Recordings stuck as Active Recordings
earthtorob
I'm using the power supply that came with the unit.   I noticed that the unit rebooted when Emby tried to  record using both tuners.  I think this is the problem.
So.....turns out that my problem isn't Emby and shouldn't be on this thread.  IDK if others are having the same problem with HDHomerun's.  Or if their problem is with Emby.
Thanks for the help guys.  I might see if I can dig up a more powerful power supply and see if that helps.
@@earthtorob
Depending on the age of the unit, silicondust did replace some connect power supplies under a sort of recall/early failure problem.
Otherwise, if you can't find one easily, I know they sell new power supplies that wasn't a bad price if I recall.
earthtorob
Thanks Erik....and everyone.
  • 3 weeks later...
(Copied to this thread after posted in error to other section)
I had another active recording stuck just this evening. The HDhomerun's are fine, no resets as had been happening and all tuners released and available so it looks like the Beta firmware has fixed any problems on that end, but Emby had to be restarted to recognize the recording was no longer active but looks like it recorded perfectly. When i looked initially the file size was way to small and looked like it had failed, but when i stopped emby the file showed full size and i played it to verify.
The recording was for "Kevin Can't Wait".
Log PM'd for you @@Luke
Another example from last night. This time however, only resulted in a 1 minute recording and failed after that.
Just to isolate @@Luke could this be complicated because im running as a service? i can run from the tray for a bit to see.
4-11 21:29:59.8322 Info HttpClient: HttpClientManager GET: http://192.168.123.145/discover.json
2017-04-11 21:29:59.8634 Info HttpClient: HttpClientManager GET: http://192.168.123.145/discover.json
2017-04-11 21:29:59.8791 Info App: Streaming Channel hdhr_7.1_577bd4328f2afbdcee14f43e9a05659d
2017-04-11 21:29:59.8791 Info App: Live stream c9dbc5d14df8499a80e156d67e249626native_9098a73d5f0a41a094a99f31435d5a51_d5fb11d03948d3d03b75890785fc579b consumer count is now 2
2017-04-11 21:29:59.8947 Debug LibraryMonitor: New file refresher created for \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary
2017-04-11 21:29:59.8947 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\Season 1
2017-04-11 21:29:59.8947 Info App: Beginning recording. Will record for 31.0017542983333 minutes.
2017-04-11 21:29:59.8947 Info App: Writing file to path: \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\Season 1\Imaginary Mary S01E03 The Parent-y Trap.ts
2017-04-11 21:29:59.8947 Info App: Opening recording stream from tuner provider
2017-04-11 21:29:59.8947 Info HttpClient: HttpClientManager GET: http://127.0.0.1:8096/LiveTv/LiveStreamFiles/354a730d358848738d3e0188fecc9ac5/stream.ts
2017-04-11 21:29:59.8947 Info HttpServer: HTTP GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/354a730d358848738d3e0188fecc9ac5/stream.ts. UserAgent: Emby/3.0
2017-04-11 21:29:59.9441 Info App: Opened recording stream from tuner provider
2017-04-11 21:29:59.9441 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\Season 1\Imaginary Mary S01E03 The Parent-y Trap.ts
2017-04-11 21:30:00.1160 Info App: Copying recording stream to file \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\Season 1\Imaginary Mary S01E03 The Parent-y Trap.ts
2017-04-11 21:30:00.9441 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\Season 1\Imaginary Mary S01E03 The Parent-y Trap.ts
2017-04-11 21:31:00.1232 Debug LibraryMonitor: Timer stopped.
2017-04-11 21:31:00.1389 Info LibraryMonitor: Series (\\SERVER\Emby Server - TV Recordings$\Series) will be refreshed.
