dejavux2 47 Posted April 1, 2016 Posted April 1, 2016 Hello, I can't seem to get rid of this "Channels" that's been added to Emby for WMC. I don't want it 'inline' or 'separate'.....don't want it at all, because there is nothing in it....
ebr 16332 Posted April 1, 2016 Posted April 1, 2016 You must have some sort of channel plug-in installed on your server.
dejavux2 47 Posted April 1, 2016 Author Posted April 1, 2016 No Channel plug-ins installed. Only plug-ins are: Auto Box Sets Server Configuration Backup ServerWMC Trailers
dejavux2 47 Posted April 1, 2016 Author Posted April 1, 2016 (edited) I uninstalled Trailers, and the "Channels" entry point is now gone. But I don't understand. Trailers - plays trailers before movies start, causes a "Channels" entry point to appear in Emby WMC, but when you go into "Channels" it says No Items. Is that normal? I like the trailers, but not a blank entry point. Edited April 1, 2016 by dejavux2
speechles 2062 Posted April 1, 2016 Posted April 1, 2016 It shouldnt be blank. It should have items in it, depending on if you use grouping or inline views for channels. You may have exposed a ghost in the machine. Sent from my Nexus 7 using Tapatalk
Teddy 100 Posted April 2, 2016 Posted April 2, 2016 (edited) Luke can confirm it, but with Emby Server 3.0.5911 Release the channels are empty from Emby WMC . I'm waiting too for next release fix the issue. Edited April 2, 2016 by Teddy
