=1280.0kbits/s speed=0.725x frame= 613 fps= 18 q=22.0 size= 3794kB time=00:00:24.19 bitrate=1284.7kbits/s speed=0.726x frame= 623 fps= 18 q=25.0 size= 3873kB time=00:00:24.59 bitrate=1289.9kbits/s speed=0.727x frame= 632 fps= 18 q=24.0 size= 3932kB time=00:00:24.96 bitrate=1290.4kbits/s speed=0.727x frame= 642 fps= 18 q=26.0 size= 4095kB time=00:00:25.36 bitrate=1322.6kbits/s speed=0.728x frame= 652 fps= 18 q=24.0 size= 4169kB time=00:00:25.75 bitrate=1326.2kbits/s speed=0.728x frame= 663 fps= 18 q=23.0 size= 4248kB time=00:00:26.15 bitrate=1330.5kbits/s speed=0.729x frame= 673 fps= 18 q=26.0 size= 4342kB time=00:00:26.58 bitrate=1338.3kbits/s speed=0.731x frame= 683 fps= 19 q=24.0 size= 4421kB time=00:00:27.00 bitrate=1341.0kbits/s speed=0.732x frame= 693 fps= 19 q=26.0 size= 4524kB time=00:00:27.41 bitrate=1352.0kbits/s speed=0.733x frame= 703 fps= 19 q=24.0 size= 4608kB time=00:00:27.79 bitrate=1358.1kbits/s speed=0.733x frame= 712 fps= 19 q=25.0 size= 4708kB time=00:00:28.16 bitrate=1369.7kbits/s speed=0.733x frame= 722 fps= 19 q=27.0 size= 4797kB time=00:00:28.56 bitrate=1375.7kbits/s speed=0.734x frame= 731 fps= 19 q=23.0 size= 4853kB time=00:00:28.90 bitrate=1375.3kbits/s speed=0.733x frame= 741 fps= 19 q=22.0 size= 4917kB time=00:00:29.29 bitrate=1375.3kbits/s speed=0.733x frame= 751 fps= 19 q=25.0 size= 5001kB time=00:00:29.73 bitrate=1377.8kbits/s speed=0.735x frame= 762 fps= 19 q=26.0 size= 5078kB time=00:00:30.14 bitrate=1380.1kbits/s speed=0.736x frame= 773 fps= 19 q=24.0 size= 5184kB time=00:00:30.57 bitrate=1389.3kbits/s speed=0.737x frame= 783 fps= 19 q=23.0 size= 5259kB time=00:00:31.01 bitrate=1388.9kbits/s speed=0.739x frame= 792 fps= 19 q=25.0 size= 5326kB time=00:00:31.31 bitrate=1393.1kbits/s speed=0.737x frame= 801 fps= 19 q=23.0 size= 5387kB time=00:00:31.68 bitrate=1393.1kbits/s speed=0.737x frame= 808 fps= 19 q=24.0 size= 5432kB time=00:00:31.97 bitrate=1391.6kbits/s speed=0.735x frame= 814 fps= 18 q=23.0 size= 5474kB time=00:00:32.23 bitrate=1391.1kbits/s speed=0.732x frame= 823 fps= 18 q=24.0 size= 5527kB time=00:00:32.61 bitrate=1388.0kbits/s speed=0.732x frame= 833 fps= 18 q=22.0 size= 5582kB time=00:00:33.00 bitrate=1385.5kbits/s speed=0.733x frame= 842 fps= 18 q=23.0 size= 5646kB time=00:00:33.36 bitrate=1386.2kbits/s speed=0.732x frame= 851 fps= 18 q=23.0 size= 5720kB time=00:00:33.72 bitrate=1389.4kbits/s speed=0.731x frame= 858 fps= 18 q=25.0 size= 5758kB time=00:00:34.00 bitrate=1387.0kbits/s speed=0.729x frame= 866 fps= 18 q=23.0 size= 5817kB time=00:00:34.30 bitrate=1389.0kbits/s speed=0.728x frame= 874 fps= 18 q=22.0 size= 5879kB time=00:00:34.60 bitrate=1392.0kbits/s speed=0.726x frame= 880 fps= 18 q=22.0 size= 5927kB time=00:00:34.88 bitrate=1392.1kbits/s speed=0.724x frame= 889 fps= 18 q=22.0 size= 6017kB time=00:00:35.24 bitrate=1398.7kbits/s speed=0.724x frame= 899 fps= 18 q=22.0 size= 6100kB time=00:00:35.60 bitrate=1403.5kbits/s speed=0.724x frame= 908 fps= 18 q=23.0 size= 6181kB time=00:00:35.99 bitrate=1407.0kbits/s speed=0.725x frame= 917 fps= 