Hal62 0 Posted April 7, 2016 Posted April 7, 2016 emby not work on samsung SmartTV , It works only if you connect to the Internet and not offline , why ?
bluemonkey07 590 Posted April 7, 2016 Posted April 7, 2016 http://emby.media/community/index.php?/topic/790-How-to-report-a-problem
CBers 7554 Posted April 7, 2016 Posted April 7, 2016 emby not work on samsung SmartTV , It works only if you connect to the Internet and not offline , why ? It's not the app, it's the TV itself. The TV checks that it has an internet connection before any smart TV apps are loaded, even i they don't need to use the internet for access. There's not a lot Emby can do about this I'm afraid. 1
Hal62 0 Posted April 7, 2016 Author Posted April 7, 2016 It is not the TV ! emby needs the internet connection , It will not work without it , not work offline , ( if I connect internet then it works ) in fact , I tested Plex and works very well and does not require the internet, works offline !! Also emby should work offline , but is not so , I don't known why......
Hal62 0 Posted April 7, 2016 Author Posted April 7, 2016 http://emby.media/community/index.php?/topic/790-How-to-report-a-problem Ok I understand , many thanks
CBers 7554 Posted April 7, 2016 Posted April 7, 2016 It is not the TV ! emby needs the internet connection , It will not work without it , not work offline , ( if I connect internet then it works ) in fact , I tested Plex and works very well and does not require the internet, works offline !! Also emby should work offline , but is not so , I don't known why...... You get a message saying that there is not internet connection, so it is the TV, not the app. Not sure how Plex get around this, but if there is no internet connection, then no Smart apps will work. http://emby.media/community/index.php?/topic/22231-no-internet-no-emby-access-probably/
Hal62 0 Posted April 7, 2016 Author Posted April 7, 2016 It must be the setting emby , Also plex has the message but after OK it works the same emby no ! Now I look at the link
Hal62 0 Posted April 7, 2016 Author Posted April 7, 2016 (edited) the link is nothing newthe problem remains.......... I can only use Plex (that not from these problems) Edited April 7, 2016 by Hal62
