justpig 27 Posted April 15, 2016 Posted April 15, 2016 Did that same result. Here is the log file. theater-63596327817.txt
babgvant 143 Posted April 15, 2016 Posted April 15, 2016 (edited) Did that same result. Here is the log file. This looks good, but it looks like you only ran the video for <1m. Are you confident there should be a subtitle in that time span? Edited April 15, 2016 by babgvant
justpig 27 Posted April 15, 2016 Posted April 15, 2016 Yes. I have watched the video before. When using EVR+ it automatically stops the video exactly where the subtitle is to be displayed and return to the info screen. This happens at any point in the video where there is a subtitle, so even if you were to skip ahead it would still happen when a subtitle is to be displayed.
babgvant 143 Posted April 15, 2016 Posted April 15, 2016 ah... I misunderstood what the issue was. Does it do that for every video, every sub title type (looks like this is external)?
justpig 27 Posted April 15, 2016 Posted April 15, 2016 (edited) It does the same with external .srt and internal .pgs. On some videos with extenal .srt and internal .pgs, it does not display the .srt if selected and stops playing if the .pgs selected. Edited April 15, 2016 by justpig
babgvant 143 Posted April 15, 2016 Posted April 15, 2016 Do you have any other system you could test with? I can't reproduce the issue you describe. Will need to add an option to write traces to a file from the CP to get a better idea of what's going on.
justpig 27 Posted April 15, 2016 Posted April 15, 2016 This is the log file from another windows 10 PC. I am seeing the same problem. theater-63596330846.txt
babgvant 143 Posted April 15, 2016 Posted April 15, 2016 This is the log file from another windows 10 PC. I am seeing the same problem. Anything that isn't AMD? This rev will TRACE to the path indicated below (you will need to add this to the registry and ensure that it's a valid path). Windows Registry Editor Version 5.00 [HKEY_CURRENT_USER\SOFTWARE\babgvant\EVR Presenter] "LogFile"="C:\\Temp\\evrcp.txt" babgvant.zip
justpig 27 Posted April 15, 2016 Posted April 15, 2016 I tried to created a reg file with the info given but it fails.
babgvant 143 Posted April 15, 2016 Posted April 15, 2016 I tried to created a reg file with the info given but it fails. Can you be more specific about what fails?
babgvant 143 Posted April 15, 2016 Posted April 15, 2016 This the error. You should be able to copy Windows Registry Editor Version 5.00 [HKEY_CURRENT_USER\SOFTWARE\babgvant\EVR Presenter] "LogFile"="C:\\Temp\\evrcp.txt" straight into a .reg (e.g. logging.reg), save it, and run it to put the setting in the right place. If for some reason that doesn't work (there's a bigger problem at play) you can always open up regedt32 and put the values in manually...
justpig 27 Posted April 15, 2016 Posted April 15, 2016 I did that and it worked. I also created the C:\\Temp folder but there is no log file in it.
babgvant 143 Posted April 15, 2016 Posted April 15, 2016 I did that and it worked. I also created the C:\\Temp folder but there is no log file in it. You will need to close ET, replace the CP dll, restart ET and reproduce the issue. Please provide both the ET log and the CP log after that. If there is no CP log, please check the ET log and make sure that it's loading 1.0.1.1.
justpig 27 Posted April 15, 2016 Posted April 15, 2016 (edited) The CP dll? I have no such file. If by CP you mean custom presenter (EVRPresenter). Then I have done this and still no CP log file. Edited April 15, 2016 by justpig
babgvant 143 Posted April 15, 2016 Posted April 15, 2016 CP = custom presenter (what we've been troubleshooting). If you aren't getting the CP log please attach the et log file so I can see what's happening there.
justpig 27 Posted April 15, 2016 Posted April 15, 2016 Still no CP log. Here is ET's log. theater-63596339907.txt
babgvant 143 Posted April 15, 2016 Posted April 15, 2016 C:\Users\XBMC\AppData\Roaming\Emby-Theater\COMObjects\babgvant\EVRPresenter.dll - 5325df1c-6f10-4292-b8fb-be855f99f88a - True - False2016-04-15 18:22:17.0644 Debug URCOMLoader: Load: EVR Presenter (babgvant) Version: 1.0.1.12016-04-15 18:22:17.3202 Error InternalDirectShowPlayer: Couldn't get EVR Presenter (babgvant) It's really, really strange that COM isn't working reliably on your PC.
Luke 42242 Posted April 15, 2016 Posted April 15, 2016 C:\Users\XBMC\AppData\Roaming\Emby-Theater\COMObjects\babgvant\EVRPresenter.dll - 5325df1c-6f10-4292-b8fb-be855f99f88a - True - False 2016-04-15 18:22:17.0644 Debug URCOMLoader: Load: EVR Presenter (babgvant) Version: 1.0.1.1 2016-04-15 18:22:17.3202 Error InternalDirectShowPlayer: Couldn't get EVR Presenter (babgvant) It's really, really strange that COM isn't working reliably on your PC. Is it possible that it depends on something that is not on his system?
babgvant 143 Posted April 15, 2016 Posted April 15, 2016 Is it possible that it depends on something that is not on his system? It's unreliable. Sometimes it works, sometimes doesn't. We checked dependencies and regsvr32, both checked out fine.
djonnie 14 Posted April 16, 2016 Posted April 16, 2016 I got my subtitles back using EVR+ by installing LAV Filters.
feardamhan 6 Posted April 21, 2016 Posted April 21, 2016 So whats the next step here? Can I help out with logs/samples (though my sample didnt seem to reproduce for u guys, so it should like its system related)
Luke 42242 Posted April 21, 2016 Posted April 21, 2016 So whats the next step here? Can I help out with logs/samples (though my sample didnt seem to reproduce for u guys, so it should like its system related) As a test, does it happen with the madvr renderer?
