babgvant 143 Posted April 12, 2016 Posted April 12, 2016 (edited) I'm having the same issue. Subtitle won't display with EVR+ and although MadVR works on my system the video get shifted up so there is a huge black bar on the bottom and the top of the video is cut off when I use MadVR. Try this one. Had to change subtitle scaling to happen in the CP, not sure why it didn't want to handle it in the filter for this file. As a bonus, the CP now positions subs (by default) off the bottom of the frame instead of using XySubFilter's position #. Edited April 14, 2016 by babgvant
mystic.bertie 23 Posted April 14, 2016 Author Posted April 14, 2016 (edited) This problem is still happening for me. Im Using MadVr. As mentioned in another thread, evr+ with subtitles causes playback problems so i cant test evr+. Using MadVr If a movie has no internal subtiltes, the external polish subtitles will play fine. If a movie has internal subtitles, i click the cc button, there is 3 to choose from, 2 are english, 1 is polish. If i select the external polish subtitle i get nothing. If i select either of the internal english subtitles, it displays the polish subtitles. I had done a fresh install of emby theatre and deleted the folders, this did not help. Edited April 14, 2016 by mystic.bertie
babgvant 143 Posted April 14, 2016 Posted April 14, 2016 Updated version to try out. The scaling scheme has been changed dramatically as well as the offset being a % instead of a fixed int value (always the intent, just unimplemented before). babgvant.zip
lorac 119 Posted April 14, 2016 Posted April 14, 2016 @@babgvant No change with your attachment. Now on 2.19 and latest server beta (35 I believe). Here are some logs. EVR won't show subtitles and movies will play for a little while and then stop. TV shows will play for roughly 1:30 and then skip to the next episode. I also noticed with 2.19 that NDP46-KB3045560-web.exe comes up via UAC every time I start ET. A reboot and reinstalling makes no difference. emby-server.txt theater-63596245693.txt theater-63596246055.txt
Luke 42242 Posted April 15, 2016 Posted April 15, 2016 that's the .net framework version 4.6. In one of the next couple versions i'm going to change the targeting to 4.6, so if you don't have it installed the app is going to fail to run.
babgvant 143 Posted April 15, 2016 Posted April 15, 2016 @@babgvant No change with your attachment. Now on 2.19 and latest server beta (35 I believe). Here are some logs. EVR won't show subtitles and movies will play for a little while and then stop. TV shows will play for roughly 1:30 and then skip to the next episode. I also noticed with 2.19 that NDP46-KB3045560-web.exe comes up via UAC every time I start ET. A reboot and reinstalling makes no difference. Please enable debug level logging and provide those logs. The information necessary to troubleshoot isn't written otherwise.
justpig 27 Posted April 15, 2016 Posted April 15, 2016 I am having similar issues with subtitles as described by @@feardamhan. Also .pgs subtitles though selected will not display.
justpig 27 Posted April 15, 2016 Posted April 15, 2016 This is an ongoing issue that has been raised many times. I am sure they are working to fix it. I am experiencing the same problem which results in me switching back to Kodi with the Emby plugin because the Wife requires subtitles.
babgvant 143 Posted April 15, 2016 Posted April 15, 2016 I am having similar issues with subtitles as described by @@feardamhan. Also .pgs subtitles though selected will not display. Did you replace the presenter with 1.0.1.0 (a few posts back)?
justpig 27 Posted April 15, 2016 Posted April 15, 2016 Yes, I did. The results are the same as before.
babgvant 143 Posted April 15, 2016 Posted April 15, 2016 Yes, I did. The results are the same as before. OK. In that case I need a log with debug level logging enabled. I cannot provide any assistance without that.
justpig 27 Posted April 15, 2016 Posted April 15, 2016 I cannot find an option in Emby theatre to enable debug logging.
babgvant 143 Posted April 15, 2016 Posted April 15, 2016 I cannot find an option in Emby theatre to enable debug logging. You have to modify system.xml (in the config folder) directly.
justpig 27 Posted April 15, 2016 Posted April 15, 2016 Thanks. Here is the log file. theater-63596318493.txt
babgvant 143 Posted April 15, 2016 Posted April 15, 2016 "Couldn't get EVR Presenter (babgvant)" explains it. Can you use "Depends" to determine if a dependency is missing? Open Depends drag the dll in from COMObjects\babgvant Click View : Collapse All Click the plus sign for the dll Take a screenshot of the dependencies (e.g. below)
babgvant 143 Posted April 15, 2016 Posted April 15, 2016 That looks good. Are you able to regsvr32 it? Open an escalated cmd prompt and type: Register: regsvr32 pathtoevrpresenter.dll Unregister: regsvr32 pathtoevrpresenter.dll /u
babgvant 143 Posted April 15, 2016 Posted April 15, 2016 Replace Emby.Theater.DirectShow.dll with this one. I've added logging around creating the COM objects.
babgvant 143 Posted April 15, 2016 Posted April 15, 2016 Did that, same result. I just added logging to provide more information around what's going wrong. Please provide the ET log.
justpig 27 Posted April 15, 2016 Posted April 15, 2016 Here is the latest log theater-63596325283.txt
babgvant 143 Posted April 15, 2016 Posted April 15, 2016 2016-04-15 13:56:35.0242 Debug URCOMLoader: Load: EVR Presenter (babgvant) Version: 1.0.0.82016-04-15 13:56:35.1121 Debug URCOMLoader: CreateInstance EVR Presenter (babgvant): 02016-04-15 13:56:35.1121 Debug URCOMLoader: Got Object System.__ComObject from 5325df1c-6f10-4292-b8fb-be855f99f88a2016-04-15 13:56:35.1121 Debug InternalDirectShowPlayer: Got EVR Presenter (babgvant) Looks like it overwrote the 1.0.1.0 CP, can you put it back and try again?
