optimalt 10 Posted March 28, 2016 Posted March 28, 2016 That is really too bad [emoji20]Trying to follow.. [emoji14]Does this mean that it's likley that people (in countries where there is no HDHomerun) will not be able to watch football games or the upcoming olympics in high quality in ET AND stream to an iphone? Even though both works with different boxes ticked? Skickat från min SM-G920F via Tapatalk
jds828 24 Posted March 28, 2016 Posted March 28, 2016 @pünktchen Just noticed something this morning. My guide was showing the wrong channel order so I checked the plugin. When I first opened the plugin it had the spinning circle and not showing the red or green writing to say it was connected to MPExtended. As soon as I clicked save and test, the circle went away and the green "Connected" came up. When I checked the channel group it had defaulted to the first group in MP (Entertainment) I had to set it back to the group I made and run the EPG updater in Emby. The physical server or Emby server hadn't restarted and the TV was working Ok, Let me know if you want any logs and I'll send them over to you. Thanks
pünktchen 1410 Posted March 28, 2016 Author Posted March 28, 2016 Trying to follow.. [emoji14] Does this mean that it's likley that people (in countries where there is no HDHomerun) will not be able to watch football games or the upcoming olympics in high quality in ET AND stream to an iphone? Even though both works with different boxes ticked? Skickat från min SM-G920F via Tapatalk That's not a fault of the plugin! 1
optimalt 10 Posted March 28, 2016 Posted March 28, 2016 That's not a fault of the plugin!I'm not saying it is - just trying to understand. Skickat från min SM-G920F via Tapatalk
pünktchen 1410 Posted March 28, 2016 Author Posted March 28, 2016 @pünktchen Just noticed something this morning. My guide was showing the wrong channel order so I checked the plugin. When I first opened the plugin it had the spinning circle and not showing the red or green writing to say it was connected to MPExtended. As soon as I clicked save and test, the circle went away and the green "Connected" came up. When I checked the channel group it had defaulted to the first group in MP (Entertainment) I had to set it back to the group I made and run the EPG updater in Emby. The physical server or Emby server hadn't restarted and the TV was working Ok, Let me know if you want any logs and I'll send them over to you. Thanks I've seen this also recently. I think i have to remove the connection validation in the config page...
optimalt 10 Posted March 28, 2016 Posted March 28, 2016 Looks other tv-plugins are struggeling with similar issues Skickat från min SM-G920F via Tapatalk
jds828 24 Posted March 28, 2016 Posted March 28, 2016 I've seen this also recently. I think i have to remove the connection validation in the config page... Ok thanks. It's certainly not a big issue or causing playback problems. Just wanted to let you know any issues as I see them. 1
pünktchen 1410 Posted March 28, 2016 Author Posted March 28, 2016 Looks other tv-plugins are struggeling with similar issues Skickat från min SM-G920F via Tapatalk I have a theory about this [emoji55]
Luke 42237 Posted March 28, 2016 Posted March 28, 2016 No it doesn't mean that because direct play could still be possible. I know dvb and server wmc support that
optimalt 10 Posted March 28, 2016 Posted March 28, 2016 No it doesn't mean that because direct play could still be possible. I know dvb and server wmc support that"That" as in direct play to ET and works with iOS? Skickat från min SM-G920F via Tapatalk
Luke 42237 Posted March 28, 2016 Posted March 28, 2016 iOS does not have the same format support as Emby Theater so it's a little different. There are a lot of factors that affect whether it will direct play such as bandwidth and network connection, bitrate, etc. The point is the plugins expose the stream so that it can be direct played if all of the requirements line up. 1
pünktchen 1410 Posted March 28, 2016 Author Posted March 28, 2016 (edited) No it doesn't mean that because direct play could still be possible. I know dvb and server wmc support thatThe problem is, if i deliver mediainfo (that's needed for direct play and is working fine in Android and Theater) the iOS app refuses to play the transcoded stream, but it works in Chrome. Edited March 28, 2016 by pünktchen
pünktchen 1410 Posted March 29, 2016 Author Posted March 29, 2016 @@jds828 and @@optimalt if you both like to try Emby server dev version with "Direct Playback" in the plugin enabled?
