Adding Movie: Prefix in TV Guide for Movies
My TV Guide provider has an option to add a Movie: prefix and it is very useful unfortunately if I enable it than I get either wrong metadata or none at all. As I use  WMC I have the prefix enabled. In Australian we have about 15 channels and none of them are dedicated movie channels.
Thinking about it this may mean for others that have many movie channels they may get annoyed like I am with NEW prefix so probable the best is if Movie: prefix can be ignored before emby commences searching the movie database.
Thank you
bluemonkey07
The skin helper addon for kodi , which is used for grabbing metadata for items in kodis live TV guide has a setting to ignore a user defined string before searching for exactly this situation and it works well
  • Like 1
