Emby for Kodi problem/question with cdart and comment/mood tags
Hi,
I just tried using the Emby Kodi addon for music aswell.
It seems that Emby does not cache the cdart.png files from my local music directories.
Is that correct? Because in the now playing screen of Kodi they are missing.
Another thing I noticed is that the comment tag is not read by Emby.
I use the last.fm.plus plugin (last.fm.ng) in musicbrainz picard to store additional Information like occasion or artist country separated by " / " in the comment field.
Because Kodi is able to search this field I always used these information for creating smart playlists.
Is this comming for Emby aswell or maybe already possible?
Same would be possible with the "mood" tag maybe.
Even in ID3v2.3 you can store this in a TXXX frame, although I know that Kodi does not support this right now.
But some time ago there was a Kodi nightly build where you could also use this field to browse by mood.
Maybe it can be considered to add support for this tag? Would be a nice feature I think.