18 q=25.0 size= 6260kB time=00:00:36.37 bitrate=1409.7kbits/s speed=0.725x frame= 923 fps= 18 q=25.0 size= 6310kB time=00:00:36.60 bitrate=1412.0kbits/s speed=0.722x frame= 932 fps= 18 q=24.0 size= 6385kB time=00:00:36.97 bitrate=1414.8kbits/s speed=0.722x frame= 939 fps= 18 q=24.0 size= 6429kB time=00:00:37.24 bitrate=1413.9kbits/s speed=0.72x frame= 950 fps= 18 q=25.0 size= 6500kB time=00:00:37.65 bitrate=1414.2kbits/s speed=0.721x frame= 959 fps= 18 q=22.0 size= 6542kB time=00:00:38.05 bitrate=1408.1kbits/s speed=0.722x frame= 968 fps= 18 q=24.0 size= 6602kB time=00:00:38.40 bitrate=1408.4kbits/s speed=0.721x frame= 976 fps= 18 q=24.0 size= 6659kB time=00:00:38.72 bitrate=1408.9kbits/s speed=0.72x frame= 986 fps= 18 q=24.0 size= 6747kB time=00:00:39.08 bitrate=1414.3kbits/s speed=0.72x frame= 995 fps= 18 q=27.0 size= 6793kB time=00:00:39.44 bitrate=1410.8kbits/s speed=0.719x frame= 1003 fps= 18 q=27.0 size= 6966kB time=00:00:39.76 bitrate=1434.9kbits/s speed=0.719x frame= 1010 fps= 18 q=27.0 size= 7109kB time=00:00:40.04 bitrate=1454.4kbits/s speed=0.717x frame= 1016 fps= 18 q=29.0 size= 7264kB time=00:00:40.32 bitrate=1475.9kbits/s speed=0.716x frame= 1025 fps= 18 q=31.0 size= 7423kB time=00:00:40.68 bitrate=1494.8kbits/s speed=0.716x frame= 1032 fps= 18 q=33.0 size= 7532kB time=00:00:40.93 bitrate=1507.2kbits/s speed=0.714x frame= 1041 fps= 18 q=32.0 size= 7634kB time=00:00:41.30 bitrate=1514.2kbits/s speed=0.714x frame= 1049 fps= 18 q=28.0 size= 7663kB time=00:00:41.62 bitrate=1508.3kbits/s speed=0.713x frame= 1057 fps= 18 q=26.0 size= 7717kB time=00:00:41.94 bitrate=1507.3kbits/s speed=0.712x frame= 1063 fps= 18 q=25.0 size= 7781kB time=00:00:42.19 bitrate=1510.6kbits/s speed=0.71x frame= 1070 fps= 18 q=24.0 size= 7846kB time=00:00:42.43 bitrate=1514.8kbits/s speed=0.708x frame= 1075 fps= 18 q=25.0 size= 7904kB time=00:00:42.66 bitrate=1517.6kbits/s speed=0.706x frame= 1083 fps= 18 q=23.0 size= 8011kB time=00:00:42.98 bitrate=1526.7kbits/s speed=0.705x frame= 1091 fps= 18 q=22.0 size= 8068kB time=00:00:43.28 bitrate=1527.0kbits/s speed=0.704x frame= 1098 fps= 18 q=24.0 size= 8139kB time=00:00:43.58 bitrate=1529.8kbits/s speed=0.703x frame= 1107 fps= 18 q=21.0 size= 8229kB time=00:00:43.96 bitrate=1533.2kbits/s speed=0.703x frame= 1114 fps= 18 q=22.0 size= 8299kB time=00:00:44.20 bitrate=1538.1kbits/s speed=0.701x frame= 1122 fps= 18 q=23.0 size= 8386kB time=00:00:44.52 bitrate=1543.1kbits/s speed=0.701x frame= 1127 fps= 18 q=21.0 size= 8423kB time=00:00:44.75 bitrate=1541.7kbits/s speed=0.698x frame= 1133 fps= 18 q=21.0 size= 8481kB time=00:00:45.01 bitrate=1543.5kbits/s speed=0.697x frame= 1140 fps= 18 q=22.0 size= 8620kB time=00:00:45.27 bitrate=1559.9kbits/s speed=0.695x frame= 1147 fps= 17 q=23.0 size= 8673kB time=00:00:45.54 bitrate=1559.9kbits/s speed=0.694x frame= 1154 fps= 17 q=22.0 size= 8748kB time=00:00:45.84 bitrate=1563.2kbits/s speed=0.693x frame= 1162 fps= 17 q=24.0 size= 8850kB time=00:00:46.12 bitrate=1571.9kbits/s speed=0.692x frame= 1168 fps= 17 q=27.0 size= 8964kB