Changed Lan port to 80 please help fix
I just changed the lan port from 8096 to 80 without giving it much tought, found out it does not work on freebsd? any way to change it in a file in order to access the web interface again?
Update:
when into "/var/db/emby-server/config" and edited "system.xml" and changed the port back to 8096
Edited by reapsz
Well done, glad you found it.
