GrotShot 28 Posted December 28, 2013 Posted December 28, 2013 LAV has issues with some MP4 files and audio so I converted them to mkv. 1
bruce73 2 Posted December 28, 2013 Posted December 28, 2013 So not all MP4s? Or just ones with AAC? Sent from my Nexus 4 using Tapatalk 2
bruce73 2 Posted December 28, 2013 Posted December 28, 2013 Does MBT have a problem playing back MP4 files? Is this a problem with MBT's LAV filters? Even when I set MPC-HC as an external player, they won't play (but will play with MPC-HC as a standalone). So it seems that MBT uses its own LAV filters instead of MPC-HC's. Is this right? Sent from my Nexus 4 using Tapatalk 2
Luke 42234 Posted December 28, 2013 Posted December 28, 2013 there should be no problem. it uses your installed LAV but it sensitive to other installed software on the system, and we still have some work to do to prevent that. 1
GrotShot 28 Posted December 28, 2013 Author Posted December 28, 2013 My issue was with aac so I used mp42mkvac3 to convert those that I had. 1