time=00:00:46.40 bitrate=1582.7kbits/s speed=0.689x frame= 1175 fps= 17 q=27.0 size= 9072kB time=00:00:46.65 bitrate=1592.8kbits/s speed=0.687x frame= 1181 fps= 17 q=28.0 size= 9129kB time=00:00:46.93 bitrate=1593.5kbits/s speed=0.686x frame= 1184 fps= 17 q=25.0 size= 9165kB time=00:00:47.04 bitrate=1596.0kbits/s speed=0.683x frame= 1192 fps= 17 q=25.0 size= 9249kB time=00:00:47.33 bitrate=1600.6kbits/s speed=0.682x frame= 1197 fps= 17 q=27.0 size= 9300kB time=00:00:47.55 bitrate=1602.2kbits/s speed=0.679x frame= 1206 fps= 17 q=26.0 size= 9393kB time=00:00:47.89 bitrate=1606.6kbits/s speed=0.679x frame= 1212 fps= 17 q=27.0 size= 9447kB time=00:00:48.17 bitrate=1606.6kbits/s speed=0.678x frame= 1222 fps= 17 q=25.0 size= 9548kB time=00:00:48.55 bitrate=1611.0kbits/s speed=0.678x frame= 1231 fps= 17 q=25.0 size= 9632kB time=00:00:48.93 bitrate=1612.4kbits/s speed=0.679x frame= 1239 fps= 17 q=25.0 size= 9705kB time=00:00:49.23 bitrate=1614.6kbits/s speed=0.678x frame= 1249 fps= 17 q=26.0 size= 9835kB time=00:00:49.66 bitrate=1622.2kbits/s speed=0.679x frame= 1258 fps= 17 q=27.0 size= 9959kB time=00:00:50.00 bitrate=1631.5kbits/s speed=0.679x frame= 1266 fps= 17 q=28.0 size= 10075kB time=00:00:50.28 bitrate=1641.4kbits/s speed=0.678x frame= 1273 fps= 17 q=28.0 size= 10165kB time=00:00:50.58 bitrate=1646.2kbits/s speed=0.678x frame= 1280 fps= 17 q=26.0 size= 10242kB time=00:00:50.88 bitrate=1649.0kbits/s speed=0.677x frame= 1290 fps= 17 q=26.0 size= 10358kB time=00:00:51.26 bitrate=1655.2kbits/s speed=0.678x frame= 1301 fps= 17 q=23.0 size= 10439kB time=00:00:51.73 bitrate=1653.0kbits/s speed=0.679x frame= 1309 fps= 17 q=23.0 size= 10520kB time=00:00:52.03 bitrate=1656.3kbits/s speed=0.678x frame= 1319 fps= 17 q=25.0 size= 10630kB time=00:00:52.41 bitrate=1661.3kbits/s speed=0.679x frame= 1330 fps= 17 q=24.0 size= 10727kB time=00:00:52.88 bitrate=1661.5kbits/s speed=0.68x frame= 1339 fps= 17 q=25.0 size= 10777kB time=00:00:53.27 bitrate=1657.3kbits/s speed=0.681x frame= 1347 fps= 17 q=25.0 size= 10823kB time=00:00:53.56 bitrate=1655.1kbits/s speed=0.68x frame= 1357 fps= 17 q=22.0 size= 10875kB time=00:00:53.95 bitrate=1651.2kbits/s speed=0.681x frame= 1367 fps= 17 q=22.0 size= 10951kB time=00:00:54.35 bitrate=1650.3kbits/s speed=0.681x frame= 1377 fps= 17 q=24.0 size= 11033kB time=00:00:54.72 bitrate=1651.7kbits/s speed=0.681x frame= 1383 fps= 17 q=26.0 size= 11117kB time=00:00:54.99 bitrate=1655.9kbits/s speed=0.68x frame= 1392 fps= 17 q=27.0 size= 11238kB time=00:00:55.38 bitrate=1662.3kbits/s speed=0.681x frame= 1402 fps= 17 q=25.0 size= 11350kB time=00:00:55.76 bitrate=1667.3kbits/s speed=0.681x frame= 1409 fps= 17 q=24.0 size= 11428kB time=00:00:56.04 bitrate=1670.5kbits/s speed=0.68x frame= 1418 fps= 17 q=25.0 size= 11525kB time=00:00:56.36 bitrate=1675.2kbits/s speed=0.68x frame= 1426 fps= 17 q=25.0 size= 11611kB time=00:00:56.72 bitrate=1676.8kbits/s speed=0.68x frame= 1435 fps= 17 q=26.0 size= 11697kB time=00:00:57.06 bitrate=1679.1kbits/s speed=0.68x frame= 1444 fps= 17 q=24.0 size= 11777kB