pünktchen 1411 Posted March 25, 2016 Posted March 25, 2016 (edited) i had it investigate and fixed in the master and lose the interesting to help here out if i get an new question as answer to my question good luck i am out if you can delete this acount What the hell is going on with you Kai?You are the one who has pushed the Sat/Ip implemention and now if don't get an expected answer you quit? By not taking your code doesn't mean @@Luke doesn't appreciate your help on this. This attitude is probably one of the reasons why your ideas didn't get that much attention from MediaPortal, ArgusTV and NextPVR! Edited March 25, 2016 by pünktchen
Luke 42242 Posted March 25, 2016 Posted March 25, 2016 Be nice. He has been extremely helpful, and I hope he comes back.
pünktchen 1411 Posted March 25, 2016 Posted March 25, 2016 Be nice. He has been extremely helpful, and I hope he comes back.Just wanted to say i'm also not always happy with your answers/no answers (guide loading problem [emoji6] ),but i'm still here because i love the Emby project as a whole!
Guest Diefenthal Posted March 25, 2016 Posted March 25, 2016 (edited) What the hell is going on with you Kai? You are the one who has pushed the Sat/Ip implemention and now if don't get an expected answer you quit? By not taking your code doesn't mean @@Luke doesn't appreciate your help on this. This attitude is probably one of the reasons why your ideas didn't get that much attention from MediaPortal, ArgusTV and NextPVR! diese aussage zeigt nur das du mich nicht kennst .... komisch das ich mit Greame (Npvr er nutzt meinen rtsp stack) oder Prog (von ProgDVB ernutzt den ssdp code) oder so manchen unter anderem mit MM1352000( Mediaportal ) Steve (Epgcollector) einen regen kontakt habe achja und Nico von Argutv will keinen Netzwerk Tuner Support hoffe das ich nun keinen vergessen habe .... wenn ja dann sorry for that und das nur um das Sat>Ip einwenig zu pushen es geht nicht darum ob sie meinen code nutzen oder nicht es geht um eine saubere Implementierung so das jedes gerät dann ohne Probleme dann läuft nur wenn man den code auseinander nimmt was in dem fall ein paar stunden in zeit nehmen kann (denn ich versuche in der regel den code des Entwicklers lauffähig zubekommen) und wenn es dann nach stunden in dem fall 8 nicht zum laufen zubewegen ist und es mit meinem läuft bekommt der dev meinen als reference um selber mal zu schauen habe zwar zugesagt zu helfen aber es sollte nicht mein Lebensinhalt werden somit muss man manchmal eine Reißleine ziehen um anderen helfen zu können SichboPVR nur mal so als Beispiel Edited March 25, 2016 by Diefenthal
rechner123 12 Posted March 25, 2016 Posted March 25, 2016 i had it investigate and fixed in the master and lose the interesting to help here out if i get an new question as answer to my question good luck i am out if you can delete this acount This is too Bad.
pünktchen 1411 Posted March 25, 2016 Posted March 25, 2016 @ Okay dann entschuldige ich mich hiermit offiziell bei dir!!! Von Außen sieht das eben anders für mich aus, da du überall Threads beginnst und dann ist auf einmal Schluß. Kann natürlich nicht wissen was im Hintergrund abläuft... Sorry for german.
Nikolaech 32 Posted April 3, 2016 Posted April 3, 2016 @ Diefenthal ; Luke did it. Thank you both. ES beta 3.0.5925 the parameters are determined automatically. The channels, however yet do not work. Perhaps due to the syntax rtspchannels.m3u. Need to check.
