Nutts 0 Posted March 25, 2016 Posted March 25, 2016 Hi,, Bought this app some years ago now reinstalled today due to wiping tablet (GT-P7510) which is now running android 4.0.4 installed from play store. When app is launched screen goes black and a second it goes white then black again then crashes. Have uploaded a couple of the client logs Cheers nutts 1aef28f4-f5c4-44e9-8385-db5a8b5856f5.log 03efb6f2-8f49-4ce1-81b2-2b19eb6d0323.log 4a35bba3-af3e-4a41-8c0c-619c08c220d1.log
Luke 42243 Posted March 25, 2016 Posted March 25, 2016 Hi, apologies, yes. I think there are some issues with really old versions of android that we need to look at.
Nutts 0 Posted March 26, 2016 Author Posted March 26, 2016 Ok no problems thanks for the response I found a KitKat ROM for the tablet installed works fine. Thanks
michaelmrc 0 Posted October 3, 2016 Posted October 3, 2016 Hi, apologies, yes. I think there are some issues with really old versions of android that we need to look at. so is there a fix to this issue. i have just downloaded emby for my samsung galaxy tab running android 4.04 and it does the exact same thing. looks like its starting to play then crashes and back to home screen. need a fix please.
Luke 42243 Posted October 3, 2016 Posted October 3, 2016 4.04? A couple months ago we re-targeted the app to require 4.1 jellybean. I'm guessing the play store is still allowing you to get the last known version that supported 4.0. I will have to look at turning that off. I'm sorry. What I would suggest doing though is using the Chrome browser.
michaelmrc 0 Posted October 3, 2016 Posted October 3, 2016 do you mean using chrome browser as the media client? how does this work?
Luke 42243 Posted October 4, 2016 Posted October 4, 2016 Just open the browser on your device and visit http://app.emby.media I think you'll like it
