weka02 0 Posted April 9, 2016 Posted April 9, 2016 Hi, and HELP. I been a user for a while now,. Since the upgrade to Emby from Media Browser 3 , I have had issues on playback which are very frustrating. I had several different folders, each containing different films, AVI, MKT, MPEG2/4 formats, the indexing and Film retreival works well. When I select a file, read synopysis, then select film to PLAY, it plays a completely different film. I tried just using single directory of films, but same issue occurs. I am running W7 Ultimate 64b, everything is up to date and patched which includes the OS, Emby too. I have been through Emby control panel, ensuring Sync, and all correct options are set...its totally puzzling, any ideas. ? I have Roku's 3 XS , and Smart Samsung TV, this occurs through both when using EMby to select browse my film repository. All units hard wired on the lan, using cat 5e. . Sam
Luke 42186 Posted April 9, 2016 Posted April 9, 2016 Perhaps you enabled cinema mode: https://github.com/MediaBrowser/Wiki/wiki/Cinema-Mode
weka02 0 Posted April 10, 2016 Author Posted April 10, 2016 Thanks for suggestion , yes you were correct it was set, so just switched off and will try again thsievening...much appercaited and thanks again, Sam
