Michael K. 24 Posted April 4, 2016 Posted April 4, 2016 Hello, I am a new user who is testing Emby. The issue I'm having is that I cannot figure out how to get Emby to display embedded metadata from movies. The movies are in MP4. The cover art, long description, cast/crew info, etc. is not showing. The only metadata I can see is a short description. Emby for Windows Version 3.0.5912.0. I attached a Log file to this post: Log.txt
Luke 42186 Posted April 4, 2016 Posted April 4, 2016 Hi, I would need a sample file to diagnose. thanks.
Michael K. 24 Posted April 4, 2016 Author Posted April 4, 2016 Hi, I would need a sample file to diagnose. thanks. No problem. I am going to create a clip to reduce the size. I'll post it shortly.
Michael K. 24 Posted April 4, 2016 Author Posted April 4, 2016 Hi, I would need a sample file to diagnose. thanks. The sample file is attached. sample file.zip Please advise. Thanks.
Michael K. 24 Posted April 13, 2016 Author Posted April 13, 2016 Hello, Have you many any progress with this issue?
Luke 42186 Posted April 13, 2016 Posted April 13, 2016 Hi, yes there are some improvements coming for the next emby server release. thanks.
Michael K. 24 Posted April 13, 2016 Author Posted April 13, 2016 Great, thanks for the update. I'm eager to try the changes.
Solution Michael K. 24 Posted May 2, 2016 Author Solution Posted May 2, 2016 Looks like this change has been implemented. The metadata is now showing and it looks really good on my end, using Firefox and Apple TV. Thanks for making these updates! Note: Simply scanning the existing library did not cause any change to the metadata. In order for these changes to take effect, I had to delete my existing library and recreate a new library. After the new library was done scanning I could see the metadata. 1
