Fix restart.sh On Debian 8
Hy all !!!
Today I fixed my restart.sh script on emby and I want to share for all users who have the same problem :)
So first visit this :
https://github.com/MediaBrowser/Wiki/wiki/Linux-Troubleshooting-Guide-and-FAQ
first check that /usr/lib/emby-server/restart.sh is executable with :
> ls -alh /usr/lib/emby-server/restart.sh
Then I execute thoose commands :
>apt install sudo (not installed yet for me :/)
> chmod 0640 /etc/sudoers.d/emby
> usermod -a -G emby $USER_NAME (Where $USER_NAME is equal to your username)
> visudo
> $USER_NAME  ALL=(ALL) NOPASSWD: /etc/init.d/emby-server (UNDER # User alias specification line) This will allow this command only for the $USER_NAME user.
> /etc/init.d/sudo restart to apply modification
Then hit the restart button on the emby web interface and it work's :)
This modification is effective if you're running emby as a non-root user.
To do that, just edit this file :
> /etc/emby-server.conf and modify this line (delete the '#" char and just put your name behind '=' without sapce' :
#EMBY_USER=       #$EMBY_USER, username to run Emby under, the default is emby
@@Luke : Could make a script or something like that to do this modification when a custome want to change the user who is running emby ? I know this is hard beacause you have to check i f sudo is installed and if yes so you have to add the line on the correct line etc... but this will help a lot of user I think ;). Maybe be you can add this directly on the emby web interface. This will be awesome !!! :D
  • Like 1
