lurch9366 16 Posted April 10, 2016 Posted April 10, 2016 When ripping a movie from my collection I make sure to name any specials as they are named on the blu-ray and/or blu-ray.com When I place the movie in my collection and scan it rather than naming the specials the same as the file name it names them the same title as the main movie. I than go into emby server and edit each special with the file name. Is there a way to set it to automatically name them the same as the file name?
bluemonkey07 590 Posted April 10, 2016 Posted April 10, 2016 Are you putting them the Extras sub folder of your movie folder as per the naming wiki ?
lurch9366 16 Posted April 10, 2016 Author Posted April 10, 2016 They are in the specials sub folder which is in the movie folder
lurch9366 16 Posted April 10, 2016 Author Posted April 10, 2016 When extras was launched the naming convention was putting all extras in a "specials" folder. it correctly picks them up in all the apps and displays them as extras it just names them wrong. I will try naming the folder "extras" on the next movie rip and see if anything changes. If so I will need to go back through all movies in my collection and rename the extras folder.
bluemonkey07 590 Posted April 10, 2016 Posted April 10, 2016 (edited) Specials is used in TV shows, extras is used for movies You need to read here: https://github.com/MediaBrowser/Wiki/wiki/Movie%20naming Edited April 10, 2016 by Vidman
MndWrp 101 Posted April 10, 2016 Posted April 10, 2016 I've seen this issue as well in my setup and realised that some extras had a title metadata set directly in the file. (Usually the name of the movie set automatically by MakeMKV) Removing that made emby directly pick the file name instead... That worked for me, maybe it's the same for you.
lurch9366 16 Posted April 10, 2016 Author Posted April 10, 2016 Specials is used in TV shows, extras is used for movies You need to read here: https://github.com/MediaBrowser/Wiki/wiki/Movie%20naming
lurch9366 16 Posted April 10, 2016 Author Posted April 10, 2016 You assume people do not read the wiki. You come across very condescending and it makes people not want to reach out for help. The goal of these forums is to help and foster this community and find ways to overcome bugs and improve them. Please be aware of this when stating things like you NEED to read the wiki as it is received as hey stupid why don't you do this before posting. Thank for being part of this community Vidman and your input does get the job done.
lurch9366 16 Posted April 10, 2016 Author Posted April 10, 2016 I've seen this issue as well in my setup and realised that some extras had a title metadata set directly in the file. (Usually the name of the movie set automatically by MakeMKV) Removing that made emby directly pick the file name instead... That worked for me, maybe it's the same for you.
lurch9366 16 Posted April 10, 2016 Author Posted April 10, 2016 Thank you. I do use make mkv and this is the most likely cause.
speechles 2061 Posted April 10, 2016 Posted April 10, 2016 (edited) Tv shows uses "/season 0" for specials and will scrape metadata for them Movies uses "/extras" for extra stuff. You can also use "/extras" in Tv too. Using "/extras" wont fetch metadata. Edited April 10, 2016 by speechles
bluemonkey07 590 Posted April 10, 2016 Posted April 10, 2016 (edited) So did you solve the issue? Edited April 10, 2016 by Vidman
Xorp 48 Posted April 11, 2016 Posted April 11, 2016 I still put bonus features for movies in a subfolder called "specials" and don't have any issues with it. It puts the file name as the extra name.
Luke 42186 Posted April 11, 2016 Posted April 11, 2016 mb2 supported specials so that does work as sort of an undocumented alias of extras
lurch9366 16 Posted April 11, 2016 Author Posted April 11, 2016 (edited) So did you solve the issue?I changed all my specials folders to extras pr the wiki and it still names them the title of the movie. (Not hard at all using the search feature in windows explorer and tab Ctrl+v) for those that need to do the same thing When looking at the properties details it looks like mkv did embed the movie title into the file title. I will keep an eye on the next rip. Edited April 11, 2016 by lurch9366
MndWrp 101 Posted April 12, 2016 Posted April 12, 2016 The embedded title can be removed easily with mkvtoolnix ... you don't even have to remux or anything, just edit in the header editor and save.
lurch9366 16 Posted April 12, 2016 Author Posted April 12, 2016 The embedded title can be removed easily with mkvtoolnix ... you don't even have to remux or anything, just edit in the header editor and save. I remuxed about 100 extras today using mkvtoolnix. I did not know there was an option to do it without muxing. I will look into this tonight. Thanks!!!
Solution Luke 42186 Posted April 12, 2016 Solution Posted April 12, 2016 the issue is we're pulling the name from embedded metadata which was requested recently, but now we're seeing cases where that's not always desirable. so we might need some options around it. 1
lurch9366 16 Posted April 12, 2016 Author Posted April 12, 2016 I remuxed about 100 extras today using mkvtoolnix. I did not know there was an option to do it without muxing. I will look into this tonight. Thanks!!! This is working great. I am able to do many at a time.When done removing the embedded title I then need to rename all "extras" folders to "specials" scan library, name back to "extras" and scan again. for some reason when I scan without changing the folder name emby does not pick up the changes.
lurch9366 16 Posted April 12, 2016 Author Posted April 12, 2016 the issue is we're pulling the name from embedded metadata which was requested recently, but now we're seeing cases where that's not always desirable. so we might need some options around it. I wold definitely like this option!!
lurch9366 16 Posted April 12, 2016 Author Posted April 12, 2016 Well that was fun. After re-scanning we are back to where we started when I name them extras. empy reverts back to previous titles for extras. If I leave them specials it seems to pick them up. Luke would you like me to leave it for now until you change the setting so it does not read the embedded title?
MndWrp 101 Posted April 12, 2016 Posted April 12, 2016 (edited) I have the same issue on some titles... the old name won't go away... i refresh, i rescan, i ignored the title, cleaned the database, rescan again.... nope... the old title (even though it's not in the file anymore) remains.... so an option to use the file metadata or not is probably a good idea. Or i guess add the file name as the title metadata... ill try that i guess to shake the wrong naming loose. Edited April 12, 2016 by MndWrp 1
lurch9366 16 Posted April 12, 2016 Author Posted April 12, 2016 I have the same issue on some titles... the old name won't go away... i refresh, i rescan, i ignored the title, cleaned the database, rescan again.... nope... the old title (even though it's not in the file anymore) remains.... so an option to use the file metadata or not is probably a good idea. Or i guess add the file name as the title metadata... ill try that i guess to shake the wrong naming loose. I have both file types in my collection, embedded and no title. It does not seem to make a difference. emby will not pick up the changes.
Luke 42186 Posted April 12, 2016 Posted April 12, 2016 make sure there isn't a metadata file with the old title in it 1
lurch9366 16 Posted April 12, 2016 Author Posted April 12, 2016 I deleted the xml file in the movie folder and re-scanned and no luck. Is there something stored elsewhere?
