mystic.bertie 23 Posted February 17, 2016 Posted February 17, 2016 Hi guys, i dont usually use subtitles much but not long ago i managed to get Polish subtitles displaying fine when using the previous version of Emby, 100% of the time. With the new Emby it would only work for 2 out of 5 movies, after a bit of research, the movies that wont display the Polish subtitles actually have internal subtitles. See snapshot below. I have tried the different settings for subtitles 'always' 'default' 'smart' and it wont make a difference. The Polish subtitles are only shown when the movie has no internal subtitles. How can i fix this?
mystic.bertie 23 Posted March 2, 2016 Author Posted March 2, 2016 can admin assist perhaps to lifetime supporter
mystic.bertie 23 Posted March 21, 2016 Author Posted March 21, 2016 any progress on this, its a nuisance having to use another player to play movies with subtitles.
Luke 42242 Posted March 21, 2016 Posted March 21, 2016 Please try a clean install of the latest version by uninstalling your current version. Thanks.
mystic.bertie 23 Posted March 22, 2016 Author Posted March 22, 2016 Good news, reinstalling emby worked, my subtitles are now displaying fine. The CC button is now shown, it was missing before, all in all emby is much faster now, it was a bit slow before and it would hang while waiting on movies to start. It seems fine now. More good news, my screen size is now fixed, madvr and evr+ both work fine now. Yippeee many thanks once again.
nodiaque 62 Posted March 23, 2016 Posted March 23, 2016 I have a similar problem. playing any video with subtitle as srt doesn't work. It was working 3 days ago but suddently, subs aren't working in emby theater. I tried reinstalling theater, no joy. I do have the CC button, but when clicking and selecting subs, nothing change. thank you
mystic.bertie 23 Posted March 23, 2016 Author Posted March 23, 2016 (edited) I have a similar problem. playing any video with subtitle as srt doesn't work. It was working 3 days ago but suddently, subs aren't working in emby theater. I tried reinstalling theater, no joy. I do have the CC button, but when clicking and selecting subs, nothing change. thank you does switching between the video renderer help , i also noticed it wont play unless the subtitle file is the exact same name as the video file. when you uninstall did you remove all traces and settings etc? Edited March 23, 2016 by mystic.bertie
nodiaque 62 Posted March 24, 2016 Posted March 24, 2016 The problem is with WMP, since ebt is using wmp. When using WMP, I get the same result, no subtitle for a particular set of file. They have embeded SRT file. Those with embeded ASS file work, and the external SRT also work (I manage to fix the other, but not that one). Using MPC-HC, no problem.
mystic.bertie 23 Posted March 24, 2016 Author Posted March 24, 2016 I cant suggest anything more as im using external srt files. I dont know if internal subs would work or not.
justpig 27 Posted March 24, 2016 Posted March 24, 2016 I am having similar problems with embedded srt and pgs subtitles not displaying and then crashing when using EVR+.
markle88 15 Posted April 3, 2016 Posted April 3, 2016 @@babgvant topic says it all. SRT files will load on all other clients but not the Windows Emby theater App. Thanks in advance for the help Server - Log.txt theater-63595304827.txt
djonnie 14 Posted April 5, 2016 Posted April 5, 2016 Are you running the new Emby Theater? There are issues playing SRT files when using EVR+. On MadVR it should work fine, but not every computer has enough power to playback using MadVR.
markle88 15 Posted April 5, 2016 Posted April 5, 2016 Yeah I am using the new Emby Theater. I am using EVR+ because madvr playback is very jumpy. EVR+ was working fine until a couple of days ago. Any suggestions?
LqHnyBear 24 Posted April 6, 2016 Posted April 6, 2016 I'm having the same issue. Subtitle won't display with EVR+ and although MadVR works on my system the video get shifted up so there is a huge black bar on the bottom and the top of the video is cut off when I use MadVR.
feardamhan 6 Posted April 8, 2016 Posted April 8, 2016 So MadVR works for me....no black bar. But jumpy as others mention. No perfect answer yet. EVR+ just stops playback as soon as it hits a subtitle in the srt file
LqHnyBear 24 Posted April 9, 2016 Posted April 9, 2016 Can someone provide a sample video? Thanks I sent one to babgvant in a PM. Maybe you can get it from him.
feardamhan 6 Posted April 9, 2016 Posted April 9, 2016 (edited) Try this. First 60 seconds of Hundred Code Ep3. There is a subtitle kicks in within 5 seconds, which with EVR+ on my system means it stops playback and returns to the episode info in the library Two files. mkv and external srt https://www.dropbox.com/sh/erj9wqaf7dva3gq/AAAaHHc_ZFR3ZgKl5q0_2cDwa?dl=0 Edited April 9, 2016 by feardamhan
babgvant 143 Posted April 11, 2016 Posted April 11, 2016 Try this. First 60 seconds of Hundred Code Ep3. There is a subtitle kicks in within 5 seconds, which with EVR+ on my system means it stops playback and returns to the episode info in the library Two files. mkv and external srt https://www.dropbox.com/sh/erj9wqaf7dva3gq/AAAaHHc_ZFR3ZgKl5q0_2cDwa?dl=0 I can't reproduce this issue. I get the first subtitle (~1s in), then the 2nd (at about 1m in), then the video ends (which is right since the sample is 1m 7s). If you look at the event log do you see any WER messages?
lorac 119 Posted April 12, 2016 Posted April 12, 2016 (edited) EVR+ is not showing subtitles in 2.18 on a fresh install. MADVR does. EVR+ is very buggy today. Episodes will suddenly skip ahead two shows and movies will play for a bit and then go back to the main movie screen. Very odd. MADVR seems to always play subtitles though even through I have it configured for SMART. Edited April 12, 2016 by lorac
babgvant 143 Posted April 12, 2016 Posted April 12, 2016 EVR+ is not showing subtitles in 2.18 on a fresh install. MADVR does. EVR+ is very buggy today. Episodes will suddenly skip ahead two shows and movies will play for a bit and then go back to the main movie screen. Very odd. MADVR seems to always play subtitles though even through I have it configured for SMART. I don't see how a custom presenter would control playback in the way you describe. It's doesn't manage the graph in that way (actually doesn't touch it at all). If you could provide a log with debug level logging enabled I can have a look. Without a log, reports like this aren't that useful.
