2BTSquared 5 Posted December 29, 2013 Posted December 29, 2013 So the guide says: \Music \Artist Name \Album Name 1- Song.mp3 2- Song.mp3 So for Roy Orbison - The Soul of Rock and Roll (2008), how should I do it? It's 4 disc: Into the 1950s - Disc One Into the 1960s - Disc Two Into the 1970s - Disc Three Into the 1980s - Disc Four
Luke 42289 Posted December 29, 2013 Posted December 29, 2013 that should be fine, although currently the server will see it as separate albums. but it will function.
2BTSquared 5 Posted December 29, 2013 Author Posted December 29, 2013 that should be fine, although currently the server will see it as separate albums. but it will function. Not sure what you mean... I did the following: \Music \Roy Orbison \The Soul of Rock and Roll Into the 1950's Disc 1 1- Song.mp3 2- Song.mp3 My only heartburn with the result is that it doesn't display the "Into the 1950s" part of the CD name.
Luke 42289 Posted December 29, 2013 Posted December 29, 2013 can you show a screeenshot of what you mean
2BTSquared 5 Posted December 29, 2013 Author Posted December 29, 2013 can you show a screeenshot of what you mean Sure...
Solution Luke 42289 Posted December 29, 2013 Solution Posted December 29, 2013 oh right, check your id3 tags. we don't really do much with the folder names as far as music is concerned 1
