skidmarks 199 Posted December 26, 2013 Posted December 26, 2013 (edited) First off Merry Christmas! Hope everyone had a great one... When i go to view my pictures in MBC i get the error popping up saying "value was either too large or too small for int32". My logs are clean and no new lines appear at the time when i try to view said pictures. Not sure what is goin on. When i try pictures with my android and my Roku it just says the folder doesnt exist. Any ideas what might be going on? I have a lot of pictures in this folder... Thanks in advance (said pictures folder was working perfectly fine in MBC and Android App last week) Edited December 26, 2013 by skidmarks
ebr 16354 Posted December 26, 2013 Posted December 26, 2013 Error popping up where? How? Please post a MBC log and the windows event error if the program is actually shutting down (see how to report a problem for instructions).
skidmarks 199 Posted December 26, 2013 Author Posted December 26, 2013 (edited) Picture Link: http://www.dropbox.com/s/7bwl9phdpdtht1e/Screenshot%202013-12-25%2023.01.06.png MBC Log: http://www.dropbox.com/s/ux9hypu0n94mrnk/MBClassic-221220139a47452522a94593b29dafe532672e2c.log Server Log: http://www.dropbox.com/s/0j04gn2uzhbi0s5/server-63523585900.log MBC never shuts down, the error pops up for maybe 3 seconds and then just a blank pictures page. I removed the pictures folder from the config and then put it back, but same issue. MBC does not freeze and i can go on to select other items (movies, music, etc). Thanks in Advance and thanks for the support! Edited December 26, 2013 by skidmarks
DGMayor 90 Posted December 26, 2013 Posted December 26, 2013 You're image isn't MBC, it's the web client. http://mediabrowser.tv/community/index.php?/topic/3318-web-client-error-viewing-music-album-list/ I'm having the same issue with music album view.
ebr 16354 Posted December 26, 2013 Posted December 26, 2013 Yeah, that isn't MBC. MB Classic is the Media Center client.
skidmarks 199 Posted December 26, 2013 Author Posted December 26, 2013 Think possibly its a folder that is too large or something of that nature? Instead of looking at my entire pictures directory i set it up to look at a much smaller folder and that seems to be ok. I am talking 50 pictures as apposed to 5000. Just putting it out there. Last week i could see and look at the entire pictures collection. Yah my bad with calling it MBC, but when you have the old black holes in the brain (from MS) stuff like this happens... You should see me in the store standing in front of too many choices! Thanks guys!
