jds828 24 Posted April 7, 2016 Posted April 7, 2016 Hi, My setup seems to only use the audio descriptive stream with no option to change it in any of the Emby players. I've looked through the Mediaportal settings and Emby but can't see a way to force the standard audio. Any ideas of the setting I'm missing? Thanks.
pünktchen 1410 Posted April 7, 2016 Posted April 7, 2016 Hi, My setup seems to only use the audio descriptive stream with no option to change it in any of the Emby players. I've looked through the Mediaportal settings and Emby but can't see a way to force the standard audio. Any ideas of the setting I'm missing? Thanks. You cannot change it while it's playing? That should be possible already!You can't define what's the default audio track (other than language), it's always the first one.
jds828 24 Posted April 7, 2016 Author Posted April 7, 2016 No, that's why I wondered if it was a MP issue and not the plugin. On the IOS version the audio icon shows but only shows one stream. How would you change it before it plays? I thought the icon only shows during playback. I'll have to have another look later. Thanks for the help.