time=00:00:57.40 bitrate=1680.5kbits/s speed=0.68x frame= 1452 fps= 17 q=24.0 size= 11867kB time=00:00:57.75 bitrate=1683.4kbits/s speed=0.679x frame= 1459 fps= 17 q=26.0 size= 11945kB time=00:00:58.07 bitrate=1685.2kbits/s speed=0.679x frame= 1468 fps= 17 q=23.0 size= 12037kB time=00:00:58.39 bitrate=1688.8kbits/s speed=0.679x frame= 1477 fps= 17 q=24.0 size= 12092kB time=00:00:58.75 bitrate=1686.1kbits/s speed=0.679x frame= 1485 fps= 17 q=24.0 size= 12138kB time=00:00:59.07 bitrate=1683.3kbits/s speed=0.678x frame= 1493 fps= 17 q=24.0 size= 12197kB time=00:00:59.41 bitrate=1681.7kbits/s speed=0.678x frame= 1502 fps= 17 q=25.0 size= 12266kB time=00:00:59.71 bitrate=1682.7kbits/s speed=0.678x frame= 1510 fps= 17 q=24.0 size= 12338kB time=00:01:00.07 bitrate=1682.4kbits/s speed=0.677x frame= 1518 fps= 17 q=25.0 size= 12417kB time=00:01:00.37 bitrate=1684.8kbits/s speed=0.677x frame= 1526 fps= 17 q=24.0 size= 12488kB time=00:01:00.71 bitrate=1685.0kbits/s speed=0.677x frame= 1534 fps= 17 q=24.0 size= 12558kB time=00:01:01.03 bitrate=1685.6kbits/s speed=0.676x frame= 1542 fps= 17 q=23.0 size= 12641kB time=00:01:01.33 bitrate=1688.4kbits/s speed=0.676x frame= 1548 fps= 17 q=23.0 size= 12719kB time=00:01:01.59 bitrate=1691.7kbits/s speed=0.675x frame= 1558 fps= 17 q=26.0 size= 12868kB time=00:01:01.97 bitrate=1700.9kbits/s speed=0.675x frame= 1567 fps= 17 q=27.0 size= 12968kB time=00:01:02.35 bitrate=1703.6kbits/s speed=0.676x frame= 1576 fps= 17 q=26.0 size= 13063kB time=00:01:02.72 bitrate=1706.2kbits/s speed=0.676x frame= 1584 fps= 17 q=26.0 size= 13154kB time=00:01:03.06 bitrate=1708.8kbits/s speed=0.676x frame= 1595 fps= 17 q=27.0 size= 13283kB time=00:01:03.44 bitrate=1715.1kbits/s speed=0.676x frame= 1605 fps= 17 q=24.0 size= 13384kB time=00:01:03.87 bitrate=1716.6kbits/s speed=0.677x frame= 1614 fps= 17 q=25.0 size= 13492kB time=00:01:04.23 bitrate=1720.7kbits/s speed=0.677x frame= 1617 fps= 17 q=-1.0 Lsize= 13668kB time=00:01:04.56 bitrate=1734.3kbits/s speed=0.676x video:12119kB audio:1515kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.245340% [libx264 @ 0xa959c80] frame I:17 Avg QP:16.60 size: 38624 [libx264 @ 0xa959c80] frame P:552 Avg QP:18.19 size: 13346 [libx264 @ 0xa959c80] frame B:1048 Avg QP:20.23 size: 4185 [libx264 @ 0xa959c80] consecutive B-frames: 9.7% 9.5% 6.3% 74.5% [libx264 @ 0xa959c80] mb I I16..4: 36.2% 24.4% 39.3% [libx264 @ 0xa959c80] mb P I16..4: 12.7% 14.2% 3.7% P16..4: 40.1% 0.0% 0.0% 0.0% 0.0% skip:29.3% [libx264 @ 0xa959c80] mb B I16..4: 1.4% 1.4% 0.2% B16..8: 23.0% 0.0% 0.0% direct:10.8% skip:63.1% L0:39.3% L1:44.8% BI:16.0% [libx264 @ 0xa959c80] 8x8 transform intra:44.9% inter:46.9% [libx264 @ 0xa959c80] coded y,uvDC,uvAC intra: 42.2% 56.0% 23.1% inter: 13.1% 17.2% 0.7% [libx264 @ 0xa959c80] i16 v,h,dc,p: 58% 27% 7% 7% [libx264 @ 0xa959c80] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 24% 16% 6% 5% 6% 6% 7% 8% [libx264 @ 0xa959c80] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 24% 30% 12% 6% 5% 5% 6% 5% 7% [libx264 @ 0xa959c80] i8c dc,h,v,p: 