DParsons 4 Posted April 2, 2016 Posted April 2, 2016 The app is very well done and works perfectly while I'm at home on the same network as my server, but it will not stream remotely. I've tried to create a new server with the same ddns information that I connect remotely to my content with a PC, but it always says "it is not able to connect to the selected server right now please ensure it is running and try again". Should the server settings be the same as my ddns or is there some other method to connect to my home server with the Android mobile app? I'm also connecting via wifi from anywhere I have wifi access.
Luke 42243 Posted April 2, 2016 Posted April 2, 2016 hi, does the mobile web app work in chrome? is this http or https?
DParsons 4 Posted April 3, 2016 Author Posted April 3, 2016 I can connect the app using chrome on my android with the regular remote access address: http://192.168.1.2:8096. I'm at home now testing it while using the chrome mobile app, and it's working as well, but the regular emby mobile app will also connect while I'm at home. It's just normal http as far as I'm aware although now that you mention https I do use a chrome extension called https everywhere. It's possible that extension may be causing some sort of error since you mentioned https that is the first thing that comes to mind now. If you can let me know if I should be able to connect my emby mobile for android app by creating a new server with my ddns info: http://dspstream.duckdns.org:8096/emby. If that should work then I would say that it must have something to do with the https extension.
DParsons 4 Posted April 4, 2016 Author Posted April 4, 2016 Hello I've disabled the 'https everywhere' addon but it is the same. It just tells me that 'we're unable to connect to the selected server'. I guess that must not be what is happening then.
bluemonkey07 590 Posted April 4, 2016 Posted April 4, 2016 (edited) Why do you have /emby at the end of the duckdns address? Have you followed the connectivity wiki and setup port forwarding to your server? Is your server set to have a static ip? Edited April 4, 2016 by Vidman
DParsons 4 Posted April 4, 2016 Author Posted April 4, 2016 (edited) That is what Emby says the address is under 'remote access'. Everything remote works if I'm accessing Emby from a PC it's only the Android Mobile app that is having an issue connecting remotely. Everything else is fine as far as remote access via a PC is concerned so I would have to say that yes all connectivity setup steps have been taken. I do have a static IP address setup. Edited April 4, 2016 by DParsons
Luke 42243 Posted April 5, 2016 Posted April 5, 2016 it says that on the server dashboard? is it because you may have configured a custom external address that is possibly not correct?
DParsons 4 Posted April 5, 2016 Author Posted April 5, 2016 Hello Luke, Here are some screen shots of the settings I'm using.
Solution bluemonkey07 590 Posted April 5, 2016 Solution Posted April 5, 2016 (edited) You need to change that external wan address to just "dspstream.duckdns.org" the rest is added automatically by the server which is why you see the port 8096 twice in the first screenshot And /emby is not part of the url Edited April 5, 2016 by Vidman 2
Luke 42243 Posted April 5, 2016 Posted April 5, 2016 Yup, he's right. This is good info though. I can have the config page automatically correct this in the future.
DParsons 4 Posted April 5, 2016 Author Posted April 5, 2016 Thanks vidman that did the trick. Now I need to renew my premier subscription so I can access the full guide.☺
