Theodore 136 Posted April 5, 2016 Posted April 5, 2016 (edited) So here is an interesting one and definitely not one I have seen in any previous build (3.0.5912.0): I just clicked into my Television library and the shows are out of order even though the library has always sorted alphabetically. I verified the sort is still set that way too. All of the shows appearing at the front share one factor - they all have something in the "Sort Name" field. All the ones in normal order below them have that field blank. It appears that Emby is not taking a blank "Sort Name" field to mean that it should sort on the Name field alone. Either that or something in this version is allowing "Sort Name" to override the Name field even when blank. I would ASSUME that this is carrying over into the Movies libraries as well, but as all of my titles have something in the "Sort Name" field I cannot verify that. Example screenshot - http://www.imgur.com/MB9UwWy.png Edited April 17, 2016 by Theodore
Theodore 136 Posted April 5, 2016 Author Posted April 5, 2016 (edited) Link does not work. Sorry about that. Edited and should be working now (http://www.imgur.com/MB9UwWy.png) Edited April 17, 2016 by Theodore
