charliekay74 0 Posted December 28, 2013 Author Posted December 28, 2013 (edited) i am only talking about the backdrop issue, which i can take a look at over teamviewer. once that is solved we can move onto mbc. Okay, how can we do the teamviewer session? Edited December 28, 2013 by charliekay74
Luke 42289 Posted December 28, 2013 Posted December 28, 2013 you have to run it and then send me the code
charliekay74 0 Posted December 28, 2013 Author Posted December 28, 2013 I sent you a direct message Gesendet von meinem GT-I9505 mit Tapatalk
charliekay74 0 Posted December 29, 2013 Author Posted December 29, 2013 (edited) third problem: after every reboot of the computer, the server is not working anymore....although there is a tray icon....only complete new installation solves the problem... and after new installation...the backdrop problem is there again.... Edited December 29, 2013 by charliekay74
charliekay74 0 Posted December 29, 2013 Author Posted December 29, 2013 (edited) the backdrop problem is solved. after deleting the folders "extrafanart" und "extrathumbs" in the movie folder, the backdrops appear for every film now there are left two more probs: 1. media browser classic setup fails (i need media browser classic, because here i can use bigger fonts so i can read the details aof the films from the sofa) 2. what can i do, that the server runs properly after rebooting the machine, the option "server runs at startup" i have to choose or do i have to make an entry in the autostart menu? i tried both, but i think nothing works --- Update: the backdrop problem is not solved....now there is again everywhere the same photo in every movie...its too buggy....how many more hours should spend in this....media browser 2.x was fast setup and worked nearly out of the box...let it stay alive Edited December 29, 2013 by charliekay74
ebr 16354 Posted December 29, 2013 Posted December 29, 2013 Google "clear clickonce cache" follow the steps and see if that allows you to install MBC.
Logos302 86 Posted December 29, 2013 Posted December 29, 2013 (edited) don't give up just yet. I am actually surprised that you are having this many issues. Do you have a third party Meta Data fetcher? and yes you should have that server runs at start-up check if you are not running it as a service. Is it possible that he's missing .net 3.51?? I didn't see what OS you are running either. @@ebr he's already tried the clean cache once - rundll32 %windir%\system32\dfshim.dll CleanOnlineAppCache. Edited December 29, 2013 by Logos302
charliekay74 0 Posted December 29, 2013 Author Posted December 29, 2013 (edited) Now success...i went on earlier restore point of windows....no risk no fun...now everything seems to work....also media browser classic setup worked fine...only have to look for the server after reboot...thanks a lot "ebr" and "Luke" for their time and help so far!!! Edited December 29, 2013 by charliekay74
ebr 16354 Posted December 30, 2013 Posted December 30, 2013 Well, that's good and bad. Good that you finally got up and going but bad that we still have no idea what the problem is/was. Let us know if it crops up again. Thx.
Luke 42289 Posted December 30, 2013 Posted December 30, 2013 i teamviewerd with him and he had movies that no backdrops inheriting from a parent. all resolved. i don't know what fixed his mbc install though.