2017-04-11 21:31:00.3420 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Fresh Off the Boat\Season 3\Fresh Off the Boat S03E19 Driving Miss Jenny.ts
2017-04-11 21:31:00.3420 Info App: Recording stopped: \\SERVER\Emby Server - TV Recordings$\Series\Fresh Off the Boat\Season 3\Fresh Off the Boat S03E19 Driving Miss Jenny.ts
2017-04-11 21:31:00.3420 Info App: Live stream dbe9a85c1e49442da99a915802b3a8e2_native_9098a73d5f0a41a094a99f31435d5a51_d5fb11d03948d3d03b75890785fc579b consumer count is now 1
2017-04-11 21:31:00.4045 Error App: Error in QueueStream
	*** Error Report ***
	Version: 3.2.12.0
	Command line: C:\Users\Administrator\AppData\Roaming\Emby-Server\system\MediaBrowser.ServerApplication.exe -service
	Operating system: Microsoft Windows NT 6.2.9200.0
	64-Bit OS: True
	64-Bit Process: True
	Processor count: 4
	Program data path: C:\Users\Administrator\AppData\Roaming\Emby-Server
	Application directory: C:\Users\Administrator\AppData\Roaming\Emby-Server\system
	System.IO.IOException: Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host
	   at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
	   at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size)
	   --- End of inner exception stack trace ---
	   at SocketHttpListener.Net.ResponseStream.<WriteAsync>d__28.MoveNext()
	--- End of stack trace from previous location where exception was thrown ---
	   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
	   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
	   at Emby.Server.Implementations.LiveTv.TunerHosts.QueueStream.<StartInternal>d__19.MoveNext()
	InnerException: System.Net.Sockets.SocketException
	System.Net.Sockets.SocketException (0x80004005): An existing connection was forcibly closed by the remote host
2017-04-11 21:31:00.4045 Error HttpServer: Error processing request
	Version: 3.2.12.0
	64-Bit OS: True
	Processor count: 4
	   at MediaBrowser.Api.Playback.Progressive.ProgressiveFileCopier.<WriteToAsync>d__19.MoveNext()
	   at Emby.Server.Implementations.Services.ResponseHelper.<WriteToResponseInternal>d__1.MoveNext()
	   at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__15.MoveNext()
	   at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__75.MoveNext()
2017-04-11 21:31:00.4045 Info HttpServer: HTTP Response 500 to 127.0.0.1. Time: 1860391ms. http://127.0.0.1:8096/LiveTv/LiveStreamFiles/354a730d358848738d3e0188fecc9ac5/stream.ts
2017-04-11 21:31:00.4826 Error App: Error opening live stream:
	Version: 3.2.12.0
	64-Bit OS: True
	Processor count: 4
	System.NullReferenceException: Object reference not set to an instance of an object.
	   at Emby.Server.Implementations.LiveTv.TunerHosts.MulticastStream.<CopyUntilCancelled>d__5.MoveNext()
	   at Emby.Server.Implementations.LiveTv.TunerHosts.HdHomerun.HdHomerunHttpStream.<>c__DisplayClass11_0.<<StartStreaming>b__0>d.MoveNext()
2017-04-11 21:31:00.9670 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\Season 1
2017-04-11 21:31:03.3089 Debug App: Running EpisodeNfoProvider for \\SERVER\Emby Server - TV Recordings$\Series\The Middle\Season 8\The Middle S08E19 The Confirmation.ts
2017-04-11 21:31:03.3245 Debug App: Saving \\SERVER\Emby Server - TV Recordings$\Series\The Middle\Season 8\The Middle S08E19 The Confirmation.ts to database.
2017-04-11 21:31:03.3557 Debug App: Running SeriesNfoProvider for \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary
2017-04-11 21:31:03.3714 Debug App: Running TvdbSeriesProvider for \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary
2017-04-11 21:31:03.3714 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/api/GetSeries.php?seriesname=Imaginary+Mary&language=en
2017-04-11 21:31:03.8920 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/api/B89CE93890E9419B/series/311915/all/en.zip
2017-04-11 21:31:04.4037 Debug App: Running OmdbItemProvider for \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary
2017-04-11 21:31:04.4037 Info HttpClient: HttpClientManager GET: https://www.omdbapi.com/?plot=full&r=json&t=Imaginary+Mary&type=series
2017-04-11 21:31:04.6381 Debug App: OmdbItemProvider returned no metadata for \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary
2017-04-11 21:31:04.6381 Debug App: Running MovieDbSeriesProvider for \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary
2017-04-11 21:31:04.6381 Info HttpClient: HttpClientManager GET: https://api.themoviedb.org/3/tv/find/311915?api_key=f6bd687ffa63cd282b6ff2c6877f2669&external_source=tvdb_id
2017-04-11 21:31:04.8256 Debug App: Throttling Tmdb by 112 ms
2017-04-11 21:31:04.9506 Info HttpClient: HttpClientManager GET: https://api.themoviedb.org/3/tv/70307?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=credits,images,keywords,external_ids,videos,content_ratings&language=en&include_image_language=en,null
2017-04-11 21:31:05.0287 Debug App: Running TvdbSeriesImageProvider for \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary
2017-04-11 21:31:05.0287 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/posters/311915-2.jpg
2017-04-11 21:31:06.3218 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\poster.jpg
