speechles 2062 Posted April 6, 2016 Posted April 6, 2016 (edited) New firmware: http://forums.roku.com/viewtopic.php?f=28&t=94094 Manually update your roku before the 24 hour window expires if you want to be an early adopter. Otherwise you have to wait for the stable update rollout from roku. Note: Ive updated mine. ^_~ Can confirm the subtitle issue is fixed. Internal and external subtitles direct play fine. Changing them on the fly also works. Anime fans will want to update the firmware of their roku. This update also fixes on the fly multiple audio track selection. So anime fans definitely will want to update as soon as possible. @@Luke you no longer need to force burn-in transcoding of internal subtitles once roku makes the 7.1 firmware an official rollout See here: http://emby.media/community/index.php?/topic/29452-subtitles-on-by-default/ Edited April 6, 2016 by speechles 4
Koleckai Silvestri 1154 Posted April 6, 2016 Posted April 6, 2016 Interesting fixes. I'll just wait until the standard upgrade push. Not currently experiencing any major issues. One of the reasons I bought the Roku is because it just does it thing.
