nk786 0 Posted March 20, 2016 Posted March 20, 2016 Not sure why this is happening but under the "Live TV" section, I'm unable to see the reset button on the right hand side of each tuner listed. I haven't changed any user permissions and have checked them as well. Any ideas? Thanks in advance.
Luke 42241 Posted March 20, 2016 Posted March 20, 2016 It's now only displayed if the tv plugin reports the reset feature as supported.
nk786 0 Posted March 20, 2016 Author Posted March 20, 2016 I'm confused, the buttons were there and working fine yesterday :/ I do have some tuners stuck on a couple channels and need to reset them. I'm not able to reset the tuners locally on my htpc because I live in another state now. Is there any way to reset the tuner on the emby web client without the reset button?
Luke 42241 Posted March 20, 2016 Posted March 20, 2016 If you are seeing this then you are running a non-stable version of Emby Server. Thank you for helping to test this pre-release version of Emby.
Luke 42241 Posted March 20, 2016 Posted March 20, 2016 Use the stable release or just be patient. Thanks.
nk786 0 Posted March 20, 2016 Author Posted March 20, 2016 I'm positive I installed the stable release on my windows htpc. Did this change happen yesterday?
nk786 0 Posted March 23, 2016 Author Posted March 23, 2016 I'm also using google chrome to access the web clientÂ
Luke 42241 Posted March 23, 2016 Posted March 23, 2016 Ok, the tv plugin developers have been notified so you may just need to be patient for now until they publish an update. whatever tv software the plugin is connected to probably also has this function so you can just use that on a temporary basis.
nk786 0 Posted March 23, 2016 Author Posted March 23, 2016 ok great thanks. yes, im using serverwmc but is there any way to access that remotely so i can release the tuners?
