larrywells 0 Posted March 23, 2016 Posted March 23, 2016 When using Ipvanish (VPN) on a windows 10 laptop with emby server running I can not access anything on my ipad. When I turn off ipvanish i connect fine. No where do I see an option of changing the ports they are using as some suggest. Is there something I'm missing?
Luke 42186 Posted March 23, 2016 Posted March 23, 2016 Hi, welcome. What you can do is change server, and manually enter the address of the server, if it's different from before.
larrywells 0 Posted March 23, 2016 Author Posted March 23, 2016 Change the serve on emby? Not sure I follow
Happy2Play 9800 Posted March 23, 2016 Posted March 23, 2016 It is manual work on your side since your vpn is changing your WAN address you will have to manually put your actual WANIP in "External WAN Address" (Dashboard-Advanced-Hosting). Your only issue is how often your external address changes.