39% 30% 21% 11% [libx264 @ 0xa959c80] Weighted P-Frames: Y:5.3% UV:3.4% [libx264 @ 0xa959c80] kb/s:1534.87 [aac @ 0xa979da0] Qavg: 555.996 For your information, my movie is impossible to see. The transcoding is very bad. I have testing to see the same movie with Emby for Android with my LG G2 when I select an other player. I tested my movie with the player Freebox Mini Android TV, it is the same, 17 fps, impossible to see my movie. I tested my movie with the player Freebox Mini Emby chromecast, the movie is transcoding but in 20 fps and the movie is good, the picture is clear but there is lag. The server log if you want : http://192.168.1.6:8096/emby/videos/2ae56a1efe0aa11c8e31acaed2582b54/stream.mkv?DeviceId=db4b864504eb9c15&MediaSourceId=2ae56a1efe0aa11c8e31acaed2582b54&VideoCodec=h264&AudioCodec=aac,mp3&AudioStreamIndex=1&VideoBitrate=56112986&AudioBitrate=192000&MaxAudioChannels=6&Level=51&Profile=high&PlaySessionId=0615aeca507844889294c58be36711f2&api_key=f281567512fd41f4b435cc819441b288&CopyTimestamps=true&SubtitleMethod=Encode&EnableSubtitlesInManifest=false&Tag=ab74babe4cda34a7bc7a06276a84e4d0 {"Protocol":"File","Id":"2ae56a1efe0aa11c8e31acaed2582b54","Path":"/volume1/Film/Film (L Ã Z)/Le Flingueur (2011)/Le Flingueur (2011).ts","Type":"Default","Container":"ts","Name":"480P/H264/MP2","ETag":"ab74babe4cda34a7bc7a06276a84e4d0","RunTimeTicks":49823280000,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","TimeBase":"1/90000","CodecTimeBase":"1/50","NalLengthSize":"0","IsInterlaced":false,"IsAVC":false,"BitRate":2080469,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":576,"Width":720,"AverageFrameRate":25,"RealFrameRate":25,"Profile":"Main","Type":"Video","AspectRatio":"20:11","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":30,"IsAnamorphic":false},{"Codec":"mp2","Language":"fra","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"Fra MP2 stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":2080469,"RequiredHttpHeaders":{}} /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -fflags +genpts -i file:"/volume1/Film/Film (L Ã Z)/Le Flingueur (2011)/Le Flingueur (2011).ts" -ss 00:00:01.000 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -force_key_frames "expr:gte(t,n_forced*5)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1280)/2)*2:trunc(ow/dar/2)*2" -copyts -avoid_negative_ts disabled -start_at_zero -pix_fmt yuv420p -preset superfast -crf 23 -b:v 2080469 -maxrate 2080469 -bufsize 4160938 -vsync -1 -profile:v high -level 51 -map_metadata -1 -threads 0 -codec:a:0 aac -strict experimental -ac 2 -ab 192000 -af "aresample=async=1" -y "/var/packages/EmbyServer/target/var/transcoding-temp/282ab20c5ef11163d4dd43cbc99c8934.mkv" ffmpeg version 3.1.2-static http://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.4.0 (Debian 5.4.0-6) 20160609 configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libwebp --enable-libspeex --enable-libvorbis --enable-libvpx --enable-libfreetype --enable-fontconfig --enable-libxvid --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvo-amrwbenc --enable-gray --enable-libopenjpeg --enable-libopus --enable-libass --enable-gnutls --enable-libvidstab --enable-libsoxr --enable-frei0r --enable-libfribidi --disable-indev=sndio --disable-outdev=sndio --enable-librtmp --enable-libmfx --enable-libzimg --cc=gcc libavutil 55. 