rumred85 0 Posted April 11, 2016 Posted April 11, 2016 I have 2 hdhomerun primes for a total of 6 tuners. When i try to play stations they lock up after about 10 seconds. If i delete a tuner then they don't lock up but if i add it back they do. It doesn't matter which tuner i delete. I also have media center running (which i am hoping to replace with your dvr solution), It does not lock up with 6 tuners. I can record all 6 channels with no lockups. Any thoughts?
Luke 42242 Posted April 11, 2016 Posted April 11, 2016 Hi, it's probably a coincidence and doesn't have anything to do with multiple tuners. Please see how to report a media playback issue and we'll take a look. Thanks.
rumred85 0 Posted April 11, 2016 Author Posted April 11, 2016 (edited) Ok, I think i have everything you should need. I have 3 log files and 2 transcoding-temp files. You can see the stuttering on the temp files and eventually about about 30 sec it just stops. Thank you for your help. transcode-accc7d8c-12f2-4520-9b1b-749a9746a9d6.txt server-63595976091.txt transcode-72804d9e-fe3c-41fe-b638-4825e0bffaf1.txt Edited April 11, 2016 by rumred85
rumred85 0 Posted April 13, 2016 Author Posted April 13, 2016 Just curious....is someone looking into this? Did i post the information you need to diagnose this problem?
Luke 42242 Posted April 13, 2016 Posted April 13, 2016 I wonder if it's an issue with that specific tuner and not an issue specific to multiple tuners. Perhaps it could be signal loss leading to the stream stopping. For example, I have multiple tuners as part of a test setup and don't see any issues. The multi-tuner support doesn't really do anything special. It's just a matter of picking which tuner to use, then once that's decided, it's the same as a single tuner setup.
rumred85 0 Posted April 14, 2016 Author Posted April 14, 2016 That could be true but media center has no problems with both tuners. On top of that i tested it with each tuner stand alone and had no problems as i stated before.
Luke 42242 Posted April 14, 2016 Posted April 14, 2016 It could be the same signal drops are happening but it's just recovering better than we are at this point. An automatic re-connection is something we need to add.
