genesisforlive 7 Posted April 6, 2016 Posted April 6, 2016 Hi, the speedlimit for streaming form external dont work. I think its a bug. System win10 pro, emby per https over port 443 Greets
ebr 16307 Posted April 6, 2016 Posted April 6, 2016 Please explain exactly what you did that makes you think it isn't working. Thanks.
genesisforlive 7 Posted April 7, 2016 Author Posted April 7, 2016 Hi, i limit the streaming bandbriete. than i watch a movie from external and alle traffice is used that i have (10Mbps Upload)
Luke 42186 Posted April 7, 2016 Posted April 7, 2016 What is 0,25, .25mbps? That's very low. In any event, what Emby app are you using? please see how to report a problem. Thanks.
genesisforlive 7 Posted April 8, 2016 Author Posted April 8, 2016 I Try 0,25 for testing ich have 10 Mbps but i will limit it to 5-7 but it wont work.
Happy2Play 9800 Posted April 8, 2016 Posted April 8, 2016 @@Luke, is the comma in the limit just from translation?
Tranquil 95 Posted April 8, 2016 Posted April 8, 2016 I think the 0,25 can not be interpreted as a bitrate limit. Use 2500 for 2.5 Mbit or 250 for 0.25 Mbit (which is really really a low value for 720p and x264) What is the bandwidth you want to provide to emby?
Luke 42186 Posted April 8, 2016 Posted April 8, 2016 I Try 0,25 for testing ich have 10 Mbps but i will limit it to 5-7 but it wont work. How are you determining that it's not working? Please see how to report a problem. Thanks.
