feardamhan 6 Posted April 6, 2016 Posted April 6, 2016 (edited) Hi All Been looking through the threads and not found quite what I'm after. Hoping you all can help. Just installed Emby Theatre (Premiere) having been running Emby for WMC for long time. I use Microsoft RC6 remotes everywhere in the house and struggling with some of the functions we are used to with Emby/WMC. For instance: Navigating Movies or TV Series via keying in letters from Remote Volume control Is there a way to get same experience with remote as we are used to? Windows 7 / Latest Emby Server/Theatre builds. Thanks in advance. Edited April 6, 2016 by feardamhan
Deathsquirrel 745 Posted April 6, 2016 Posted April 6, 2016 Navigating by letter isn't implemented and volume control doesn't work if bitstreaming.
Luke 42241 Posted April 7, 2016 Posted April 7, 2016 and volume control doesn't work if bitstreaming. and just so we're clear this is normal. when bitstreaming, you control audio with your receiver.
Deathsquirrel 745 Posted April 7, 2016 Posted April 7, 2016 and just so we're clear this is normal. when bitstreaming, you control audio with your receiver. Sorry, yes. My phrasing could have been clearer.
feardamhan 6 Posted April 7, 2016 Author Posted April 7, 2016 Thanks guys. Good to know. Onward on the Emby Theater learning curve for me!
