doowain 0 Posted April 9, 2016 Posted April 9, 2016 Hi guys. Sorry if this has been covered before. I downloaded both the previous version of Emby Theater and the newer version. Both have the following issue. When I launch the application, I get the following error: "There was an error launching Emby: Exception has been thrown by the target of an invocation." I checked the logs and there is definitely something amiss. I have attached the log file and below is the stack trace for the error from that log. I know what I downloaded works as I launched the exe with the same files on my work PC. Both are running Windows 7. Please help! ----------- 2016-04-08 21:48:38.1319 Debug - URCOMLoader: CheckObjects lastCheckedPath: C:\Emby Theater App\COMObjects\LastChecked.txt 2016-04-08 21:48:38.1479 Error - App: Error launching application Exception has been thrown by the target of an invocation. System.Reflection.TargetInvocationException at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at System.Security.Cryptography.CryptoConfig.CreateFromName(String name, Object[] args) at System.Security.Cryptography.MD5.Create() at MediaBrowser.Common.Extensions.BaseExtensions.GetMD5(String str) at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker.get_Id() at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker.GetConfigurationFilePath() at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker.LoadTriggers() at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker.get_Triggers() at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker.ReloadTriggerEvents(Boolean isApplicationStartup) at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker..ctor(IScheduledTask scheduledTask, IApplicationPaths applicationPaths, ITaskManager taskManager, IJsonSerializer jsonSerializer, ILogger logger) at MediaBrowser.Common.Implementations.ScheduledTasks.TaskManager.<AddTasks>b__7(IScheduledTask t) at System.Linq.Enumerable.WhereSelectListIterator`2.MoveNext() at System.Collections.Generic.List`1.InsertRange(Int32 index, IEnumerable`1 collection) at MediaBrowser.Common.Implementations.ScheduledTasks.TaskManager.AddTasks(IEnumerable`1 tasks) at MediaBrowser.Common.Implementations.BaseApplicationHost`1.RunStartupTasks() at MediaBrowser.UI.ApplicationHost.<Init>d__0.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.UI.App.<LoadApplication>d__14.MoveNext() InnerException: System.InvalidOperationException This implementation is not part of the Windows Platform FIPS validated cryptographic algorithms. at System.Security.Cryptography.MD5CryptoServiceProvider..ctor() theater-63595748915.txt
Luke 42241 Posted April 9, 2016 Posted April 9, 2016 Hi, try this: http://www.sitefinity.com/developer-network/knowledge-base/details/this-implementation-is-not-part-of-the-windows-platform-fips-validated-cryptographic-algorithms-exception
doowain 0 Posted April 9, 2016 Author Posted April 9, 2016 Thanks for the reply Luke. While that didn't work (I don't have local policy settings as I have Windows 7 Home), it DID point me in the right direction. In case anyone else comes across this, I simply downloaded and extracted the zip file in the instructions at the below link and ran the FIPS.bat file. I'm now in! Thanks again! And awesome product. https://www.articulate.com/support/engage-09/this-implementation-is-not-part-of-the-windows-platform-fips-validated-cryptographic-algorithms
nwsurfer 0 Posted April 9, 2016 Posted April 9, 2016 I'm having a similar issue with the latest version. When the app loads, the splash screen appears, but then it's just a black screen. At that time, the log showed no obvious errors. I followed the steps provided in the previous posts...with FIPS disabled, I experience what was already described, when I enable FIPS I get the error doowain described. Any help would be great because I need my Emby Theater! Log when FIPS disabled 2016-04-09 00:00:19.4572 Info App: Application version: 2.1.6.0 2016-04-09 00:00:19.4892 Info App: Application configuration: {"EnableDebugLevelLogging":true,"EnableAutoUpdate":true,"SystemUpdateLevel":"Release","LogFileRetentionDays":3,"RunAtStartup":false,"IsStartupWizardCompleted":true,"EnableCustomPathSubFolders":false} 2016-04-09 00:00:19.4892 Info App: Loading MediaBrowser.Model, Version=3.0.5867.23148, Culture=neutral, PublicKeyToken=null 2016-04-09 00:00:19.4892 Info App: Loading MediaBrowser.Common, Version=3.0.5867.23147, Culture=neutral, PublicKeyToken=null 2016-04-09 00:00:19.4892 Info App: Loading MediaBrowser.Common.Implementations, Version=3.0.5867.23144, Culture=neutral, PublicKeyToken=null 2016-04-09 00:00:19.4892 Info App: