Error: Connection Refused
Tried connecting remotely, no luck. Tried connecting on machine using localhost or IP, no luck. Log showing error:
2016-03-28 14:39:49.5512 Error App: Error creating SimpleInjector.ActivationException: No registration for type WebSocketNotifier could be found and an implicit registration could not be made. The constructor of type WebSocketNotifier contains the parameter with name 'notificationsRepo' and type INotificationsRepository that is not registered. Please ensure INotificationsRepository is registered, or change the constructor of WebSocketNotifier. ---> SimpleInjector.ActivationException: The constructor of type WebSocketNotifier contains the parameter with name 'notificationsRepo' and type INotificationsRepository that is not registered. Please ensure INotificationsRepository is registered, or change the constructor of WebSocketNotifier.
I have rebooted emby and computer to no avail.
I have renamed plugins, nope.
I have installed it on top of itself, nope.
Update: Just had a popup: Unhandled exception: Configuration with key autoorganize not found.
Killed all of the db files in the root of data and it appears to be working.
server-63594772786.txt
Edited by acroninj
Well done, thanks for the update.
