Nazgulled 11 Posted March 30, 2016 Posted March 30, 2016 The Trakt plugin currently scrobbles when one starts or stops playing a video a file. But it does nothing for actions like: Fast-forward or rewind Stop playback for later resume So, you could fast-forward a bit and the progress bar on the Trakt user profile won't be updated to reflect that change (this is a minor problem because you stop playing, the scrobble will also stop. But when you stop playing something in the middle to resume at a later time, when you start resuming the playback, scrobble position will be from the start like you've just started playing that video file from the beginning, which is not true. Not sure if this can be improved (maybe the Trakt API is limited on this regard, I wouldn't know). But here's a suggestion to make some improvements to scrobbling progress changes.