jds828 24 Posted March 29, 2016 Posted March 29, 2016 (edited) Tried what you said but IOS starts then stops no matter if you use 0 or 1500. I'm running the beta of Emby IOS (17) @@Luke, could that be an issue? ET v2 seems ok Let me know if you want me to try any other settings Edited March 29, 2016 by jds828
pünktchen 1410 Posted March 29, 2016 Author Posted March 29, 2016 Tried what you said but IOS starts then stops no matter if you use 0 or 1500. I'm running the beta of Emby IOS (17) @@Luke, could that be an issue? ET v2 seems ok Let me know if you want me to try any other settings No other tests needed. I thought something has changed in regard to transcoding, but maybe i'm wrong...Btw. 0 doesn't disable mediainfo anymore (that was only in the test version here), it's "enable direct playback" and "enable direct streaming" - without that no mediainfo.
jds828 24 Posted March 29, 2016 Posted March 29, 2016 (edited) Ok, I just took it off as Android Mobile also stopped working. Problem now is the backup of my server auto updates to the test plugin, Can that be turned off? Thanks EDIT: Forget the above. Back on beta server with latest plugin and all working again. Edited March 29, 2016 by jds828 1
optimalt 10 Posted March 30, 2016 Posted March 30, 2016 Tried what you said but IOS starts then stops no matter if you use 0 or 1500. I'm running the beta of Emby IOS (17) @@Luke, could that be an issue? ET v2 seems ok Let me know if you want me to try any other settings Got the same results unfortunatly. Except Android is working for me. Thank you for your hard work trying to solve this pünktchen!
jds828 24 Posted March 30, 2016 Posted March 30, 2016 Got the same results unfortunatly. Except Android is working for me. Thank you for your hard work trying to solve this pünktchen! I forgot to mention that I only use Android Mobile over 4G/LTE. The main reason for this is that I don't use my phone at home for watching media but I do use it when I'm out and about. I was having another look at the IOS app. When I use anything other than 0 in the timer the seek bar in the video shows. By the looks of it, what you set is the time you get. 1500 gives 1.5 seconds of video then it stops, 3000 gives 3 seconds. you'd think that zero would show no video. Does this give any clues to playback issues? The latest version of the plugin seems to be holding the channel group now and the spinning circle has gone from the plugin settings page.
pünktchen 1410 Posted March 30, 2016 Author Posted March 30, 2016 I was having another look at the IOS app. When I use anything other than 0 in the timer the seek bar in the video shows. By the looks of it, what you set is the time you get. 1500 gives 1.5 seconds of video then it stops, 3000 gives 3 seconds. you'd think that zero would show no video. Does this give any clues to playback issues? The "delay" is really just a pause in the code before the stream gets analyzed. Otherwise mediainfo sometimes returns false or empty values... Please test the attached plugin!
pünktchen 1410 Posted March 30, 2016 Author Posted March 30, 2016 @@jds828 and @@optimalt thanks for your cooperation and patience with this problem!
jds828 24 Posted March 30, 2016 Posted March 30, 2016 @@jds828 and @@optimalt thanks for your cooperation and patience with this problem! It's not a problem at all. We all have slightly different hardware, you're working on the plugin, the outcome can only be a better system. I'm sure there will be a lot more bumps in the road before it's 100%. I've installed the new .dll. Anything you want setting or testing with it?
pünktchen 1410 Posted March 30, 2016 Author Posted March 30, 2016 It's not a problem at all. We all have slightly different hardware, you're working on the plugin, the outcome can only be a better system. I'm sure there will be a lot more bumps in the road before it's 100%. I've installed the new .dll. Anything you want setting or testing with it? As usual - iOS app with delay 1500, direct playback, direct streaming and transcoding, all three enabled.
jds828 24 Posted March 30, 2016 Posted March 30, 2016 Looking good on IOS. Set to 1500 with the options ticked as above and the ipad played HD & SD TV fine. It wouldn't play on Android Mobile though. It could be my 4G or any number of things so I'll keep looking into it and try other settings. Thanks again for the work you're doing on this.
pünktchen 1410 Posted March 30, 2016 Author Posted March 30, 2016 Looking good on IOS. Set to 1500 with the options ticked as above and the ipad played HD & SD TV fine. It wouldn't play on Android Mobile though. It could be my 4G or any number of things so I'll keep looking into it and try other settings. Thanks again for the work you're doing on this. It plays on iOS, really? [emoji3] Let's wait for @@optimalt before i put this online.
jds828 24 Posted March 30, 2016 Posted March 30, 2016 It certainly did. I'm on the beta IOS so you do right to see what it does on the stable version... if that's what @optimalt is using.