28.100 / 55. 28.100 libavcodec 57. 48.101 / 57. 48.101 libavformat 57. 41.100 / 57. 41.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 47.100 / 6. 47.100 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 1.100 / 2. 1.100 libpostproc 54. 0.100 / 54. 0.100 Input #0, mpegts, from 'file:/volume1/Film/Film (L Ã Z)/Le Flingueur (2011)/Le Flingueur (2011).ts': Duration: 01:23:02.33, start: 0.200000, bitrate: 2080 kb/s Program 1 Stream #0:0[0x80c]: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p(tv), 720x576 [SAR 16:11 DAR 20:11], 25 fps, 25 tbr, 90k tbn, 50 tbc Stream #0:1[0x80d](fra): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16p, 192 kb/s [libx264 @ 0xa959c80] using SAR=3974/3983 [libx264 @ 0xa959c80] using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 [libx264 @ 0xa959c80] profile High, level 5.1 [libx264 @ 0xa959c80] 264 - core 148 r276 3f5ed56 - H.264/MPEG-4 AVC codec - Copyleft 2003-2016 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x3:0x3 me=dia subme=1 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=6 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=0 rc=crf mbtree=0 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=2080 vbv_bufsize=4160 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 pb_ratio=1.30 aq=1:1.00 [matroska @ 0xa98bac0] Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead. Last message repeated 1 times Output #0, matroska, to '/var/packages/EmbyServer/target/var/transcoding-temp/282ab20c5ef11163d4dd43cbc99c8934.mkv': Metadata: encoder : Lavf57.41.100 Stream #0:0: Video: h264 (libx264) (H264 / 0x34363248), yuv420p, 1046x574 [SAR 5740:5753 DAR 20:11], q=-1--1, 2080 kb/s, 25 fps, 1k tbn, 25 tbc Metadata: encoder : Lavc57.48.101 libx264 Side data: cpb: bitrate max/min/avg: 2080000/0/2080000 buffer size: 4160000 vbv_delay: -1 Stream #0:1: Audio: aac (LC) ([255][0][0][0] / 0x00FF), 48000 Hz, stereo, fltp, 192 kb/s Metadata: encoder : Lavc57.48.101 aac Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (mp2 (native) -> aac (native)) Press [q] to stop, [?] for help [h264 @ 0xaab7660] Reinit context to 720x576, pix_fmt: yuv420p [h264 @ 0xaa5bbe0] Increasing reorder buffer to 2 frame= 8 fps=0.0 q=0.0 size= 0kB time=00:00:00.00 bitrate=N/A speed= 0x frame= 13 fps= 13 q=0.0 size= 0kB time=00:00:00.19 bitrate= 0.0kbits/s speed=0.188x frame= 18 fps= 12 q=22.0 size= 69kB time=00:00:00.40 bitrate=1398.1kbits/s speed=0.266x frame= 24 fps= 12 q=23.0 size= 150kB time=00:00:00.66 bitrate=1851.1kbits/s speed=0.326x frame= 30 fps= 12 q=24.0 size= 237kB time=00:00:00.85 bitrate=2277.3kbits/s speed=0.337x frame= 36 fps= 12 q=25.0 size= 341kB time=00:00:01.11 bitrate=2515.7kbits/s speed=0.365x frame= 42 fps= 12 q=25.0 size= 455kB time=00:00:01.36 