kbrutlag 2 Posted April 10, 2016 Posted April 10, 2016 Hello, I've been testing the built-in PVR functionality for some time and have found that it's not quite ready for me to use full time - missing recordings, schedules, etc., I'm now testing NextPVR. I have Next PVR setup and have added the plug-in into Emby - so far, so good. Now, to the root of this post.... Does anyone know how to permanently remove the previous tuner device from Live TV settings? I've used the trashcan and answered OK to the warning pop-up, but in less than 5 minutes it reappears. Thank you
bluemonkey07 590 Posted April 10, 2016 Posted April 10, 2016 You need to disable the tuner not delete. ...to disable select the tuner then select to disable. ...not the trashcan
kbrutlag 2 Posted April 13, 2016 Author Posted April 13, 2016 Thanks, I have disabled the tuner, just thought there was a way to remove it completely if necessary.