2017-04-11 21:31:06.3218 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\poster.jpg
2017-04-11 21:31:06.3218 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/graphical/311915-g2.jpg
2017-04-11 21:31:07.1716 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\banner.jpg
2017-04-11 21:31:07.1716 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary
2017-04-11 21:31:07.1716 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\banner.jpg
2017-04-11 21:31:07.1873 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\banner.jpg
2017-04-11 21:31:07.1873 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/fanart/original/311915-2.jpg
2017-04-11 21:31:08.3284 Info HttpServer: HTTP GET http://192.168.123.50:8096/emby/Users/824f711b49784825b017e884dec877b2/Items?Recursive=true&Limit=3&Filters=IsNotFolder&SortBy=DateCreated&SortOrder=Descending&Ids=f98679416a510e74630a28b9b5161bf8%2Ce9aadf5de69c0889f9ae48d9e5a2d755&MediaTypes=Audio%2CVideo. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) EmbyTheater/2.5.40 Chrome/53.0.2785.143 Electron/1.4.15 Safari/537.36
2017-04-11 21:31:08.3441 Info HttpServer: HTTP Response 200 to 192.168.123.101. Time: 16ms. http://192.168.123.50:8096/emby/Users/824f711b49784825b017e884dec877b2/Items?Recursive=true&Limit=3&Filters=IsNotFolder&SortBy=DateCreated&SortOrder=Descending&Ids=f98679416a510e74630a28b9b5161bf8%2Ce9aadf5de69c0889f9ae48d9e5a2d755&MediaTypes=Audio%2CVideo
2017-04-11 21:31:09.2366 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\fanart.jpg
2017-04-11 21:31:09.2366 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary
2017-04-11 21:31:09.2366 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\fanart.jpg
2017-04-11 21:31:09.2522 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\fanart.jpg
2017-04-11 21:31:09.2522 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/fanart/original/311915-1.jpg
2017-04-11 21:31:10.4142 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrafanart\fanart1.jpg
2017-04-11 21:31:10.4142 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary
2017-04-11 21:31:10.4142 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrafanart
2017-04-11 21:31:10.4298 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrafanart\fanart1.jpg
2017-04-11 21:31:10.4298 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrathumbs\thumb1.jpg
2017-04-11 21:31:10.4454 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary
2017-04-11 21:31:10.4454 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrathumbs
2017-04-11 21:31:10.4454 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrathumbs\thumb1.jpg
2017-04-11 21:31:10.4610 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/fanart/original/311915-5.jpg
2017-04-11 21:31:13.6373 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrafanart\fanart2.jpg
2017-04-11 21:31:13.6373 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrafanart
2017-04-11 21:31:13.6373 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrafanart\fanart2.jpg
2017-04-11 21:31:13.6529 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrathumbs\thumb2.jpg
2017-04-11 21:31:13.6529 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrafanart\fanart2.jpg
2017-04-11 21:31:13.6529 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrathumbs
2017-04-11 21:31:13.6529 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrathumbs\thumb2.jpg
2017-04-11 21:31:13.6685 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrathumbs\thumb2.jpg
2017-04-11 21:31:13.6685 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/fanart/original/311915-3.jpg
2017-04-11 21:31:16.5317 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrafanart\fanart3.jpg
2017-04-11 21:31:16.5317 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrafanart
2017-04-11 21:31:16.5317 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrafanart\fanart3.jpg
2017-04-11 21:31:16.5473 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrathumbs\thumb3.jpg
2017-04-11 21:31:16.5473 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrafanart\fanart3.jpg
2017-04-11 21:31:16.5473 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrathumbs
2017-04-11 21:31:16.5473 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrathumbs\thumb3.jpg
2017-04-11 21:31:16.5630 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrathumbs\thumb3.jpg
2017-04-11 21:31:16.5630 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/fanart/original/311915-6.jpg
2017-04-11 21:31:17.9390 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrafanart\fanart4.jpg
2017-04-11 21:31:17.9390 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrafanart
2017-04-11 21:31:17.9547 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrafanart\fanart4.jpg
2017-04-11 21:31:17.9703 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrathumbs\thumb4.jpg
2017-04-11 21:31:17.9703 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrafanart\fanart4.jpg
2017-04-11 21:31:17.9703 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrathumbs
2017-04-11 21:31:17.9703 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrathumbs\thumb4.jpg
2017-04-11 21:31:17.9859 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\extrathumbs\thumb4.jpg
2017-04-11 21:31:17.9859 Debug App: Running FanartSeriesProvider for \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary
2017-04-11 21:31:17.9859 Info HttpClient: HttpClientManager GET: https://webservice.fanart.tv/v3/tv/311915?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4
2017-04-11 21:31:18.2203 Debug JsonSerializer: Deserializing file E:\Emby Server - Cache\Cache\cache\fanart-tv\311915\fanart.json
2017-04-11 21:31:18.2359 Info HttpClient: HttpClientManager GET: https://assets.fanart.tv/fanart/tv/311915/hdclearart/imaginary-mary-58b84e0025528.png
2017-04-11 21:31:19.0768 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\clearart.png
2017-04-11 21:31:19.0768 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary
2017-04-11 21:31:19.0768 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\clearart.png
2017-04-11 21:31:19.0768 Info HttpClient: HttpClientManager GET: https://assets.fanart.tv/fanart/tv/311915/hdtvlogo/imaginary-mary-58b69c059a664.png
2017-04-11 21:31:19.4915 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\logo.png
2017-04-11 21:31:19.4915 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary
2017-04-11 21:31:19.4915 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\logo.png
2017-04-11 21:31:19.4915 Info HttpClient: HttpClientManager GET: https://assets.fanart.tv/fanart/tv/311915/tvthumb/imaginary-mary-58e10f44ee52f.jpg
2017-04-11 21:31:20.1491 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\landscape.jpg
2017-04-11 21:31:20.1491 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary
2017-04-11 21:31:20.1491 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\landscape.jpg
2017-04-11 21:31:20.1647 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\landscape.jpg
2017-04-11 21:31:20.1804 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/actors/380022.jpg
2017-04-11 21:31:20.9052 Debug ProviderManager: Saving image to E:\Emby Server - Cache\Metadata\metadata\People\S\Stephen Schneider\poster.jpg
2017-04-11 21:31:20.9208 Debug App: Saving E:\Emby Server - Cache\Metadata\metadata\People\S\Stephen Schneider to database.
2017-04-11 21:31:21.5302 Debug ProviderManager: Saving \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary to Nfo.
2017-04-11 21:31:21.5614 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\tvshow.nfo
2017-04-11 21:31:21.5770 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\tvshow.nfo
2017-04-11 21:31:21.5770 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/actors/416622.jpg
2017-04-11 21:31:22.3427 Debug ProviderManager: Saving image to E:\Emby Server - Cache\Metadata\metadata\People\N\Nicholas Coombe\poster.jpg
2017-04-11 21:31:22.3583 Debug App: Saving E:\Emby Server - Cache\Metadata\metadata\People\N\Nicholas Coombe to database.
2017-04-11 21:31:23.0926 Debug ProviderManager: Saving \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary to Nfo.
2017-04-11 21:31:23.0926 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\tvshow.nfo
2017-04-11 21:31:23.1083 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\tvshow.nfo
2017-04-11 21:31:23.1083 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/actors/380023.jpg
2017-04-11 21:31:23.5467 Debug ProviderManager: Saving image to E:\Emby Server - Cache\Metadata\metadata\People\M\Matreya Scarrwener\poster.jpg
2017-04-11 21:31:23.5623 Debug App: Saving E:\Emby Server - Cache\Metadata\metadata\People\M\Matreya Scarrwener to database.
2017-04-11 21:31:24.3904 Debug ProviderManager: Saving \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary to Nfo.
2017-04-11 21:31:24.4060 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\tvshow.nfo
2017-04-11 21:31:24.4217 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\tvshow.nfo
2017-04-11 21:31:24.4217 Debug ProviderManager: Saving \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary to Nfo.
2017-04-11 21:31:24.4373 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\tvshow.nfo
2017-04-11 21:31:24.4373 Debug App: Saving \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary to database.
2017-04-11 21:31:24.4529 Debug App: Running SeasonNfoProvider for \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\Season 1
2017-04-11 21:31:24.4529 Debug App: SeasonNfoProvider returned no metadata for \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\Season 1
2017-04-11 21:31:24.4529 Debug App: Running TvdbSeasonImageProvider for \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\Season 1
2017-04-11 21:31:24.4529 Debug App: Running FanArtSeasonProvider for \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\Season 1
2017-04-11 21:31:24.4529 Debug JsonSerializer: Deserializing file E:\Emby Server - Cache\Cache\cache\fanart-tv\311915\fanart.json
2017-04-11 21:31:24.4529 Debug App: Saving \\SERVER\Emby Server - TV Recordings$\Series\Imaginary Mary\Season 1 to database.
Edited by Erik