bitrate=2728.6kbits/s speed=0.385x frame= 49 fps= 12 q=25.0 size= 584kB time=00:00:01.62 bitrate=2948.0kbits/s speed=0.396x frame= 56 fps= 12 q=27.0 size= 714kB time=00:00:01.92 bitrate=3046.9kbits/s speed=0.417x frame= 63 fps= 12 q=29.0 size= 829kB time=00:00:02.21 bitrate=3060.5kbits/s speed=0.433x frame= 71 fps= 13 q=30.0 size= 940kB time=00:00:02.49 bitrate=3086.0kbits/s speed=0.444x frame= 78 fps= 13 q=31.0 size= 1026kB time=00:00:02.81 bitrate=2985.0kbits/s speed=0.46x frame= 86 fps= 13 q=26.0 size= 1120kB time=00:00:03.11 bitrate=2947.3kbits/s speed=0.469x frame= 94 fps= 13 q=26.0 size= 1196kB time=00:00:03.43 bitrate=2852.8kbits/s speed=0.479x frame= 102 fps= 13 q=28.0 size= 1273kB time=00:00:03.77 bitrate=2760.8kbits/s speed=0.492x frame= 112 fps= 14 q=28.0 size= 1340kB time=00:00:04.13 bitrate=2652.6kbits/s speed=0.505x frame= 121 fps= 14 q=23.0 size= 1394kB time=00:00:04.50 bitrate=2536.4kbits/s speed=0.517x frame= 130 fps= 14 q=25.0 size= 1455kB time=00:00:04.88 bitrate=2440.3kbits/s speed=0.53x frame= 140 fps= 14 q=24.0 size= 1540kB time=00:00:05.27 bitrate=2393.3kbits/s speed=0.542x frame= 150 fps= 15 q=25.0 size= 1614kB time=00:00:05.65 bitrate=2337.9kbits/s speed=0.552x frame= 161 fps= 15 q=25.0 size= 1693kB time=00:00:06.08 bitrate=2280.5kbits/s speed=0.566x frame= 172 fps= 15 q=24.0 size= 1743kB time=00:00:06.55 bitrate=2180.5kbits/s speed=0.582x frame= 184 fps= 16 q=23.0 size= 1789kB time=00:00:07.06 bitrate=2074.8kbits/s speed=0.601x frame= 197 fps= 16 q=21.0 size= 1841kB time=00:00:07.57 bitrate=1991.6kbits/s speed=0.618x frame= 210 fps= 16 q=22.0 size= 1897kB time=00:00:08.04 bitrate=1931.9kbits/s speed=0.63x frame= 221 fps= 17 q=20.0 size= 1935kB time=00:00:08.47 bitrate=1871.8kbits/s speed=0.638x frame= 233 fps= 17 q=23.0 size= 1985kB time=00:00:08.93 bitrate=1819.5kbits/s speed=0.648x frame= 244 fps= 17 q=23.0 size= 2028kB time=00:00:09.34 bitrate=1778.4kbits/s speed=0.654x frame= 255 fps= 17 q=18.0 size= 2107kB time=00:00:09.77 bitrate=1766.9kbits/s speed=0.66x frame= 267 fps= 17 q=21.0 size= 2140kB time=00:00:10.30 bitrate=1701.8kbits/s speed=0.673x frame= 280 fps= 18 q=17.0 size= 2159kB time=00:00:10.77 bitrate=1641.4kbits/s speed=0.681x frame= 291 fps= 18 q=20.0 size= 2173kB time=00:00:11.22 bitrate=1586.1kbits/s speed=0.687x frame= 302 fps= 18 q=22.0 size= 2196kB time=00:00:11.64 bitrate=1544.8kbits/s speed=0.692x frame= 314 fps= 18 q=21.0 size= 2250kB time=00:00:12.11 bitrate=1521.3kbits/s speed=0.699x frame= 326 fps= 18 q=20.0 size= 2287kB time=00:00:12.60 bitrate=1486.0kbits/s speed=0.707x frame= 337 fps= 18 q=20.0 size= 2324kB time=00:00:13.05 bitrate=1458.0kbits/s speed=0.712x frame= 348 fps= 18 q=-1.0 Lsize= 2392kB time=00:00:13.80 bitrate=1420.1kbits/s speed=0.726x video:2066kB audio:319kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.327577% [libx264 @ 0xa959c80] frame I:4 Avg QP:13.96 size: 12928 [libx264 @ 0xa959c80] frame P:149 Avg QP:17.01 size: 10730 [libx264 @ 0xa959c80] frame B:195 Avg QP:15.84 size: 2381 [libx264 @ 0xa959c80] consecutive