Guest Diefenthal Posted April 3, 2016 Posted April 3, 2016 @ Diefenthal ; Luke did it. Thank you both. ES beta 3.0.5925 the parameters are determined automatically. The channels, however yet do not work. Perhaps due to the syntax rtspchannels.m3u. Need to check. thank @@Luke for that i had nothing todo with it
Luke 42242 Posted April 3, 2016 Posted April 3, 2016 Thank you both. Glad to hear it. Now for the hard part. Given a detected server (url), we need to figure out how to get a list of available channels. 1
Nikolaech 32 Posted April 3, 2016 Posted April 3, 2016 thank @@Luke for that i had nothing todo with it Sat-IP your merit. Let us continue to work all together. 1
Nikolaech 32 Posted April 3, 2016 Posted April 3, 2016 .Given a detected server (url), we need to figure out how to get a list of available channels. Channels finds - does not play. tried #EXTINF:-1,Orion Express - Первый Канал #EXTVLCOPT:program=101 rtsp://localhost:554/?src=1&freq=12640&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=30000&mtype=qpsk&tnr=1,12640,30000,10600,1,1,0,4,2101,1101,101,101,1,0,25,0,7,1,-1&pids=0,16,17,18,20,101,1101,151,2101 #EXTINF:-1,Orion Express - Первый Канал HD #EXTVLCOPT:program=92 rtsp://localhost:554/?src=1&freq=11960&msys=dvbs2&plts=off&fec=35&pol=h&ro=0.35&sr=28800&mtype=8psk&tnr=1,11960,28800,10600,1,0,0,7,2902,1902,902,92,6,0,25,0,15,1,-1&pids=0,16,17,18,20,902,1902,33,2902,3902 #EXTINF:-1,Orion Express - Первый Канал rtsp://localhost:554/?src=1&freq=12640&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=30000&mtype=qpsk&tnr=1,12640,30000,10600,1,1,0,4,2101,1101,101,101,1,0,25,0,7,1,-1&pids=0,16,17,18,20,101,1101,151,2101 #EXTINF:-1,Orion Express - Первый Канал src=1&freq=12640&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=30000&mtype=qpsk&tnr=1,12640,30000,10600,1,1,0,4,2101,1101,101,101,1,0,25,0,7,1,-1&pids=0,16,17,18,20,101,1101,151,2101 does not play.
Nikolaech 32 Posted April 4, 2016 Posted April 4, 2016 (edited) For those who do not know. Recording Service (DVBVierwer) automatically can create upnp and rtsp playlists.rtsp upnp Showing the way Embu.rtspupnpfile .m3u (upnp)I tried in different ways. In all cases, the channels are there, but not playing.Tried to edit and rtsp playlist, leaving only the necessary options.src=1&freq=11800&msys=dvbs2&fec=23&pol=h&sr=28800&pids=0,16,17,18,20,1408,3408,4408 add the tuner M3U (file .m3u (upnp))play OK (only upnp tuner M3U) That's all what I can to help you. Edited April 4, 2016 by Nikolaech
Nikolaech 32 Posted April 4, 2016 Posted April 4, 2016 @Diefenthal At you, the server is running? ES 3.0.5926
Guest Diefenthal Posted April 8, 2016 Posted April 8, 2016 (edited) Glad to see that this project have resumed, Not really sure i had Play on some things but alone is there no way to handle this complex thing (Sparetime Limitation) and i dont mean the solution for emby for that are far far far far away if anyone help to write the code for TS Tables and the descriptos can it be faster an entry is there https://github.com/Diefenthal/SatIp the Main Scan Loop private void worker_DoWork(object sender, DoWorkEventArgs e) { _udpclient = new UdpClient(40000); IPEndPoint remoteEndPoint = new IPEndPoint(IPAddress.Any, 0); while (!worker.CancellationPending) { string source = "1"; string tuning; IniReader reader = new IniReader(_file); var Index = 1; var Count = reader.ReadInteger("DVB", "0", 0); while (Count > Index) { _programMapTables = new Dictionary<int, ProgramMapTable>(); var Current = reader.ReadString("DVB", Index.ToString()); var strArray = Current.Split(new char[] { ',' }); if (strArray[4] == "S2") { tuning = string.Format("src={0}&freq={1}&pol={2}&sr={3}&fec={4}&msys=dvbs2&mtype={5}&plts=on&ro=0.35", source, strArray[0].ToString(), strArray[1].ToLower().ToString(), strArray[2].ToLower().ToString(), strArray[3].ToString(), strArray[5].ToLower().ToString()); } else { tuning = string.Format("src={0}&freq={1}&pol={2}&sr={3}&fec={4}&msys=dvbs&mtype={5}", source, strArray[0].ToString(), strArray[1].ToLower().ToString(), strArray[2].ToString(), strArray[3].ToString(), strArray[5].ToLower().ToString()); } ScanFrequency(tuning,remoteEndPoint); Index++; } } } holds the Session Open void _keepalive_Tick(object sender, EventArgs e) { _rtspDevice.RtspSession.Options(); } Scan one Transponder private void ScanFrequency(string tuning, IPEndPoint remoteEndPoint) { if (string.IsNullOrEmpty(_rtspDevice.RtspSession.RtspSessionId)) { _rtspDevice.RtspSession.Setup(tuning + "&pids=0", _transmissionMode.ToString().ToLower()); } else { _rtspDevice.RtspSession.Play(tuning + "&pids=0"); } _keepalive = new Timer(); _keepalive.Interval = _rtspDevice.RtspSession.RtspSessionTimeToLive; _keepalive.Tick += new EventHandler(_keepalive_Tick); _keepalive.Start(); _rtspDevice.RtspSession.Play("addpids=0"); GetPAT(_udpclient, remoteEndPoint); if (_programAssociationTable != null) { foreach (var program in _programAssociationTable.Programs) { //Say the Sat>IP server we want Receives the ProgramMapTable for Pid x _rtspDevice.RtspSession.Play(string.Format("addpids={0}", program.Pid)); GetPMT(_udpclient, remoteEndPoint, program.Pid); } } //Say the Sat>IP server we want Receives the ServiceDescriptionTable //_rtspDevice.RtspSession.Play("addpids=17"); //GetSDT(_udpclient, remoteEndPoint); _programAssociationTable = null; _programMapTables.Clear(); //_serviceDescriptionTable = null; } Get the ProgramAssociationTable for Transponder private void GetPAT(UdpClient client,IPEndPoint endpoint) { //if (_programAssociationTable == null) // _programAssociationTable = new ProgramAssociationTable(); bool patfound = false; while (!patfound) { var receivedbytes = client.Receive(ref endpoint); //Reads the RTP Header //RtpHeader rtpheader = new RtpHeader(receivedbytes); //Console.WriteLine(rtpheader.ToString()); if ((receivedbytes.Length > 12) && ((receivedbytes.Length - 12) % 188) == 0) { double num9 = (((double)(receivedbytes.Length - 12)) / 188.0) - 1.0; for (double j = 0.0; j <= num9; j++) { byte[] destinationarray = (byte[])Array.CreateInstance(typeof(byte), 188); Array.Copy(receivedbytes, (int)Math.Round((double)(12.0 + (j * 188))), destinationarray, 0, 188); while (_programAssociationTable == null) { if (destinationarray[0] == 0x47 && destinationarray.Length >= 188 && (destinationarray[1] & 15) == 0 && destinationarray[2] == 0x00 && destinationarray[5] == 0x00) { //Reads the TsHeader var tsheader = new TsHeader(destinationarray); //Decode the Table _programAssociationTable = ProgramAssociationTable.Decode(tsheader.PayloadUnitStartIndicator, tsheader.PayLoadStart, destinationarray); Console.Write(_programAssociationTable.ToString()); //Say the Sat>IP server we want not more receives the ProgramAssociationTable _rtspDevice.RtspSession.Play("delpids=0"); _programMapTables = new Dictionary<int, ProgramMapTable>(); patfound = true; } } } } } } Get the Program MapTables(for Each Service from Program Association Table) for Transponder private void GetPMT(UdpClient client,IPEndPoint endpoint, int pid) { //if (_programMapTables == null) // _programMapTables = new Dictionary<int, ProgramMapTable>(); var receivedbytes = client.Receive(ref endpoint); //Reads the RTP Header //RtpHeader rtpheader = new RtpHeader(receivedbytes); //Console.WriteLine(rtpheader.ToString()); if ((receivedbytes.Length > 12) && ((receivedbytes.Length - 12) % 188) == 0) { double num9 = (((double)(receivedbytes.Length - 12)) / 188.0) - 1.0; for (double j = 0.0; j <= num9; j++) { byte[] destinationarray = (byte[])Array.CreateInstance(typeof(byte), 188); Array.Copy(receivedbytes, (int)Math.Round((double)(12.0 + (j * 188))), destinationarray, 0, 188); if ((destinationarray[0] == 0x47 && destinationarray.Length >= 188 && destinationarray[5] == 0x02)) { //Reads the TsHeader var tstheader = new TsHeader(destinationarray); //Console.Write(tstheader.ToString()); //Decode the Table var programMapTable = ProgramMapTable.Decode(tstheader.PayloadUnitStartIndicator, tstheader.PayLoadStart, destinationarray); if (!_programMapTables.ContainsKey(programMapTable.ProgramNumber)) { _programMapTables.Add(programMapTable.ProgramNumber, programMapTable); Console.Write(programMapTable.ToString()); //Say the Sat>IP server we want not more Receives the ProgramMapTable for Pid x _rtspDevice.RtspSession.Play(string.Format("delpids={0}", tstheader.Pid)); } } } } } Get the ServiceDescription Table for Transponder private void GetSDT(UdpClient client, IPEndPoint endpoint) { //if (_serviceDescriptionTable == null) // _serviceDescriptionTable = new ServiceDescriptionTable(); bool sdtfound = false; while (!sdtfound) { var receivedbytes = client.Receive(ref endpoint); //Reads the RTP Header //RtpHeader rtpheader = new RtpHeader(receivedbytes); //Console.WriteLine(rtpheader.ToString()); if ((receivedbytes.Length > 12) && ((receivedbytes.Length - 12) % 188) == 0) { double num9 = (((double)(receivedbytes.Length - 12)) / 188.0) - 1.0; for (double j = 0.0; j <= num9; j++) { byte[] destinationarray = (byte[])Array.CreateInstance(typeof(byte), 188); Array.Copy(receivedbytes, (int)Math.Round((double)(12.0 + (j * 188))), destinationarray, 0, 188); if (destinationarray[0] == 0x47 && destinationarray.Length >= 188 && (destinationarray[1] & 15) == 0 && destinationarray[2] == 0x11 && destinationarray[5] == 0x42) //check if it is a SDT (Service Description Table) destinationarray? { //Reads the TsHeader var tsheader = new TsHeader(destinationarray); //Decode the Table _serviceDescriptionTable = ServiceDescriptionTable.Decode(tsheader.PayloadUnitStartIndicator, tsheader.PayLoadStart, destinationarray); Console.Write(_serviceDescriptionTable.ToString()); //Say the Sat>IP server we want not more Receives the ServiceDescriptionTable _rtspDevice.RtspSession.Play(string.Format("delpids=17")); sdtfound = true; } } } } } dont c&p this code it is very Buggy at time and my rtsp stack made Problems at time too but it Shows you (Luke ) how you get the Rtp/Mpegts parse the Tables to get the Infos for Channel Service Creation Edited April 10, 2016 by Diefenthal 1
Guest Diefenthal Posted April 15, 2016 Posted April 15, 2016 hmmm no fork and no help is answer enough for me for me is the try to help there out finshed and think if @@Luke read the definitions and specifications can he understand how it works here in both threads are enough informations to Support Sat>Ip
Nikolaech 32 Posted April 15, 2016 Posted April 15, 2016 @ Diefenthal Tell us more about Octopus NET S2 Sx Cx Tx. This is a good solution for Emby circular LNB Non-standard lo frequency? plugins? EPG? Support third-party sources EPG CI+ CI which encoding is supported? home sharing conditional access cards? or where to read? Thank you. 1
Luke 42242 Posted April 15, 2016 Posted April 15, 2016 hmmm no fork and no help is answer enough for me for me is the try to help there out finshed and think if @@Luke read the definitions and specifications can he understand how it works here in both threads are enough informations to Support Sat>Ip Thank you for all of your help.