Loading Emby.Theater, Version=2.1.6.0, Culture=neutral, PublicKeyToken=null 2016-04-09 00:00:19.5822 Info App: Core startup complete 2016-04-09 00:00:19.5832 Info App: C:\Users\Media\AppData\Roaming\Emby-Theater\system\x64\electron\electron.exe "C:\Users\Media\AppData\Roaming\Emby-Theater\system\electronapp" 2016-04-09 00:00:20.1793 Info App: attempting to load pfx: 2016-04-09 00:00:20.1793 Error App: Secure requested, but no certificate found at: 2016-04-09 00:00:20.2343 Debug URCOMLoader: URCOMLoader Initialized 2016-04-09 00:00:20.2343 Debug URCOMLoader: EnsureObjects: block: False redownload: False 2016-04-09 00:00:20.2383 Debug URCOMLoader: EnsureObjects needsCheck: False 2016-04-09 00:00:20.2383 Debug URCOMLoader: EnsureObjects needsRestart: False 2016-04-09 00:00:20.2383 Info App: Setting window state to Normal 2016-04-09 00:00:20.2943 Info App: SyncWindowSize Top=260 Left=304 Width=1152 Height=480 2016-04-09 00:00:22.5824 Info App: StartupTrigger fired for task: Check for application updates 2016-04-09 00:00:22.5824 Info App: Queueing task SystemUpdateTask 2016-04-09 00:00:22.5964 Info App: Executing Check for application updates 2016-04-09 00:00:22.6464 Info App: HttpClientManager GET: https://api.github.com/repos/MediaBrowser/Emby.Theater.Windows/releases 2016-04-09 00:00:27.7877 Debug App: No application update available. 2016-04-09 00:00:27.7887 Info App: Check for application updates Completed after 0 minute(s) and 5 seconds Log when FIPS Enabled 2016-04-08 23:57:23.6666 Info App: Application version: 2.1.6.0 2016-04-08 23:57:23.6966 Info App: Application configuration: {"EnableDebugLevelLogging":true,"EnableAutoUpdate":true,"SystemUpdateLevel":"Release","LogFileRetentionDays":3,"RunAtStartup":false,"IsStartupWizardCompleted":true,"EnableCustomPathSubFolders":false} 2016-04-08 23:57:23.6966 Info App: Loading MediaBrowser.Model, Version=3.0.5867.23148, Culture=neutral, PublicKeyToken=null 2016-04-08 23:57:23.6966 Info App: Loading MediaBrowser.Common, Version=3.0.5867.23147, Culture=neutral, PublicKeyToken=null 2016-04-08 23:57:23.6966 Info App: Loading MediaBrowser.Common.Implementations, Version=3.0.5867.23144, Culture=neutral, PublicKeyToken=null 2016-04-08 23:57:23.6966 Info App: Loading Emby.Theater, Version=2.1.6.0, Culture=neutral, PublicKeyToken=null 2016-04-08 23:57:23.7866 Error App: Error launching application One or more errors occurred. System.AggregateException at System.Threading.Tasks.Task.WaitAll(Task[] tasks, Int32 millisecondsTimeout, CancellationToken cancellationToken) at Emby.Theater.Program.Main() InnerException: System.Reflection.TargetInvocationException Exception has been thrown by the target of an invocation. at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at System.Security.Cryptography.CryptoConfig.CreateFromName(String name, Object[] args) at System.Security.Cryptography.MD5.Create() at MediaBrowser.Common.Extensions.BaseExtensions.GetMD5(String str) at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker.get_Id() at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker.GetConfigurationFilePath() at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker.LoadTriggers() at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker.get_Triggers() at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker.ReloadTriggerEvents(Boolean isApplicationStartup) at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker..ctor(IScheduledTask scheduledTask, IApplicationPaths applicationPaths, ITaskManager taskManager, IJsonSerializer jsonSerializer, ILogger logger, IFileSystem fileSystem) at MediaBrowser.Common.Implementations.ScheduledTasks.TaskManager.<AddTasks>b__7(IScheduledTask t) at System.Linq.Enumerable.WhereSelectListIterator`2.MoveNext() at System.Collections.Generic.List`1.InsertRange(Int32 index, IEnumerable`1 collection) at MediaBrowser.Common.Implementations.ScheduledTasks.TaskManager.AddTasks(IEnumerable`1 tasks) at MediaBrowser.Common.Implementations.BaseApplicationHost`1.RunStartupTasks() at Emby.Theater.App.ApplicationHost.<Init>d__3.MoveNext() InnerException: System.InvalidOperationException This implementation is not part of the Windows Platform FIPS validated cryptographic algorithms. at System.Security.Cryptography.MD5CryptoServiceProvider..ctor()
nwsurfer 0 Posted April 9, 2016 Posted April 9, 2016 False alarm...I got it working. For some reason, after logging in via an RDP session with another user...the app loaded. Then I tried on my HTPC and bam it loaded but it was very small. After some screen resolution mucking around, it finally loaded normal. Thanks for a wonderful product, I love it!