B-frames: 21.6% 9.8% 4.3% 64.4% [libx264 @ 0xa959c80] mb I I16..4: 55.7% 34.1% 10.2% [libx264 @ 0xa959c80] mb P I16..4: 19.6% 20.7% 4.1% P16..4: 26.9% 0.0% 0.0% 0.0% 0.0% skip:28.6% [libx264 @ 0xa959c80] mb B I16..4: 1.4% 1.7% 0.1% B16..8: 15.2% 0.0% 0.0% direct:10.4% skip:71.2% L0:43.1% L1:47.2% BI: 9.7% [libx264 @ 0xa959c80] 8x8 transform intra:46.5% inter:52.9% [libx264 @ 0xa959c80] coded y,uvDC,uvAC intra: 35.3% 52.3% 18.5% inter: 8.5% 19.6% 0.5% [libx264 @ 0xa959c80] i16 v,h,dc,p: 66% 19% 6% 9% [libx264 @ 0xa959c80] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 31% 15% 15% 6% 5% 8% 5% 10% 6% [libx264 @ 0xa959c80] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 34% 22% 11% 6% 4% 5% 5% 6% 5% [libx264 @ 0xa959c80] i8c dc,h,v,p: 40% 21% 27% 11% [libx264 @ 0xa959c80] Weighted P-Frames: Y:8.7% UV:5.4% [libx264 @ 0xa959c80] kb/s:1215.43 [aac @ 0xa979da0] Qavg: 513.738 Tell me if you want an other test Jérémy Edited August 27, 2016 by Darkjeje
ebr 16337 Posted August 27, 2016 Posted August 27, 2016 I am not seeing your log report from the app. Are you getting a confirmation message that it was sent? Also, would it be possible for you to provide a sample file?
Luke 42244 Posted August 27, 2016 Posted August 27, 2016 I am not seeing your log report from the app. Are you getting a confirmation message that it was sent? Also, would it be possible for you to provide a sample file? He PM'd me. I added you to it.
Darkjeje 11 Posted August 28, 2016 Author Posted August 28, 2016 I am not seeing your log report from the app. Are you getting a confirmation message that it was sent? Also, would it be possible for you to provide a sample file? Hello ebr, I sended my movie to Luke this morning and I sended my log at 9h55 AM
ebr 16337 Posted August 28, 2016 Posted August 28, 2016 I played your sample on both my Nexus Player and Fire TV and it direct played for me on both. I tried changing some of the playback settings and I could not make it transcode (unless I lowered the bitrate). Is it possible that there is some server-side setting that is impacting this?
Luke 42244 Posted August 28, 2016 Posted August 28, 2016 I played your sample on both my Nexus Player and Fire TV and it direct played for me on both. I tried changing some of the playback settings and I could not make it transcode (unless I lowered the bitrate). Is it possible that there is some server-side setting that is impacting this? I don't believe so. What about client-side audio settings related to stereo vs surround? Aside from that, he should update to the latest Emby Server and double check that he is running the latest beta version of the app (or stable if these changes have gone out).
ebr 16337 Posted August 28, 2016 Posted August 28, 2016 I don't believe so. What about client-side audio settings related to stereo vs surround? I tried both audio settings and it direct played with either one as it should (since the source audio is stereo). One other possibility could be that the item isn't properly probed in his environment...
